Results 1 to 15 of 15
Hybrid View
    Bethlehem
    Thanked: 6215
    Default Prad0 150 V6 Waterpumo - When/What to look for??
    Keep forgetting to ask.
    I've read on numerous Threads that the V6 Prado (120/150) may have issues with water pumps.
    1) When is this usually happening, meaning at what km's, or difficult to tell??
    2) What are the warning signs/sounds/smells??
    3) What causes this issue, belts/coolant/gasket, or does it just happen, is it just a weak spot??
    4) Any preventative measures to take on this issue when servicing??
    Mine is a 2013 V6, mileage is around 125000 or so - havent driven it in a looooong time.
    THANKS8)8)
    Bethlehem
    Thanked: 6215
    Default Re: Prad0 150 V6 Waterpumo - When/What to look for??
    Mods.........please just rectify my spelling in the Header.
    Sorry and Thanks
    Jul 2009
    Thanked: 382
    You got a looooong way before you need to worry about that I think.... More close to 200 000km.
    I sold my 150 on 170 000km without any problems and original waterpump.
    Francois
  4. The Following User Says Thank You to Francois111 For This Useful Post:
    Bethlehem
    Thanked: 6215
    But are there any early warning signs?? Leaks or whatever?? Maybe a coolant smell??
    I need to know this anyway, if maybe looking to buy another in as stock, etc etc.
    Robertson/ Larissa, Greece
    Thanked: 5479
    Petri you can usually see some antifreeze streaks below the waterpump.
    Someone else posted here not so long ago a bulletin or something from Toyota where it was stated that many waterpumps are replaced while the problem was actually something else. Can't remember what eaxctly.
  7. The Following User Says Thank You to Francois Theron For This Useful Post:
    Sep 2010
    Langebaan
    Thanked: 15
    My hilux the pump was replaced at 150000 km and the 2014 prado at 42000 km. JY beter hom maar dophou Petri.
  9. The Following User Says Thank You to gerrit fourie For This Useful Post:
  10. #7
    Bethlehem
    Thanked: 6215
    Quote Originally Posted by gerrit fourie View Post
    Dis wat ek wil weet..........wat hou mens dop?? Waarsku hy jou of nie??
  11. #8
    Henties
    Thanked: 2169
    Thread you are referring to might be this one:
    https://www.4x4community.co.za/forum...mps?highlight=
    Keep in mind that the bulletin is from 2007, so it should include the 1GR-FE single VVTi engine in the Prado 120. There were concerns raised that it might not be applicable to the dual VVTi engine in the Prado 150. The two engines have different coolant pumps according to the part numbers, however I'm not sure whether they differ technically or whether it's essentially the same pump in a different housing.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser -sold-
  12. The Following 3 Users Say Thank You to HugoNotte For This Useful Post:
  13. #9
    Lonehill
    Thanked: 36
    Mate of mine just changed his at 220k km, and it was leaking top and bottom. Heís not sure if itís been changed before.
    Problem is you canít see it leaking.
    Itís a R4.5k job(at an indie) that I would do every 100k km just be safe. And do the serpentine belt at the same time. And then you have no maths problems to figure out when itís time to change, do it 100k, 200k, 300k km etc
    Itís 4.5c per km insurance well spent.
    D
    2014 Jeep Grand Cherokee Limited 3.6 Pentastar
    1967 MGB GT
  14. The Following 2 Users Say Thank You to hercules_za For This Useful Post:
  15. #10
    joburg
    Thanked: 641
    I'm at 147kkm and no signs of leaks and no intention to replace yet and I'm a Toyota trained makkie so relax and enjoy the car, perhaps use it a bit more?
  16. #11
    RICHARDSBAAI
    Thanked: 40
    My SIL have a 2006 Prado 120, waterpump is fine but for some reason lost waterthrough the head gasket , vehicle currently on about 280K , I think maybe previous owner replaced waterpump but damage was done already.
    Shalom
    Julius Truter
    Walk by FAITH not by sight
    2014 Pathfinder 2.5 LE
    Snomaster 60L
    Overlander Trailer
  17. #12
    Bethlehem
    Thanked: 6215
    Quote Originally Posted by sparewheel View Post
    .........Did Bethlehem - Welkom - Potch and back this weekend, spare. Goes like a bomb!! And consumption is a HUGE surprise for a V6.......!!!8)
    Anyway, thanks again Guys.
    Seems that this (potential) hassle is more on the 120 then??
    I'll just regularly keep an eye on water levels and leakage signs on the water pump.
  18. #13
    Feb 2013
    Thanked: 1977
    They tend to go around 180 to 200k km if I recall and it just happens. Best to do water pump and thermostat as preventative maintenance.
    "The man who does not read has no advantage over the man who cannot read" - Not Mark Twain
  19. The Following User Says Thank You to bigboy529 For This Useful Post:
