Amarok On GY Wrangler Adventure - Ride Quality concerns
Results 1 to 10 of 10
    Jul 2017
    Default Amarok On GY Wrangler Adventure - Ride Quality concerns
    Hi Guys
    I recently fitted a set of GY Wrangler Adventures on my Amarok. They are 265/60/18 as per spec on Vehicle door tag.
    I find that the ride quality isnt as good as it used to be. When cruising on highway the ride feels 'bobbly', as if every slight bump on the road surface is being felt. The old tyres didnt feel like this (Duelers at the front and Geolanders at the rear)
    Can anyone else post their experiences with these tyres on their Amaroks?
    Melkbosstrand
    Thanked: 159
    Default Re: Amarok On GY Wrangler Adventure - Ride Quality concerns
    Are they not perhaps a little hard?
    Your "symptoms" are similar to what I had when I "over" inflated my tyres on my previous bakkie
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  3. The Following 2 Users Say Thank You to BobMabena For This Useful Post:
    PRETORIA
    Thanked: 41
    All The Spirit Of Africa Amaroks Runs those Tyre in the competition. But all 265/65/17. They do very well with everything through at them by the Drivers
    FOTON TUNLAND 4X4 LUX
    Swakopmund
    Thanked: 631
    Play around with the tyre pressures. Deflate them by 0.2 bar and see whether it makes a difference. Feel the tyres after you have been driving highway for a while. If they are warm to the touch, it's fine. If they are hot, pressure is too low. Experiment a bit.
    Watch the wear pattern: if they wear in the middle more than towards the sides, pressure is too high.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
  6. The Following User Says Thank You to HugoNotte For This Useful Post:
    Jul 2017
    Thanks guys, bobmabena was on the money. Seems the place I used to get the pressures done had them over inflated. Running them at 2.1bar now and it feels fine. There is slight vibe/left to right move t of the steering but I think that's balancing. Will get that checked out at the soonest. Seems the Tyre shop I went to doesn't really know what they doing.
    Melkbosstrand
    Thanked: 159
    Quote Originally Posted by CTDi View Post
    Glad you're sorted...
    Seems tyre places (almost without fail) over inflate the tyres...
    Jul 2017
    Thanks for the responses guys...
    Amorosa
    Thanked: 355
    Quote Originally Posted by BobMabena View Post
    They do yes.
    Had new tyres fitted to the company car on Friday. They were inflated to 2.7 bar. Vehicle spec shows 2.2 bar.
    Bush Lapa Miskruier 586
    Jul 2017
    Seems like the Tyre shops don't bother calibrating the equipment often enough
    PE & North Africa
    Thanked: 335
    Even the Stealers do that, had it on my previous Hilux.
    Just the other day I took my cousins Fortuner for a test drive after we picked it up from a service in Pretoria... Immediately I told her they are overinflated and she should get a gauge to keep inside the car. Checked... 2.8 bar
    2008 Fortuner 3.0 D-4D 4x4 "Sushi the Tuna"
    2018 Baobab 4 - B1543 "Nala"
    Bacon fact #16 - Bacon is Healthier than Crystal Meth!
