Dust inside 2019 Toyota Hilux Bakkie
Results 1 to 20 of 20
    Sep 2018
    Default Dust inside 2019 Toyota Hilux Bakkie
    I have a new 2019 Toyota Hilux Bakkie, with a canopy
    The load area gets very dusty. If I look towards the tailgate from the driver area, there are large areas of light on either side of the tailgate. So there is no seal between the tailgate and the side of the vehicle.
    Is this a design fault?
    How can I seal this area?
    Thanks in advance
    Skelmbos
    Thanked: 39
    Default Re: Dust inside 2019 Toyota Hilux Bakkie
    Not a design fault - all bakkies have the same issue (the space between tailgate and bodywork being about a finger-thickness width) which is intentional due to body movements (twist/bend/etc) and loose components (ie, tailgate).
    Luckily it is quite easy to fix it by simply buying some self-adhesive rubber strips and paste it around the edges. You can see more about it here (in another part of the forum):
    https://www.4x4community.co.za/forum...te-seal-for-T6
    Apr 2018
    Thanked: 130
    Yes all bakkies that I've ever been have this problem. Three ways to solve this:
    1.buy the rubber seal tape like Groenhoender says.
    2. open your canopy window when driving on dirt road.
    3. Buy bakkie dust seal kit
    2017 Isuzu KB 300 4X4 Auto (current)
    2008 Isuzu KB 300 4X4 manual (current)
    2017 Isuzu kB 250 (sold)
    2006 Isuzu KB300 (sold)
    2002 Isuzu Kb 260 petrol (sold)
    Feb 2012
    Sandton
    Thanked: 23
    Get the bakkie dust seal kit. Finnished and klaar.
    2011 Toyota Land Cruiser 76 S/W
    Jan 2019
    Otjiwarongo
    Thanked: 14
    Dust Seal kit is available from Toyota D/C and X/Cab P/number PZN76DD200 +/- R640.00
    Thanked: 913
    What is in the dust seal kit, over priced foam sealing tape?
    Thanked: 367
    Quote Originally Posted by TimTDP View Post
    Thanks in advance
    Dust happens in ALL bakkies when you go on a dirt road ..Get a 4x4 workshop to put an anti dust kit in ..mine cost R 2000 about and stops about 40% of the dust = waste of money ..Live with it like Defender drivers live with oil leaks
    Wartburg
    Thanked: 1014
    Quote Originally Posted by Peter Betts View Post
    I had a Defender single cab, with canopy on the back. The cab had very little dust. The back even less. I sealed the tailgate, and had water proof openings on either side of the forward facing canopy wall, which created positive pressure in the back.
    Skelmbos
    Thanked: 39
    R2 000!?! Why so much?
    Also sounds they did not install it properly.
    Should be around R350-450 for kit.
    Pretty much easy to DIY too, with some slight effort here and there to trim it.
    Took me about 15-20min.
    Jan 2017
    Thanked: 86
    Also feel around the top inside edge of the load bin you may find openings, shove sponges in there, it helps a lot to keep dust out and if you keep the canopy window open a bit you will get very little dust. My opinion those tail gate seals do very little.
  11. The Following User Says Thank You to Fishing1 For This Useful Post:
    Thanked: 552
    What is wrong with a tonneau cover?
    HeinrichC
    Kathu
    Thanked: 2020
    This is the solution. When I build the canopy for my 79 Cruiser I made two forward facing openings to pressurise it. Tailgate not sealed yet but no dust enters the canopy.
    Nov 2018
    Ruaha National Park
    Thanked: 87
    Cool Re: Dust inside 2019 Toyota Hilux Bakkie
    Hey we also suck dust don't discriminate
    1962 88" Series 2a
    1996 300 TDI Defender 110
    1997 2.8i Defender 110
    Toyota Hi Lux D4D
    Only dead fish go with the flow
  15. #14
    Thanked: 1051
    Check THIS thread I posted with what I did back in 2012 on the Vigo Hilux I had. I'm sure this can be applied to newer models as well. Dust is evil...it will find its way in. This mod made the load box about 98% dust proof.
    Toyota FJ Cruiser
    BMW F800GS
    When in doubt, paint it black
  16. #15
    PE & North Africa
    Thanked: 261
    Quote Originally Posted by Fishing1 View Post
    Jip, I bought those small spong/rubber patches that have adhesive on them you use for furniture on floors to prevent damage. They come in various sizes and shapes.
    Clean the inside of the side rails of the loadbin well, and simply apply a patch over each small hole.
    There are quite a few each side.
    Grumbles
    2008 Fortuner 3.0 D-4D 4x4 "Sushi the Tuna"
    2018 Baobab 4 - B1543 "Nala"
    Bacon fact #16 - Bacon is Healthier than Crystal Meth!
  17. #16
    Skelmbos
    Thanked: 39
    Quote Originally Posted by HeinrichC View Post
    Nothing wrong with it - it is just a soft-cover version of a canopy, with just less height, and no means of safe-keeping posessions due to lack of security options. Unless one goes for a roller-cover (with a lock).
    However, both soft tonneau and roller-cover also does not keep load bin dustfree as the problem lies with the tail gate and the spacing around it.
  18. #17
    Thanked: 552
    Apologies I did not realise the dust is a problem with the canopy on
    This is a concern and the manufacturer of the vehicle and the canopy should offer solutions for sealing prior fitting a canopy.
    I would guess the air turbulence (Sometimes referred to as dirty air) behind the vehicle causes the dust to be sucked into the cavities mentioned in this thread.
    Maybe canopy design is the culprit. Perhaps a lip on top of the canopy (wing) and mud flaps behind the wheels might help?
    HeinrichC
  19. #18
    Jun 2016
    Potchefstroom
    Thanked: 18
    Wet towel at tailgate gaps did the trick for many trips.
  20. #19
    Jul 2007
    Malmesbury
    I have almost no dust by just opening the canopy window. Unfortunately have to remember to close it when it is raining.
  21. #20
    Jan 2019
    Otjiwarongo
    Thanked: 14
    This is the Toyota Kit
