Clamp Meter for DC amp readings - Page 2
Results 21 to 40 of 41
  1. #21
    Default Re: Clamp Meter for DC amp readings
    That actually looks very good.
    Relative mode can be very handy - my one doesnt have that.
    What does the relative mode do?
  2. #22
    Hillcrest, Malaysia
    Thanked: 5968
    Quote Originally Posted by Bulletjie-3 View Post
    You take a reading, store it and then take another reading. The meter displays the difference between the two readings.
    Very handy for looking for things like volt drops. Once you have taken the first reading all subsequent are actual voltage differences. So you dont have to write things down or memorise them and then do the math.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  3. The Following 4 Users Say Thank You to Fluffy For This Useful Post:
  4. #23
    Wartburg
    Thanked: 1109
    It is a handy function. My DC current readings sometimes are not zero before clamping the meter over the cable. I then use the relative mode to "zero" the display.
    Am also very impressed with the UNI-T models. Had one for many years, and lost it at some client's place - unfortunately I did not know which one. Bought this replacement from Banggood a couple of years back.
  5. The Following 5 Users Say Thank You to mikeml For This Useful Post:
  6. #24
  7. #25
    Hillcrest, Malaysia
    Thanked: 5968
    Clever.
    ZS5KAD
    3 V8's
  8. #26
    Gaborone, Botswana
    Thanked: 949
    I have this one. Mastech MS2109A from Banggood . US$46-88. (Add a few hundred ZAR for shipping/duties )
    Kobus
    Nissan
  9. The Following User Says Thank You to KobusDJ For This Useful Post:
  10. #27
    Thanked: 301
    I can add the Major Tech MT723 which has a temp probe function as well as LED to pick up voltage without making contact with the probes. Also has the relative and hold functions.
  11. The Following User Says Thank You to ekkekan For This Useful Post:
  12. #28
    Thanked: 1014
    How does that compare to the earlier Uni-T model linked to on banggood?
  13. #29
    Thanked: 662
    So if I wanted to monitor my secondary battery current draw on an ad hock basis. Could I not, in a permanent installation, wind a ferrite core with enameled copper wire, with the correct ratio of turns, and use this with a normal multi-meter?
    One decimal place accuracy would be more than sufficient.
    If this is possible how does one go about this?
  14. #30
    Hillcrest, Malaysia
    Thanked: 5968
    Nope, wonít work for DC only AC.
    Itís a transformer function. Requires fluctuating magnetic flux.
    What you are attempting is a transformer. Only works with AC, not DC.
    ZS5KAD
    3 V8's
  15. The Following User Says Thank You to Fluffy For This Useful Post:
  16. #31
    Gaborone, Botswana
    Thanked: 949
    The only way to compare is to look at the specs for both. (Available in the separate links) .
    Kobus
    Nissan
  17. #32
    Mar 2011
    Walker Bay
    Thanked: 1020
    Kobus - several brands mentioned in this thread. Which one are you ordering?
  18. #33
    Polokwane
    Thanked: 467
    If the experts concur I will be ordering the UNI-T UT210E
    Main features
    1. Ultra-portable tools for advance electricians
    2. 100A AC and DC current measurement with 1mA resolution
    3. True RMS response for AC current
    4. V.F.C function for measuring signal at variable frequency
    5. 600V AC and DC voltage measurement
    6. Resistance, diode, continuity and capacitance functions
    7. Non-contact voltage detection with LED indication
    8. Display backlight
    9. Data HOLD, MAX, MIN, MAX-MIN, and ZERO model
    https://www.banggood.com/UNI-T-UT210...r_warehouse=CN
  19. The Following 4 Users Say Thank You to DC Polokwane For This Useful Post:
  20. #34
    Thanked: 1014
    In my experience its better not to rely solely on specs with cheaper tools, real world user feedback is better, that being said Uni-T definitely has a good reputation for being decent quality and excellent value for money.
    I can't wait to get a ac/dc clamp meter, so convenient, looks like my Fluke will be sent to the back of the cupboard or the classifieds
  21. #35
    Aug 2019
    Kimberley / Edenvale
    Thanked: 45
    I think I posted the wrong one then. Mine can definitely do it.
    Hi Uys, then you have a very nice meter. Last time I checked the checked the cheapest Fluke that can do DC amps is the 325 costing over R6000-00 ,so out of reach for most hobbyist like us, but we dont all have the same sized wallets so maybe you take your hobbies more serious.
    Its fairly simple to measure AC amps, as with AC you can couple a current transformer ( the clamp of the meter) to the cable you are measuring as die alternating current will induce current in the clamp meter.
    With the DC cannot induce a current in the clamp meters clamp. Rather we make use of the Hall Effect which is bit more expensive to implement.
    The other option which also the cheapest way to measure DC amps is to measure the voltage over a current shunt.
    Most multi meter can measure DC amp but you have to connect the meter in series with the circuit.
    Most Fluke deaths can be attributed to incorrect usages while being used for DC current measurements ( in series measurements not DC clamp meters)
  22. #36
    Gaborone, Botswana
    Thanked: 949
    I already have the Mastech MS2109A
    Kobus
    Nissan
  23. #37
    Plett/Paulshof
    Thanked: 771
    Contact me if you want to sell your Fluke...pm me details pls.
    2016 LC 200 VX, 2014 D4 SDV6 HSE(sold),2015 Suzuki Jimny, 2019 VW Tiguan 4mtion 2.0tsi(work vehicle), "A little Red Car", Swambo 2013 A3 Sportback Quattro, Bush Lapa Baobab 1873, Fusion 17 boat-Yamaha FT100hp 4st.
  24. The Following User Says Thank You to BruceHun For This Useful Post:
  25. #38
    Thanked: 1014
    The leads on the MASTECH look like they are very nice quality?
    That normally bodes well with multimeters
  26. #39
    Oppierotse
    Thanked: 222
    Fluke = 11.45mA and Uni = 11mA
Name:	001 (800x600).jpg
    Fluke = 3.89mA and Uni = 4mA
Name:	004 (800x600).jpg
    Fluke = 0.2A and Uni = 193mA
Name:	006 (800x600).jpg
    Fluke = 1.87A and Uni = 1.86A
Name:	007 (800x600).jpg
    98 Hilux 2.8D D/C 4x4
  27. The Following 4 Users Say Thank You to wiel For This Useful Post:
  28. #40
    Thanked: 1014
    Quote Originally Posted by wiel View Post
    Thanks for posting that, for most peoples purposes that level of accuracy should be plenty, will do for 99% of the time.
  29. The Following User Says Thank You to Skylark For This Useful Post:
