Canopy air vents for positive pressure
Results 1 to 19 of 19
    Bushveld
    Thanked: 27
    Question Canopy air vents for positive pressure
    Was looking around for some air vents or “scoops” for my canopy and found 4x4direct sell a few...
    https://4x4direct.co.za/538-air-vents-and-handles
    Not sure which would be better to get as I seem to accumulate dust from the rear door.
    Anyone here with experience with the vents? I don’t care about the price difference... just whichever one works best. They all seem easy to install.
    Okahandja, Windhoek
    Thanked: 711
    Default Re: Canopy air vents for positive pressure
    That bottom one of R640 works. https://4x4direct.co.za/air-vents-an...-canopies.html
    Did a 10 day trip with that one on my canopy in Moremei and Kwai. No dust even with no extra sealing of the load bin.
    Johan Kriel
    LC's and Echo Chobe
  3. The Following User Says Thank You to JLK For This Useful Post:
    Pennington
    Thanked: 117
    I also used the aluminum one. Closed day to day and seals well. Open on dirt roads to make a positive pressure inside the canopy. Also seal the tailgate as this also helps
    Nov 2006
    Thanked: 163
    I just open the sliding window next to the cab.
    Bostoe
  6. The Following User Says Thank You to bostoe For This Useful Post:
    Bushveld
    Thanked: 27
    Thanks, unfortunately I don’t have a sliding window on the Alu-Cab.
    Seems like the alu one is the one I’ll get.
    Melkbosstrand
    Thanked: 149
    I've got the alu one...
    just to note, even with the vent, if you don't seal the tailgate, you'll still get dust in the back
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  9. The Following User Says Thank You to BobMabena For This Useful Post:
  10. #7
    Feb 2013
    Strand
    Thanked: 59
    popup drain plug. Like the one you have in your bathroom sink. Easy to install, is made to be waterproof.
    I've done a few for friends and my previous 2 canopies.
    I always install it facing forward in one of the top corners.
    Will see if I can find a picture.
    Edit: Found some.
ID:	534361   Click image for larger version.
  11. The Following 10 Users Say Thank You to kenskind For This Useful Post:
  12. #8
    Tshwanetoria
    Thanked: 517
    Great Idea - will use it in Future.
    Cutting the square hole for the alu vent can be quite a pain. With the round drain plug, you simply use a hole cutter. And you can add additional ones if required.
    If you have a single (square one) you have to be careful of how you pack the stuff inside the canopy, so as to not block the opening or hinder airflow. Hence the fact that more than one small one may be of help.
    Also, be careful of critters seeking out the heat generated by you fridge, entering through the large hole. One again, the drain plug may prevent this.
  13. #9
    JHB
    Thanked: 69
    That drain plug idea is brilliant.
    I recall someone once posting a pic of a canopy with a snorkel.
    2012 Pajero Sport 3.2 A/T
    2010 jimny - sold what a 4x4
    2001 colt V6 - sold (drinker)
  14. #10
    Jun 2013
    Thanked: 2272
    @kenskind
    Thanks for that, this will probably work well on my trailer
    BMW R1200R
  15. #11
    Ellisras
    Thanked: 394
    @kenskind
    DRAIN PLUG - Brilliant - Now I know what to do to vent my trailer battery bay properly while camping and closing whole driving.....
    2000 Patrol GU 4.2D(onkey) beyond 830 000 km
  16. #12
    Jan 2014
    Thanked: 447
    I have also installed the popup alu one. It works like a dream. Got one at the local trailer parts place for a lot cheaper than R640.
  17. #13
    Cape Town, Plumstead
    Thanked: 84
    Like the others have said the popup alu one is the winner
    At first I tried the Badger circular one, the vents sit too close to the canopy body and don't seem to scoop up any air at all.
    Safe Diving
    Andy
    2013 Isuzu KB6 300 DC 4X4
    http://www.flickr.com/photos/andrews_underwater_images/
  18. #14
    Langebaan
    Thanked: 18
    Jip, this one works well. But try to seal your tailgate just so that less air escapes than what the scoop forces in. Positive pressure equals no dust...
  19. #15
    Thanked: 473
    Without hijacking/derailing the thread: Is there any vent one can use on a canvas canopy?
    ENJOY!!!
    Ettienne
    1980 Range Rover
    2002 Defender Td5 D/C
    2004 Disco Td5
  20. The Following User Says Thank You to EttiennedK For This Useful Post:
  21. #16
    Sep 2011
    Thanked: 21
    Just make a small window in front which you can close with velcrow, mine worked like that for many years and min dust in the back.
  22. The Following 2 Users Say Thank You to Lappies For This Useful Post:
  23. #17
    Malmesbury
    Thanked: 101
    thanks for the tip on the drain plug ,on gravel roads i just opened one of the side doors towards the passenger side latched the lock back and that did the trick .
    my canopy does not have a slide window in the front ,but i am going to install the plug now,why it is not mensioned before
    Colt clubcab 2.8tdi 4x4 2005
    Ford Fiesta 1.4i (SWAMBO]
    opel corsa 1.7 dti 2006
  24. #18
    Wartburg
    Thanked: 1017
    On my aluminium defender canopy, i drilled a large hole (+-80mm) on the front left and right corners. A box was then riveted over this hole both on the front and inside. The bottom of the box on the outside/front was open, and top of the inside box was also open. This prevented rain from entering. Very cheap to make,
  25. #19
    Sep 2018
    Thanked: 60
    Hi all
    This thread is a good example of why I love this forum.
    I had issues with dust in the canopy and until I read this thread, it hadn't occured to me that I could do something about it.
    Thank you all!
    Here is what I did:
    Drilled a 40mm hole on each side of the canopy at the front
    Inserted 40mm compression type tank adaptors as used in JoJo tanks
    Hand tightened 40mm tank plugs
    Cost: R110 and 20 minutes.
ID:	535704   Click image for larger version.
ID:	535707   Click image for larger version.
  26. The Following User Says Thank You to Lxv For This Useful Post:
