DIY Fortuner Drawer
Results 1 to 8 of 8
    Krugersdorp
    Thanked: 26
    Default DIY Fortuner Drawer
    I built this drawer for my Fortuner, pitty the slides is so heavy, but other than that it worked out well. On the one side next to the fridge I placed a volt meter, two amp meters (10amp max so one for the fridge and one for all the plugs) and the various plugs and USB ports.
    I don't have a pic of it, underneath the bottom crate drawer is a friction slide for a plank to use as a prep table.
ID:	535213   Click image for larger version.
ID:	535214   Click image for larger version.
ID:	535215   Click image for larger version.
ID:	535216   Click image for larger version.
ID:	535217   Click image for larger version.
ID:	535218   Click image for larger version.
ID:	535219   Click image for larger version.
ID:	535221   Click image for larger version.
  2. The Following 4 Users Say Thank You to WayneSchalk For This Useful Post:
    May 2017
    Thanked: 20
    Default Re: DIY Fortuner Drawer
    Very smart, like the connections and readings on the left. good idea 8)
    PATROL 4.8 GRX
    Vredenburg
    Thanked: 28
    Hi WayneSchalk,
    Any idea what the weight is of the system without the fridge & boxes? Looks good!
    Regards,
    M
    Marius Swart
    (Blackie)
    2010 Land Rover Freelander 2 Td4 SE
    1997 Opel Corsa Bakkie 1.3i
    Krugersdorp
    Thanked: 26
    Quote Originally Posted by Blackie KB 300 View Post
    Hi WayneSchalk,
    Regards,
    M
    Not quite sure, its based of the design of a Frontrunner drawer, my buddy has that and we built it to that dimensions. I see on their website it weighs 96kg, but on mine I cut out as much as I could, the cutouts weighed 18kg. So I'm sure mine weighs less, I'll see if I can weigh it.
    Nov 2014
    Thanked: 1766
    Quote Originally Posted by WayneSchalk View Post
    Very nice. I did something very similar but with aluminium tubing and maizy connectors. Also didnít put a top over the fridge so that we could get to it while driving.
    How did you anchor it. I used aluminium braces bolted to the seat mounts - didnít want to drill holes anywhere.
    Smaak the volt meter, itís cool to be able to accurately monitor batter levels
    Love your neighbour. Thatís about it, itíll be the world we want.
    Krugersdorp
    Thanked: 26
    Quote Originally Posted by Gungets Tuft View Post
    Very nice. I did something very similar but with aluminium tubing and maizy connectors. Also didn’t put a top over the fridge so that we could get to it while driving.
    How did you anchor it. I used aluminium braces bolted to the seat mounts - didn’t want to drill holes anywhere.
    Smaak the volt meter, it’s cool to be able to accurately monitor batter levels
    Thanks,
    Yes I used 5mm flatbar that I cut to about 80mm and drilled two holes into that, I then bolted it to the seat mounts. from there I have a ratchet strap to a tie down on the sides of the drawer.
  8. The Following User Says Thank You to WayneSchalk For This Useful Post:
    Nov 2014
    Thanked: 1766
    Iím a bit challenged with making stuff so if it could not be done with a hacksaw and pop rivets Iím lost.
ID:	535234   Click image for larger version.
ID:	535235   Click image for larger version.
ID:	535236   Click image for larger version.
  10. The Following User Says Thank You to Gungets Tuft For This Useful Post:
  11. #8
    Krugersdorp
    Thanked: 26
    Here is a pick with the slides open.
ID:	535578   Click image for larger version.
