Alarm
Results 1 to 3 of 3
Thread: Alarm
    Sep 2013
    Ponta Do Oura
    Default Alarm
    Hello all.
    Any assistance will be greatly appreciated. When I park my 2013 isuzu in the sun and lock the vehicle about 20 minutes later the alarm goes off. In the shade no problem at all, obviously heat is the problem but how can I stop this? Many thanks.
    Sep 2010
    Default Re: Alarm
    I had the same issue. Check the wired connection of the door closed sensor. I opened mine, found the wires a bit loose. Tightened it and the problem went away.
    somerset west
    Default Re: Alarm
    A friend and I used to do clutch replacements as private work in Durban (MANY years ago)
    EVERY car we worked on had cockroaches under the flooring
    maybe car gets hot and insects get active (that is if the system has a motion detector)
