Defender Hot 4 Cold Intercooler TD5
Results 1 to 9 of 9
    Dec 2015
    Ruimsig
    Thanked: 48
    Default Hot 4 Cold Intercooler TD5
    Hi Landy buddies!
    So, over the weekend, I have cleaned out my intercooler and saw that i have an aftermarket Hot 4 Cold cooler installed, is this better than the standard Land Rover one. Is there anyone else here using a Hot 4 Cold TD5 intercooler? Is it worth the upgrade to a bigger intercooler?
    thnaks
    Thanked: 13557
    Default Re: Hot 4 Cold Intercooler TD5
    It is considered an acceptable upgrade. So yes, it is better than the original.
    Dec 2015
    Ruimsig
    Thanked: 48
    thanks Jelo!
    must say my EGTs have never gone higher than 535. no remap or chip.
    basic mods done to my TD5:
    - Free flow exhaust
    - Torqetune silicone boost pipes
    - Madman to monitor the Storm!
    - Hot4Cold bigger intercooler
    - disco 1.2 ratio transfer case.
    Jun 2012
    Thanked: 14
    Quote Originally Posted by Louw26! View Post
    thanks Jelo!
    - Free flow exhaust
    What do they go for? I have a cirrus intercooler and experienced a good improvement throughout the rpm range.
    Must say a td5 with some breathing mods, intercooler and an optimized tune is a totally different beast.
    '99 TD5 Hardtop
    '99 TD Discovery 2 Auto
    It's a Land Rover thing... and I get it now 8)
    Fourways Gardens
    Thanked: 669
    Quote Originally Posted by louw78 View Post
    Between R3500 and R4000 for the Hot for Cold.
    Series III 88"
    Scout Nomad
    Dec 2015
    Ruimsig
    Thanked: 48
    The Hot4Cold retails around R5000 from the supplier. I was lucky to get one from a mate who sold his TD5
    my next mod on my TD5 will be to improve the air induction system. I have a mantec snorkel on but if you look into the engine bay, you will see there is a lot of bends and loops in the piping to the airbox. would like to use a 3" flexi hose to reroute the snorkel straight to the airbox.
    Thanked: 13557
    3" is too small IMHO
    Dec 2015
    Ruimsig
    Thanked: 48
    Hi Jelo,
    you recon? i haven't done research on this yet but i know a few Aussies are running 3" - 4" intakes straight to the TD5 airbox and then to the turbo aswell
    will be a fun weekend experiment to do
    Thanked: 13557
    Hi Jelo,
    I'd say 4" / 100mm at least. But talk to Dougal on the Ozzie forums, he knows his stuff.
  10. The Following User Says Thank You to jelo For This Useful Post:
