VW T5.1 Coolant Leak
Results 1 to 15 of 15
    Jul 2019
    Helmeringhausen
    Question VW T5.1 Coolant Leak
    Hi everyone,
    I recently purchased a late 2010 VW Caravelle & after a few days i’ve had quite a significant amount of coolant leaking from what looks to be some sort of crack from an unknown part of the engine (mind you my general knowledge of these fancy engines isn’t very high compared to old plaas cruisers) I was hoping some old VW T5 cracks could help me out. See attached pictures below. Greetings from South-West!
Name:	top engine view.jpg
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    Default Re: VW T5.1 Coolant Leak
    https://volkswagen.7zap.com/en/za/tr.../115-115080/#2
    part of the EGR system. Does not appear to be available loose.
    Options is the entire unit - I know goldwagen sells them for around R15k or swop the entire assembly for the amarok version minus those parts and bypass the EGR which will then also need coding to shut it up.
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
  3. The Following User Says Thank You to Stephan van Tonder For This Useful Post:
    Nigel
    Thanked: 2310
    Not sure if this will be of any help, but I have fixed things with normal stretch bandage, soaked in polyurathane. Soak the bandage and wrap it up. Just properly clean first.
    Uniglide
    +27 zero eight 2 four 95 9252
    Jul 2019
    Helmeringhausen
    I have indeed also come up with a “plaas-plan” in the meantime. Chucked some gasket maker around the unit, let it dry overnight, flushed & refilled coolant & it seems to have done the job so far... been driving for some odd 100 k’s with no leak in sight! Until i can get to a VW garage which in our parts is a rare sight as the closest one is only in our capital Windhoek..
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    you will have a little cry in the back corner of your bus as soon as you let VW quote on that repair.
    Jul 2019
    Helmeringhausen
    & a little cry in the back corner of the bus did happen.. I ended up replacing the entire EGR unit, for a mere 30k... its idling quite nicely now but the coolant level in the bottle is still dropping & rising (depending on how much pressure i put on the engine) I do hope this time its just the bottlecap thats faulty. Going to replace it soon.
    For how beautiful this vehicle handles the roads im starting to think the heat of the Namib is getting to it... anyone else have problems with their Bus overheating when driving in warmer climates (say 38 degrees & higher) ?
    • 2010 VW T5.1 / BiTd 4Motion
    • Farm Landsberg, Helmeringhausen
    • Namib Desert
    Sep 2010
    Springbokvlakte
    Thanked: 19
    Quote Originally Posted by Südwester View Post
    Yes! Especially when towing. I'm considering an intercooler upgrade in the near future.
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    an upgraded intercooler will not give you noticibly lower water temps.
    Cape Town Southern Suburbs
    Thanked: 1131
    What kind of polyurethane do you use with the bandage?
    Sep 2010
    Springbokvlakte
    Thanked: 19
    What will?
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    more radiator, using less power..
    Sometimes using a different gear and or slowing down just 10 km/h might be enough.
    Jul 2019
    Helmeringhausen
    Quote Originally Posted by Stavats View Post
    Im glad im not the only one then! i haven't even dared to pull anything just yet! anything more than 110 km/h & the coolant level drops & then shoots up and pisses out of the overflow of the coolant bottle & the temp gauge goes up to about 115/120 degrees.. take my foot of the pedal and gauge comes back to 90 degrees in 10 - 15 seconds..
    Had a CO test done on it which came back negative. Then had it pressure tested a week ago & the water flange (connected to the EGR unit) had a leak... got that replaced but still the same issue persists..
    new coolant bottle & bottle cap is coming this week.. I hope this will fix the issue..
    • Namib Desert
    Sep 2010
    Springbokvlakte
    Thanked: 19
    I'm getting scared of saying anything on this forum. A week after my post a got a "check coolant" warning. Checked and found oil in the expansion bottle. Arranged a rollback and sent it to a specialist in Centurion that same day.
    Waiting for the final verdict, but thus far it's costing me an oil cooler, head gasket and thermostat housing.
  15. #14
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    Very often it is just the heat exchanger and always start there first before going for the head gasket solution.
  16. #15
    Jul 2019
    Helmeringhausen
    Post Re: VW T5.1 Coolant Leak
    Unfortunately the CFCA engines are very well known for their self deconstructing behaviors; mostly due to a known faulty EGR unit with earlier year models...
    im following a very interesting and active group on FB : https://www.facebook.com/groups/vwcf...vity&ref=notif
    & like Stephan said its always wise to look at the cheaper options first.. after having spend nearly 50k on my coolant leak & finding out it can be due to 100's of different reasons, im going to live by those words..
    • Namib Desert
