Ford & Mazda Everest 3.2 Auto 4x4 Speedo Under Read
Results 1 to 8 of 8
    Default Everest 3.2 Auto 4x4 Speedo Under Read
    Noticed something strange Today would set Cruise Control to 80 but on Waze/GPS it shows 89-90 kph.. same for 90/100, 100/110 etc..
    Itís a 2018 15k km on the ODO..
    Stock Factory Tyres & Rims..
    265/60R18
    2005 Ford Ranger SuperCab XLT 4000V6 Manual 5 Speed 4x4
    Petri
    1997 Ford Explorer XLT 4.0 L SOHC V6 Auto AWD 4x4
    Pieter
    2013 Audi Q5 2.0 TDi S-Tronic Quattro
    Daily Drive
    Default Re: Everest 3.2 Auto 4x4 Speedo Under Read
    That means that the 15k km in the odometer may not be true either ...
    Gauteng
    Thanked: 919
    My Everest speedo had a 6-7km/h under GPS reading.
    Tyres were 265/65/17
    Quote Originally Posted by Therackermann View Post
    Could be but as far as i know the odo works of gearbox gears, which isnít affected by speedo being out..
    Also compared Tank2Tank fuel consumption which was 11.4 km/l vs 8.5 km/l on obc but trip seems accurate if compared with gps tracker..
    Petri
    Pieter
    Daily Drive
    Jan 2014
    Thanked: 472
    Sjo, that IS very strange. I have never heard of a vehicle on standard tyres where the speedo would be lower than the GPS. I have replaced the 65 profile tyres on my Ranger to 70 profile and that has brought the speedo and GPS in sync almost 100%. I suppose going even bigger will make the speedo reading to be lower than GPS reading.
    Maybe have it checked out by Ford, for what it is worth.
    PS. I don't have speed cruise, but if I remember the Ranger I drove for while with it, you will get an electronic display that will indicate what you set the speed cruise to. So when you set it to 80, does your speedo also indicate 80. That is now on a flat stretch of road. Obviously it will speed up a bit or slow down a bit as the gradient changes before it starts to correct itself.
    Thanked: 1012
    My Honda CRV speedo is 5% out from the GPS but the odometer is spot on, stock rims and tyre.
    Quote Originally Posted by Daniek View Post
    Yup Digital Speedo shows same figure as clocks, tested on Flat stretch twice between WAFB and Zwartkops.
    Plan is to go 265/65R18 when Std Contis wear out, how many kms do they get on avg ?
    As according to calc they actually smaller overall than stock R17
    265/60R18 vs 265/65R18
    Petri
    Pieter
    Daily Drive
    Thanked: 59
    Quote Originally Posted by BigBear View Post
    Only on Waze?
    I have the same problem, and I think it is Waze. At130km/h speedo speed, the Garmin GPS (traditional GPS) shows 125km/h but Waze shows 145km/h. When I use the built-in GPS & maps, then it reads same as the traditional GPS. I think Waze had an update that screws with their speedo.
    Tough times don't last, but tough men do
    2019 Ford Everest 3.2 Ltd
    2018 BMW R1200 GSA LC
    2016 Conqueror Companion
