Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 161 to 178 of 178
  1. #161
    Mossel Bay
    Thanked: 821
    Default Re: Sous vide cooking
    Quote Originally Posted by heyyahhey View Post
    not in 20 minutes. Ive been sous viding for years.
    there are significant benefits to it other than for mass catering events.
    As I understand it @Sandjan's post says that if you have to get that many steaks ready in 20 minutes, then you sous vide them to the preferred level before the time. And then finish them off on the grill in 20 minutes.....
  2. #162
    Nov 2012
    Thanked: 1726
    Some misunderstandings.
    You sous vide before the time. Even a day or 2 before. Then warm up to temp below the sous vide cooking temp and sear. The time in the sous vide is not 20 minutes.
    Choose life
  3. #163
    Apr 2019
    Thanked: 2638
    Quote Originally Posted by Coenoes View Post
    as I said - my misunderstanding. We do that all the time, particularly for the bush... But the other poster, commenting that there is no reason to sous vide in small quantities, is missing out.
  4. #164
    Jan 2019
    Amsterdam
    I don't know why more people don't do this. I cooked a $2.50 sirloin steak and it was as good as any steak from a fine restaurant.
    For the uninitiated, you place your uncooked food in a plastic bag, remove the air using either a vacuum or by dipping the bag in water, seal the bag, and then submerge the bag in water held at a very specific temperature for an hour or more. The result: your food is cooked to the same doneness at the centre as it is at the edges.
    I don't have a proper sous vide machine so I used a slow cooker and a candy thermometer. First I calibrated the candy thermometer by inserting it in boiling water and found it was about 20 off. I filled the slow cooker with water and turned it on high until it reached 140F. Then I turned it to low and dropped my seasoned and bagged steaks in.
    Fortunately my slow cooker has a hole in the lid, I guess for venting. So I inserted my thermometer there so I could keep an eye on the temperature. I thought I'd have to hover over it but the temperature changed so slowly I only needed to turn it on or off every 20 minutes or so.
    After an hour I double checked the temperature of the steak with a meat thermometer, then seared the steak on the stove in butter for 30 seconds on each side.
    It was divine.
  5. #165
    Nov 2012
    Thanked: 1726
    Lamb shanks, olive oil, salt,pepper, rosemary. In the sous vide for 24 hours at 68 deg. Will be for lunch tomorrow. Results will be posted later.Click image for larger version.
    Choose life
  6. The Following 4 Users Say Thank You to Coenoes For This Useful Post:
  7. #166
    Sep 2019
    Pretoria East
    Thanked: 1951
    Lyk heerlik
  8. #167
    Jul 2010
    Pinetown
    Thanked: 2700
    Why not post on the "It are time thread" ?
    Reason ?
    Many more participants and some amazing ideas, recipes and methods.
    Look back through earlier posts.
    This is a very old thread that you have revived - nothing wrong with that at all - just suggesting.
    Peter Hutchison
    Platkar = Chevy Spark 1.2
  9. #168
    Kayser's Beach,East London
    Lyk heerlik!
  10. #169
    Apr 2017
    Durban North.. my name Dudley Reid
    Thanked: 5163
    Canoes that is amazing,
    Please post on It are Time
    As well
  11. #170
    Jhb
    Thanked: 60
    I made up my own soux vide controller, cost me about R200
    I bought a digital temperature controller (https://www.communica.co.za/products...contr-10a-220v) and mounted onto a 15A plug box.
    I use it to control my slow cooker, the temperature probe lies in the water and the controller switches the power on and off in order to control the temperature to a setpoint.
    Works amazingly well. Have cooked T-bones for 2 hrs at 53degC to short ribs for 48hrs.
    Bruce
    2010 Toyota Hilux 4x4 3.0D4D
    Bushlapa Miskruier BL15
  12. The Following 6 Users Say Thank You to out of africa For This Useful Post:
  13. #171
    Gaborone, Botswana
    Thanked: 1780
    What power rating for the stick thing.
    1000W? 1200W? or can one go as lo as 750W?
    Will the higher power ones just heat up faster?
    Kobus
  14. #172
    Jhb
    Thanked: 60
    I think you draw a max of 10A though the controller, which equates to about 2.2kW
    You don't need much power though, I start off by adding hot water to the bath so it's roughly at the desired temperature. All the controller does is then maintain this
    Bruce
  15. #173
    Gaborone, Botswana
    Thanked: 1780
    Quote Originally Posted by out of africa View Post
    I was actually talking about the dedicated Immersion Thermal Circulator Stick. I see they come in different power versions.
    But come to think of what you do. I have an urn with a home built temp regulator that I use for something else . I just need to put a grid about 100mm above the element (I don't want the bag to touch the element). Thermocouple should go in the water at food/bag level. It should work.
    Kobus
  16. The Following User Says Thank You to KobusDJ For This Useful Post:
  17. #174
    Jhb
    Thanked: 60
    Bruce
  18. #175
    Gaborone, Botswana
    Thanked: 1780
    Did a quick conversion to my cooking vessel.
    It can now do sous vide.
    Starting with a rump steak.
    Kobus
  19. #176
    Nov 2012
    Thanked: 1726
    It depends on the vessel you are using it in. If you have a large uninsulated vessel the heat loss can be too much for the element to maintain the desired temperature.
    In my professional Komet Julia sous vide cooker is 1000W for the 14L capacity. It is properly insulated and the elements are on maybe 5% of the time just to maintain the temperature.
    Choose life
  20. The Following 3 Users Say Thank You to Coenoes For This Useful Post:
  21. #177
    Dec 2013
    Thanked: 66
    Thank you for sharing.
    I bought the same thermostat at Micro Robotics Centurion : +- R80. (Communica out of stock).
    I copied your slowcooker plan. It works very well.
    "Cooked" a big gammon in it 72 16hours.
    The BEST gammon ever!
    I covered the slowcooker with a wonderbag and the thermostat switched on very seldom.
  22. The Following 3 Users Say Thank You to Karrooseun For This Useful Post:
  23. #178
    Dec 2007
    Nkomasi
    Thanked: 444
    May I add something. Its important to circulate the water. Especially over long periods. For an hour or two a cooler box thermometer a kettle or element will suffice. I started this way and bought a machine later.
  24. The Following 2 Users Say Thank You to bertus For This Useful Post:
