Defender Itís my Defender 90 2.8 thread - Page 3
Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 41 to 60 of 164
  1. #41
    Fourways Gardens
    Thanked: 589
    Default Re: Itís my Defender 90 2.8 thread
    Quote Originally Posted by Zapiture View Post
    You mean loose like that?. Donít they have a mounting bracket?
    No, they just hand onto things in the engine bay
    Serious, im not joking.
    Series III 88"
    Scout Nomad
  2. #42
    Feb 2016
    Thanked: 611
    yep, even on the Puma they were just hanging around. I cabled-tied all together in one spot, out of the way.
  3. #43
    Thanked: 1105
    I haven't seen them being mounted on a bracket. Cableties should be fine.
    Defender 2.8i
  4. #44
    Feb 2014
    Thanked: 556
    Quote Originally Posted by albertvl View Post
    I donít like. Iím off to Festo to get me some tube brackets:
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  5. #45
    Feb 2014
    Thanked: 556
    The spots rewired. Apparently never worked:
    Job done. Happy:
    Zapiture,
  6. The Following User Says Thank You to Zapiture For This Useful Post:
  7. #46
    Feb 2016
    Thanked: 611
    haha, if a tiny details like that bothers you, then a Defender is the wrong car for you
  8. #47
    Feb 2014
    Thanked: 556
    Doesnít bother me at all but I bought the 90 for exactly this reason: to fiddle.
    Zapiture,
  9. #48
    Feb 2014
    Thanked: 556
    Had a bracket bent to install under the glove box to leave space for the amp. Turned out great, the arm rest is at a much better hight.
    Installed 6Ēx9Ē behind the jump seats in a he back.
    Sounds good.
    Zapiture,
  10. #49
    Feb 2014
    Thanked: 556
    So I need some advice:
    Seems my Cross Rod (9)and Track rod (7) has taken a beating.
    Difficult to fix?
    Is it pricey?
    Where?
    Zapiture,
  11. #50
    Feb 2014
    Thanked: 556
    Ok so my guys have confirmed the Track Rod is definitely deformed. I can get a ORM set (track and cross) complete including track rod ends from the UK @ R2800 delivered at my door.
    Is that the right price?
    Zapiture,
  12. #51
    Thanked: 1105
    If I am understanding you correctly you want to replace everything, not just the bent rods?
    What is your reasoning for doing this? Is it because the rods are seized in place? If so, there is a way to get them loose.
    Heat up the rod-ends with a blowtorch and then pour oil into the slits of the rod-ends. Repeat the process a couple of times on each end.
    Try not to set your Landy on fire - keep a fire extinguisher close-by.
    After each heating cycle, give the rod-end a good couple of whacks with a hammer. Then use a bobbejaanspanner and see if you can break the seized thread loose.
    It took me around an hour to get the whole mess un-seized. I had to do it in order to get wheel alignment done. Perhaps you can follow the same procedure and get an engineering shop to straighten your existing rods. I think it would cost much less than to have new ones ordered.
    Defender 2.8i
  13. #52
    Thanked: 560
    Iíd love to hear what the rest of you guys did with insurance: what maximum value were you able to insure for and who is the underwriter?
    Zapiture, at the beginning of 2018 my 110 Td5 Double Cab's "book value" was R80k. I wrote to my insurer (Western Insurance) explaining the situation with Defenders and included a couple of ads from Gumtree, cars.co.za and Autotrader to prove my point. I was told to go to an accredited Land Rover dealer and get a quote (on their letterhead) stating what they would sell it for if it was on their floor. They valued the vehicle at R160K and the extras at R80K (replacement value). It was insured at that value.
    ENJOY!!!
    Ettienne
    1980 Range Rover
    2002 Defender Td5 D/C
    2004 Disco Td5
  14. The Following User Says Thank You to EttiennedK For This Useful Post:
  15. #53
    Thanked: 1023
    Did they allow adding cover for the full R80k worth of extras, ie the vehicle is insured for R240k?
  16. #54
    Thanked: 560
    Yes, full R80K is covered.
    ENJOY!!!
    Ettienne
    1980 Range Rover
    2004 Disco Td5
  17. #55
    Thanked: 1023
    Score, did they gouge you on the premuim though, for the uprated vehicle value?
    Still not such a high value and not high theft risk either.
  18. #56
    Feb 2016
    Thanked: 611
    is this what you're looking to replace?
    http://www.expeditiongear.co.za/pEG2...Defenders.aspx
  19. #57
    Feb 2014
    Thanked: 556
    Default Itís my Defender 90 2.8 thread
    Hi Albert, yes, Iíve taken the view if I can, I replace everything I work on with new and if possible upgraded version. That way I hope to gradually restore to as close to new as is practical.
    Zapiture,
  20. #58
    Feb 2014
    Thanked: 556
    Hi Ettienne,
    This is valuable info, thanks. What would constitute ďApproved LandroverĒ?
    Zapiture,
  21. #59
    Feb 2014
    Thanked: 556
    Orxy,
    Exactly what I want. Thanks man. Iíll place order tomorrow. Do you know if they ship to Pta?
    Have you purchased this from them?
    Zapiture,
  22. #60
    Feb 2014
    Thanked: 556
    First trip with the bambinoís. They donít want to get out:
    Zapiture,
