Sous vide cooking - Page 3
Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 41 to 60 of 151
  1. #41
    Apr 2019
    Thanked: 232
    Default Re: Sous vide cooking
    Anyone using it for chicken
    or chicken breasts?
    Fantastic for that. Very juicy.
    Ive used this recipe among others:
    https://www.seriouseats.com/2015/07/...en-breast.html
    personally id not use it for dark meat - just because I think that’s much better on the braii
  2. The Following User Says Thank You to heyyahhey For This Useful Post:
  3. #42
    Nov 2012
    Thanked: 495
    Whole chicken cooked perfectly right through. Never dry. Then you just finish it off under the grill or on the fire.
    Dark meat you still braai to get the smoke and braai flavors but you sous vide it first to ensure the tenderness and juiciness.
    Choose life
  4. #43
    Hillcrest, Malaysia
    Thanked: 5945
    personally id not use it for dark meat - just because I think thatís much better on the braii
    Very interesting link. Thank you.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  5. The Following User Says Thank You to Fluffy For This Useful Post:
  6. #44
    Apr 2017
    Durban North
    Thanked: 826
    When you tried the dishwasher top or bottom rack
  7. The Following User Says Thank You to Dudleytheplumber For This Useful Post:
  8. #45
    Quote Originally Posted by Dudleytheplumber View Post
    Would be keen to see you pull this off today. Shouldnít be too difficult.
    Iíd just place it in the dishwasher in a place where it doesnít get direct water pressure.
  9. #46
    Virginia
    Thanked: 856
    Any place where one could purchase off the shelf?
    Out here in the sticks a courier service is always a challenge, and I don't trust the Postal service .
    Will be in Joburg next month and I'd really like to get kitted out!
  10. #47
    Apr 2019
    Thanked: 232
    Quote Originally Posted by Bacon View Post
    They sell them on takealot. We live in JNB - if you want to order for delivery to my place you can pick it up when you are in town.. PM if you want.
  11. The Following User Says Thank You to heyyahhey For This Useful Post:
  12. #48
    Thanked: 163
    Takelot also does pickups from central points across jhb. Big one at new road on N1
    Riku
    2011 Echo4 with Blinkgat Nose cone and
  13. #49
    Hillcrest, Malaysia
    Thanked: 5945
    What about a hot air M/W with a bowl of water and zip lock bags. ?
    ZS5KAD
    3 V8's
  14. The Following User Says Thank You to Fluffy For This Useful Post:
  15. #50
    Apr 2019
    Thanked: 232
    Quote Originally Posted by zeek View Post
    lol - I didnít even think of that... !
  16. #51
    Default Sous vide cooking
    I would think that it would be more difficult to sustain a controlled temperature of about 60 degrees c over a period of about 2 hours in any kind of microwave oven.
    A steak with a grey inside isnít appealing to any steak lover.
  17. #52
    Thanked: 163
    We used the dishwasher yesterday to "cook" 2 steaks and it worked beautifully
    2 flintstone steaks as they called shrink wrapped from the store. Took all the paper and labels off and layed them on top shelf
    Normal wash cycle on 60 deg, took just over an hour
    Then onto braai for about 5 minutes aside and took it off, medium rare perfect and so soft.
    Will do that again next Sunday
ID:	537723   Click image for larger version.
    Riku
  18. The Following 5 Users Say Thank You to zeek For This Useful Post:
  19. #53
    Apr 2019
    Thanked: 232
    i wonít try my sous vide brisket recipe that way - 50 hours is a long time for the dishwasher :-)
  20. #54
    Thanked: 163
    Yes that will require many many dishes lots of energy and water
    Riku
  21. #55
    Hillcrest, Malaysia
    Thanked: 5945
    Quote Originally Posted by Therackermann View Post
    You donít have the M/W on M/W. Hot air only. It very accurately thermostatically controlled.
    Donít forget the water has thermal inertia to smooth out any temperature blips and dips.
    ZS5KAD
    3 V8's
  22. The Following User Says Thank You to Fluffy For This Useful Post:
  23. #56
    May 2016
    Thanked: 2746
    I suppose a hot air fryer will be able to do it as well, then?
    Fill the bowl with water, set it to 60 deg and the timer to 60 min?
    2006 VW Touareg V10 TDi
  24. #57
    Nov 2012
    Thanked: 495
    Only problem I see is that the 60įc will give a medium steak. 54įc is a perfect medium rare. Come borrow my sous vide then you make a 4 hour 54deg steak.
    Choose life
  25. The Following User Says Thank You to Coenoes For This Useful Post:
  26. #58
    Check this out for an expert opinion
    https://www.youtube.com/channel/UCpF...PKLolFR3gWhrMw
  27. #59
    Oct 2006
    Thanked: 16
    Maybe a bit unsophysticated for some but I bought a Rough Toti plastic crate at Builders and install a geyser element permanently inside, calibrated it on 55deg (donít trust the termostatís indications) and there we go... fill it with water when needed and voila, works perfectly
    Willem Grobler
    LC 105 GX
  28. The Following User Says Thank You to Willem Grobler For This Useful Post:
  29. #60
    Nov 2012
    Thanked: 495
    Quote Originally Posted by Willem Grobler View Post
    That is good for most meat products. You will need accuracy when doing eggs for example. With eggs the temperature range from raw to hard is only 10 degrees and 0.2 degrees difference makes a difference in the texture of the egg. A professional cooker should be PID controlled with 0.1 deg accuracy.
    Choose life
  30. The Following User Says Thank You to Coenoes For This Useful Post:
