Saving the crank battery
Results 1 to 14 of 14
    Jun 2013
    Thanked: 2410
    Default Saving the crank battery
    My poor Pajero often gets ignored and can stand for a week without being started. I often hook up a trickle charger but this involves a long wire from the house. My mind has started to think about a solar charger. The Pajero sits under a car port so I have a roof that can take a small panel and a post that can accommodate the wiring.
    What do guys think about a small 30W panel and a controller
    I would need 13.8 V for a float charge
    Would it do the job ?
    BMW R1200R
    Barberton
    Thanked: 935
    Default Re: Saving the crank battery
    A quick internet search suggests an outlay of about R1,000.
    Cancel your gym contract and roll out that wire every now and then for exercise.
    Jun 2013
    Thanked: 2410
    If I was not fat, then I would be unpopular.
    I do know that I have some losses on the system.
    Tracker unit
    Dual battery system, if I leave this on the meter, voltage display and controller all will use a little bit and draw that battery down too.
    I am after all thinking of the well being of my prized possession.
    BMW R1200R
    Mar 2017
    Okahandja
    Thanked: 604
    Panel and regulator should do it. 30 or 40watt 18v panel and regulator. Victron blue solat pwm. Should be about 1000.00
  5. The Following User Says Thank You to Erwin Schimper For This Useful Post:
    Jun 2013
    Thanked: 2410
    Quote Originally Posted by Erwin Schimper View Post
    Which is about what I would pay for a half decent charger anyway.
    I wonder if enough would come in to open that solenoid on the NL battery pack. hmmm
    BMW R1200R
    Jul 2007
    Putfontein, Benoni
    Thanked: 1970
    Just unplug the controller?.
    Audi A6 Avant - 2005 - 3l TDi Quattro - my daily
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
    Thanked: 137
    "The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts" : Bertrand Russell
    2014 Nissan Navara 2.5 4x2
    1995 Nissan Sani 3.0 V6 4x4
  9. The Following User Says Thank You to staalwol For This Useful Post:
    Okahandja, Windhoek
    Thanked: 718
    Got two vehicles parked on a 30 watt panel and charger.
    NL will open if the battery is sufficient charged.
    Johan Kriel
    LC's and Echo Chobe
  11. The Following 2 Users Say Thank You to JLK For This Useful Post:
  12. #9
    Apr 2016
    Thanked: 49
    What you need is a smart charger that can be left permanently connected to your battery.
    I saw this one in Cash Converters (see the bargain price on the top)
    If you talk to me nicely (or cross my palm with silver) I'll tell where it is..
  13. #10
    Swakop
    Thanked: 465
    disconnect the battery?
    "Meerkat"
    Namboyz
    modded 02' 105 series 4.5efi (big wheeled petrol thief)
  14. #11
    May 2016
    Jozi
    Thanked: 8
    Quote Originally Posted by AboutAfrica View Post
    ECU and tracker won't like this if you doing it regularly.
  15. #12
    Mar 2007
    Thanked: 683
    You can always bridge the solenoid with a length of wire that has a, say 10 A, fuse in. Then the power will flow to the aux battery as well. You then remove the fuse when it is not needed. If you forget to remove it, it will blow when you start the vehicle. Did this for many years ......
    Johan 😎
    2011 Daihatsu Terios 4x4
  16. The Following User Says Thank You to J Snyman For This Useful Post:
  17. #13
    Friemersheim, Southern Cape
    Thanked: 2069
    Quote Originally Posted by J Snyman View Post
    Johan 😎
    The words of wisdom...
  18. #14
    Jun 2013
    Thanked: 2410
    Just for the sake of experimentation,
    Pajtu has been standing this week so I wanted to give the battery a bit of charge. I have a small aux box, 50 amp Deltec wet cell. This is not my main aux, just a small one for charging, vape machines, cell phones Sat phone, camera batteries and did I mention Vape machine batteries. As it so happens I also have a wet cell Deltec as my crank battery. HMMM
    I have two 16 mm welding cables running to the back of the car from the crank which plugs into my NL power pack, so I unplug this.
    I then plug this into the aux box on a direct to battery connection
    The aux box has a PWM controller which I then plug the solar panel into.
    Instant success, the early morning sun is already giving 14.2 from the semi flex panel and I can see this going to both batteries
    BMW R1200R
  19. The Following User Says Thank You to Stranger For This Useful Post:
