Water Epupa falls
Results 1 to 19 of 19
    Aug 2019
    Netherlands
    Default Water Epupa falls
    Hello,
    We're planning to make a roundtrip through Namibia and Botswana in October this year and then also visit the Epupa falls. I've read that it's very dry at the moment. Does anyone have an idea if the Epupa falls will be worth a visit in October? Or is it better to skip it and use this day somewhere else?
    Kind regards,
    Nakoma
    Okahandja, Windhoek
    Thanked: 729
    Default Re: Water Epupa falls
    I see the power station in Whk some times is working, that means then usually that Ruacana is not operating, which means no water through the turbines, then it could be that the falls don't have water, or very little. The Ruacana is depend on water from the dam upstream in Angola.
    Johan Kriel
    LC's and Echo Chobe
    Aug 2014
    Simons Town
    Thanked: 968
    We visited the fall's last July when they were flowing nicely ...It's a magical place....
    Okahandja, Windhoek
    Thanked: 729
    On Nampower website they report 34 cub m /sec
    Johan Kriel
    LC's and Echo Chobe
    Thanked: 3274
    For Ruacana falls or Epupa falls?
    Okahandja, Windhoek
    Thanked: 729
    Quote Originally Posted by lekhubu943 View Post
    I assume thats what is currently running thr' the turbines at Ruacana. Ruacana falls are bone dry anyway for 99% of the time as the water is diverted thr' the turbines.
    Johan Kriel
    LC's and Echo Chobe
    Bethlehem
    Thanked: 255
    If this is what you want to see , only when Cunene is in flood after heavy rains in Angola .
    April 2011 .
    Cruiser 76 EFI 4.5 FullTime 4x4
    Cruiser 78 4.2 Diesel
    Cruiser 79 4.2 Diesel Full Time 4x4
  8. The Following User Says Thank You to Swart Jan For This Useful Post:
    Aug 2019
    Netherlands
    Thank you for the answers. Is Ruacana usually about the same level of water as Epupa? Do I understand it right that it all depends on the power station? So then there's nothing to say about the chances in October?
    Jul 2013
    Contact Koos Verwey at Epupafalls lodge. He is right next to the river operating a beautiful lodge. He will give you on the spot info. The best out there.
    or use the links below to get hold of him through his website as he may be off doing some tours back country or in Angola.
    I chatted to a farmer in that area quite recently and he told me the river was quite dry.
    http://www.openafrica.org/experience...e-and-campsite
    http://epupafallslodge.com/contact-us/
    [email protected] or +264 (0)81 250 8225 (Office Hours Only)
    Okahandja, Windhoek
    Thanked: 729
    Quote Originally Posted by Nakoma View Post
    Yes . I saw both towers are smoking today in Windhoek, so it could be that Ruacana is not working, or can't. Yes flow is control from the storage dam in Angola for the Ruacana Turbines. Normally the flow varies during the day depends on the demand for power varies.
    It might be that the dam levels are too low?!, or only down temporarily for maintenance.
    Johan Kriel
    LC's and Echo Chobe
    Jul 2013
    Thanked: 266
    If those two chimneys are smoking we do not get enough power from za. Or we are supplying to zim.
    Mar 2017
    Okahandja
    Thanked: 624
    This was the river down stream of the Ruacana falls a week ago. Best to call one of the lodge on the river closer to October Click image for larger version.
  14. The Following User Says Thank You to Erwin Schimper For This Useful Post:
  15. #13
    Lichtenburg
    Thanked: 158
    We were there 25th of June this year and this is how it looked. Nothing spectacular and the area is very very dry.
    Erich Visser
    2015 Suzuki GV 2.4 m/t 40mm lift and Bash Plates
    2015 Off Trax Outplay Trailer
    2006 Mercedes A170 (Swambo's)
    1996 Mazda Magnum 2600 D/C 4x4 (Sold)
  16. #14
    Sep 2016
    Perth
    Thanked: 266
    Quote Originally Posted by ErichV View Post
    We were there in April 2017 and there was plenty of water. Four weeks Later in Late May we were at Kunene River camp and and The river levels has dropped dramatically and the falls were a trickle until they opened the dam. All you can do is keep an eye out for therian and check ith the lodge. Have a nice sty.
  17. #15
    Thanked: 3274
    Where does the Kunene get fed from if not by water let out of the power station and rain in Angola?
    We know there has been little rain in Angola and none recently. So if no water is let out from the power station for a couple of days and the river is already very low (as Erwin's photo suggests) then it is quite plausible that Epupa can possibly be dry or very near dry.
    I guess it can vary from a trickle to a strong trickle from week to week, again depending on water from Ruacana and how empty the river is when the water is released.
    But it will most definitely not soon look like oom Jan's photo.
  18. #16
    Okahandja, Windhoek
    Thanked: 729
    Quote Originally Posted by janseekat View Post
    Or Ruacana is not supplying enough. With the 4 turbines running we export as far as I know, but 34 cub m it will not be possible either.
    Johan Kriel
    LC's and Echo Chobe
  19. #17
    Okahandja, Windhoek
    Thanked: 729
    The sluice gates damaged by the RSA forces to get a continues through flow the Calueque dam has been repaired to be able to control the flow through Ruacana, in order to supply the varying demand. Its also the cheapest electricity thus used maximal. For years there were only 2 turbines, which could only work if the river was in flood. Now I think they have 4 turbines.
    Thus most of the flow now in the Kunene below Rauacan is from the Calugue dam for the Ruacana power station. Ruacana falls only have water in case of a flood that overflowing the dams. There is also dam on top of the Ruacana falls to canal the water away through the turbines.
    Johan Kriel
    LC's and Echo Chobe
  20. #18
    Aug 2019
    Netherlands
    Thanks to everyone for the answers. I guess we'll have to wait untill October then to find out what it will be like. I understand there will not be the most water then, but there's still a difference in water level possible that makes if it's worth it or not.
  21. #19
    Mar 2007
    Thanked: 708
    This is what Epupa Falls looked like on 24 August 2019 (2 weeks ago)
    Johan
ID:	540013   Click image for larger version.
    2011 Daihatsu Terios 4x4
  22. The Following 4 Users Say Thank You to J Snyman For This Useful Post:
