Grand Vitara - service ESP system message
Results 1 to 11 of 11
    Jan 2019
    Thanked: 18
    Default Grand Vitara - service ESP system message
    Hi everyone,
    I was wondering if any GV drivers out there have had a"Service ESP system" message popping up before? I've had it about three times now but when I turn the car off and start it again, the message is gone.
    Something to have checked out or just a bug?
    As always, thanks in advance!
    PJ
    Jan 2007
    Thanked: 310
    Default Re: Grand Vitara - service ESP system message
    That usually happens when the battery voltage is too low. Have the battery tested.
    Vic
  3. The Following User Says Thank You to saxj For This Useful Post:
    Apr 2014
    Thanked: 16
    I also get it from time to time. When the error was persistent, it was my passenger front speed sensor that was dirty. Currently I only get it when I switch the car on acc and leave it there. As soon as I start, it goes away.
  5. The Following User Says Thank You to iondb For This Useful Post:
    Jan 2019
    Thanked: 18
    Thanks guys! I thought it was probably something like that. I appreciate the help!
    Thanked: 58
    Got that for the first time end of December last year just as I was about to descend the Sani Pass. Was stationary, did the usual process of taking car into 4L. Car started beeping a lot as I started moving, with the last warning being that.
    Stopped, re-did the entire process again, the beeping stopped but the warning remained until the point I got switch off the car. Asked Suzuki about it in Jan when I took car for service and they gave me a response like "its just a tiny glitch I shouldn't worry about". Haven't had the message ever since.
    Still feel it was a weird thing to not consider as a serious thing but hey, I kinda remain relaxed about it.
    2014 Suzuki Grand Vitara 2.4 Auto
    2011 Landrover Defender 110 Puma SW (sold)
    Thanked: 11
    A bit late, but agreed here. Finally replaced my battery with a 90Ah unit, and the message is gone forever now.
    Apr 2014
    Thanked: 16
    Quote Originally Posted by laserdash View Post
    Can you remember the make/model of the battery you chose?
    krugersdorp
    Thanked: 295
    for as long as alternator runs OK.
    Thanked: 11
    Quote Originally Posted by iondb View Post
    It is in my car, so I will go and have a look in a bit, and let you know.
  12. The Following User Says Thank You to laserdash For This Useful Post:
  13. #10
    Thanked: 11
    This is the battery I put in, it is Midas brand, as I didn't have much options. The battery was completely dead. Was a really good price also if I recall, something like R1300.00
    I only had to remove the plastic fitting at the bottom, otherwise it fits 100%.
  14. #11
    Apr 2014
    Thanked: 16
    Thanks for the info
