Defender Itís my Defender 90 2.8 thread - Page 2
Page 2 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 21 to 40 of 164
    Feb 2015
    Thanked: 74
    Default Re: Itís my Defender 90 2.8 thread
    Quote Originally Posted by swazi85 View Post
    Very nice congrats, also looking for a 2.8 90 at the moment.
    Just saw a 2001 90 2.8 for sale on Facebook (Land Rover S.A 4x4 group) for R165 000.00
    2016 Ford Everest 3.2Tdci XLT AWD A/T - Mods have begun!
    2010 BMW 320i AT (SWAMBO)
    Ex: 1998 Land Rover Defender 300Tdi - ek huil nogsteeds myself aan die slaap
    Ex: 2014 Ford Ranger 2.2 DC 4x4
    Always go for the deepest mud, muddy stories make the best memories!
  2. The Following User Says Thank You to Henko88 For This Useful Post:
  3. #22
    Apr 2008
    Welkom
    Thanked: 75
    Quote Originally Posted by Riebeeker View Post
    There is a great whatsapp group that is run by James Sander. PM me your number and I will ask him to add yoy.
    There is a Facebook group too.https://www.facebook.com/groups/883932585061986/
    Land Rover Defender 2.8i 110 CSW.
  4. #23
    Apr 2011
    Thanked: 1005
    Quote Originally Posted by Zapiture View Post
    G-kloof
    And you?
    W-Kloof.
    Will keep my eyes peeled!
  5. #24
    Feb 2014
    Thanked: 551
    Quote Originally Posted by Jacque W View Post
    Hi Jacque,
    Thanks for the link
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  6. #25
    Feb 2014
    Thanked: 551
    Ok, so Iíd like to put new threads on. I have a new set of Coopers 17Ē but canít find 165.1 PCS 5 stud rims so that seems to be a dead end.
    Iím leaning towards 285/75/16Ē after seeing and reading some suggestions on the net. Some advise?
    Zapiture,
  7. #26
    Thanked: 606
    285s will make your 90 feel very pap, unless you change the gear ratios.
    the biggest I would go with is 265/75 if you want wider tyres, or 235/85 or 255/85 if you want a bit more sidewall/ground clearance.
    personally, I prefer skinnier & taller tyres because it allows you a bit more flexibility wrt your lines when driving trails.
  8. #27
    Thanked: 256
    Depends on your application for the vehicle. 285 has made a big difference for offroad use on my 110. For overlanding 235s.
  9. #28
    Thanked: 1104
    I think they are going to rub. I experienced rubbing after putting on 265/75/R16 and had to adjust the turning circle.
    Defender 2.8i
    People talking without speaking
    People hearing without listening
  10. #29
    Feb 2014
    Thanked: 551
    Even the 2.8? It sure goes like a bat out of hell. Iím suspicious that it may be fiddled with. How would one know?
    Zapiture,
  11. #30
    Feb 2014
    Thanked: 551
    Quote Originally Posted by Jakkals. View Post
    Iím still figuring out what the plan is. Initially I thought that most of my overlanding will be done with my Discovery. The 2.8 is just a blast as a toy. Then, I still have the 3.8 Paj. Thought of fixing it to sell but the guys have done such a super job I think I must keep that too. Space is a slight problem though.
    Zapiture,
  12. #31
    Feb 2014
    Thanked: 551
    Default Itís my Defender 90 2.8 thread
    So today I had the rear step redone with some heavy duty Aluminum Vastap that I had laser cut.
    Had to first prep the step. It had some thick adhesive on. Only way was a grinder and flapdisk:
    Then bonded it with some Sika:
    Zapiture,
  13. The Following 2 Users Say Thank You to Zapiture For This Useful Post:
  14. #32
    Thanked: 1104
    I would have offered that you take mine for a spin in order to compare, but my exhaust is in pretty bad shape and I suspect it is way down on power at the moment. It might not be a good vehicle to use as a benchmark.
    Defender 2.8i
  15. #33
    Feb 2014
    Thanked: 551
    Quote Originally Posted by albertvl View Post
    I noticed this:
    Closer view of the little pipes that are not connected:
    Whatís up? So the search begins what they are.
    Zapiture,
  16. #34
    Thanked: 2463
    Diff breather ?
    BMW R1200R
  17. #35
    Jul 2014
    Waterfall
    Thanked: 67
    Looks like diff or gearbox extended breather pipes
    2016 V8 D/Cab Cruiser
    Land Cruiser VDJ 71
  18. #36
    Bellville
    Thanked: 32
    Perhaps extended diff/gearbox/transfer breathers?
    follow them and see where they go
    Triton 3.2 DiD
  19. #37
    Feb 2014
    Thanked: 551
    Quote Originally Posted by Hardus Bezuidenhout View Post
    Ah yes probably. Is that standard?
    Zapiture,
  20. #38
    Feb 2014
    Thanked: 551
    The spots rewired. Apparently never worked:
    Zapiture,
  21. #39
    Thanked: 1104
    Jips, breather pipes and they come standard like that.
    Defender 2.8i
  22. #40
    Feb 2014
    Thanked: 551
    You mean loose like that?. Donít they have a mounting bracket?
    Zapiture,
