Cylinder head temperature
Results 1 to 18 of 18
    Jan 2017
    Kuilsrivier
    Thanked: 20
    Default Cylinder head temperature
    Good morning all, what is the maximum safe Cht for a water cooled enjin
    Thanked: 9658
    Default Re: Cylinder head temperature
    Most people reckon under 110 deg C.
  3. The Following 2 Users Say Thank You to jelo For This Useful Post:
    Jan 2017
    Kuilsrivier
    Thanked: 20
    Thank you Jelo
    Pennington
    Thanked: 130
    Depends on what pressure cap is used as the higher the pressure the higher the boiling point. Ideal would be a max of 10deg below boiling
    Thanked: 9658
    Quote Originally Posted by mplester View Post
    You've just contradicted yourself.
    A 1.1bar cap implies a coolant temp of 110 deg C at sea level. How can the head be below boiling?
  7. The Following User Says Thank You to jelo For This Useful Post:
    Pennington
    Thanked: 130
    118.6 not 110
  9. The Following User Says Thank You to mplester For This Useful Post:
  10. #7
    Barberton
    Thanked: 934
    For my own clarity: I assume CHT in this case actually means coolant temperature as it exits the head.
  11. #8
    Thanked: 9658
    no he said CYLINDER HEAD TEMPERATURE so that implies the metal material
  12. #9
    Thanked: 9658
    118.6 not 110
    indeed which once again begs the question on 90 degrees?
  13. #10
    Pennington
    Thanked: 130
    If boiling is 118.6 and you subtract 10 = 108.6 not 90.
  14. #11
    May 2016
    Thanked: 2709
    Strange that he asks specifically for CHT - not coolant temp in general.
    Coolant temp does not vary that much in the engine (block and head) because of the fast circulation.
    Maybe he was actually asking about EGT?
    2006 VW Touareg V10 TDi
  15. #12
    Barberton
    Thanked: 934
    Quote Originally Posted by 4eTouareg View Post
    Yeah..
    The EGT numbers generally posted on forums suggest that the gasses passing through the head to generate +100C coolant temperatures, should be 4 to 5 times higher than the coolant temperature. So at a specific moment it should be possible to get a head reading anywhere from 100C to 500C, depending on where you take the reading.
  16. #13
    Thanked: 9658
    aha then I misunderstood what you meant by boiling
  17. #14
    Jan 2017
    Kuilsrivier
    Thanked: 20
    Hi all, please see attached image for my cht and egt sensor setup. Name:  IMG_20190820_210855.jpg
  18. #15
    joburg
    Thanked: 334
    Very close to exhaust manifold? Probably not going to accurately indicate head temp ?
  19. #16
    Thanked: 1523
    Boiling is not a function of only temperature, pressure also plays a part, hence the 1.1 bar cap NOT resulting in boiling at 110 C.
    Boiling is the rapid vaporization of a liquid, which occurs when a liquid is heated to its boiling point, the temperature at which the vapour pressure of the liquid is equal to the pressure exerted on the liquid by the surrounding atmosphere.
    In the case of a pressurised system, the pressure goes up and so does boiling temperature.
    Water boils at about 68C on Everest.
    https://en.wikipedia.org/wiki/Boiling_point
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  20. #17
    Thanked: 2206
    Quote Originally Posted by leonst38 View Post
    Is the temp probe for water temp installed in a waterport ? You need to have that as close as possible to the OEM temp sensor installed into a wateport.
  21. #18
    Jan 2017
    Kuilsrivier
    Thanked: 20
    Hi Grips, no it doesn't measure water temp. It's fitted to the head. I have a separate feed for water temp.
  22. The Following User Says Thank You to leonst38 For This Useful Post:
