GWM Steed 5 flat spot at 2000 rpm
Results 1 to 2 of 2
    Aug 2019
    Lephalale
    Default GWM Steed 5 flat spot at 2000 rpm
    Good morning all,
    I have a GWM Steed 5 2.5 TCi and sitting with a flat spot between 2000-2200 Rpm. It is not so bad in the morning when its is still cool but in the afternoon I cant even get past the flat spot in second gear....no power at all.
    Anybody with the same problem and what the cause may be?
    Mar 2013
    Thanked: 13
    Default Re: GWM Steed 5 flat spot at 2000 rpm
    Your problem sound worse than I had.
    I'd advise to have a diagnostic test to check if there are any issues that can be picked up.
    Also have a look at the catalytic converter as mine was badly blocked.
    Perhaps also have the turbo and pipes checked for boost leaks as well.
