Emergency Fire Starting - Page 2
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 40 of 69
    Jul 2015
    Kilkivan
    Thanked: 216
    Default Re: Emergency Fire Starting
    Powder pool chlorine and brake fluid do the trick as well. One usually has the latter in the car for topping up so its easy to carry a plastic jar of the chlorine.
    Matches these days are crap. (In oz anyway) When I was younger we used to dip the heads of the wax Vestas in a bit of molten candle wax. That waterproofed the whole thing. They would strike on anything abrasive. Shame they disapeared.
    I have not tried this but I read to mix equal parts Condys Crystals (Potassium Permanganate) and sugar together. Put under fire kindling and grind the mix with a stick. Apparently the friction starts the reaction to get the fire going.
    King Williams Town
    Thanked: 869
    Stay away from chloride and brake fluid. The chlorine fumes when burning will burn your lungs and burn your eyes badly...... and if you are a 13 year old doing this experiment, your butt would burn when mom catches you doing this.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  3. The Following 2 Users Say Thank You to hunter26 For This Useful Post:
  4. #23
    Paarl
    Thanked: 189
    As mens nou 2 goed wil meng vir n vuur... wat van chloor en brakefluid... altwee baie maklik bekombaar.
    Werk soos 'n bom!
  5. #24
    Ruimsig
    Thanked: 2254
    For friction fire lighting, the Rudiger Roll works quite well using only cotton wool and ash.
    https://www.youtube.com/watch?v=uinB3dqXUaI
  6. #25
    Thanked: 781
    if you like this sort of stuff, you will enjoy Wallace.
    http://mountainmanseries.co.za/wallacevosloo.html
  7. #26
    Polokwane
    Thanked: 462
    Quote Originally Posted by LouisF View Post
    Werk soos 'n bom!
    Werk soos 'n bom!
    Ja dit maak tot 'n seun se boude warm!
  8. The Following User Says Thank You to DC Polokwane For This Useful Post:
  9. #27
    Langs die rivier, op n berg
    Thanked: 2437
    Werk soos 'n bom!
    Quote Originally Posted by DC Polokwane View Post
    Werk soos 'n bom!
    Of, brand ALLE facial hair af, sny jou slagaar in voorarm af, sny helfde van jou senings in voorarm af. Skiet n gat dwars deur jou bobeen. Sny jou kuitspier middel deur, sodat jou kuitspier los by jou been uit hang...
    Moet nie vra hoe ek weet nie...
  10. The Following 3 Users Say Thank You to Reenen For This Useful Post:
  11. #28
    Ruimsig
    Thanked: 2254
    I dont advocate the carrying or use of volatile chemicals to produce fire. The two items I posted about have a number of other independent uses in the outdoors, that when mixed, wont rapidly expand and explode but will produce an intense heat to assist with fire lighting or starting particularly if tinder is wet or no other means of ignition is available or practical to use.
  12. The Following User Says Thank You to Estee For This Useful Post:
  13. #29
    Thanked: 2437
    So ook chloor... water ontsmetting
    So ook brakefluid... jy gaan nie ry sonder dit
  14. #30
    King Williams Town
    Thanked: 869
    Estee, have you ever tried or used one of those magafty things that uses hot compressed air to produce a burning ember on cloth. It looks like a syringe without a top opening. You toss in a piece of cloth on top of the plunger, insert plunger into a tube and hit plunger hard causing the air to heat up where the cloth is situated thus igniting the cloth.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  15. The Following User Says Thank You to hunter26 For This Useful Post:
  16. #31
    Ruimsig
    Thanked: 2254
    A fire piston, yes. I have one made by Gavin Margrate who also made my Tonteldoos. You place a small piece of char cloth in a recess in the bottom of the piston and insert it into the cylinder and give it a quick and hard downward hit. The heat generated ignites the char cloth in the piston which you then use as a match
  17. The Following User Says Thank You to Estee For This Useful Post:
  18. #32
    Jan 2015
    Vredenburg
    Thanked: 928
    Will you show those two please?
  19. #33
    Sep 2011
    Potch/Brits
    Thanked: 580
    Never heard of these.
    Estee please show your tonteldoos and piston
  20. The Following User Says Thank You to carlp For This Useful Post:
  21. #34
    Ruimsig
    Thanked: 2254
    Items on left are the fire piston cylinder and piston itself. Second right is Tomteldoos and last right is my fire steel
  22. The Following 2 Users Say Thank You to Estee For This Useful Post:
  23. #35
    Ruimsig
    Thanked: 2254
    All well used items. :-)
  24. The Following 3 Users Say Thank You to Estee For This Useful Post:
  25. #36
    Ruimsig
    Thanked: 2254
    Fire piston assembled ready to use and the char cloth in the top of the Tonteldoos and then the Tonteldoos itself
  26. The Following 2 Users Say Thank You to Estee For This Useful Post:
  27. #37
    Ruimsig
    Thanked: 2254
    Quote Originally Posted by carlp View Post
    Are you being rude? I would get suspended
  28. The Following 2 Users Say Thank You to Estee For This Useful Post:
  29. #38
    Thanked: 232
    Thanks. Still can't see the writing. Maybe you could have just written Clicks?
    Click's and just about all pharmacies stock it....Kondi's crystal's also works very well to stop bleeding on small cut's.
    Cruiser 76 V8
    Disco 4 XS
  30. The Following 3 Users Say Thank You to wildhunter For This Useful Post:
  31. #39
    King Williams Town
    Thanked: 869
    How does that flint and steel work if I may ask. Can you buy it readily.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  32. #40
    Sep 2011
    Potch/Brits
    Thanked: 580
    Hhahhaa. Some sentences just can be read both ways
  33. The Following User Says Thank You to carlp For This Useful Post:
