Tyre rotation when one set has tyre pull
Results 1 to 2 of 2
    May 2017
    Jhb
    Default Tyre rotation when one set has tyre pull
    Hi All
    I'm due for an alignment and rotation.
    Problem is that my two tyres on the rear of my vehicle give me slight tyre pull when they're on the front.
    They still have lots of tread so not replacing them.
    Should I just not rotate? or swap the tyres left to right?
    Feb 2016
    Paarl
    Default Re: Tyre rotation when one set has tyre pull
    Quote Originally Posted by Shwam View Post
    Hi All
    Rotate as per normal and see what they do. A lot of times the tyre 'settles' and don't cause pulling on the front again. Rotate first, then do alignment. Sometimes changing tyres can skew the steering wheel.
    1996 Discovery 1 (SOLD)
    2001 Mercedes C180 (SOLD)
    2012 Nissan Xtrail 2.0 (Weekend Wagon)
    2010 Kia Sedona 2.9Crdi (Written off)
