Power steering fluid
Results 1 to 9 of 9
    Feb 2017
    Pietermaritzburg
    Default Power steering fluid
    Hi guys
    My 2011 Hyundai Santa Fe power steering fluid level has dropped to the minimum level. Not sure how long its been at that level but presumably when it was serviced a few months back they would would have checked all fluids and topped up if necessary.
    I admit I do not look under the hood often, and have not noticed the fluid level drop before.
    Any Idea what fluid Hyundai uses. Should I be looking to flush the system and replace with fresh fluid? The fluid looks pretty dark through the reservoir.
    Should I be concerned that that the fluid level is down to the minimum level, I cannot see any leaks or spots on the floor.
    Appreciate all advice.
    Kavesh
    Feb 2017
    Pietermaritzburg
    Default Re: Power steering fluid
    I spoke to a mechanic at Hyundai and he suggested a flush. He also said that they use an expensive fluid but a good AFT made by Castrol should be fine.
    What do you guys think? I am a little nervous with his advice.
    Thanked: 14171
    Rather buy the Hyundai stuff at the dealer, then take it to any decent workshop and let them drain the old stuff and do the flush with ATF and then drain and put in the Hyundai steering fluid.
    I've seen cases where ATF doesn't work well with old seals and then you have a leak.
    Thanked: 1266
    This baffles me. I sent my Sorento for a service. One item is "top up fluids"... Why should fluids be topped up in a closed system. If fluid disappears then it must be leaking = problem right?
    Ruimsig
    Thanked: 11838
    Some systems like hydraulics ''sweat'' and degrade and over time, lowers fluid levels.
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Thanked: 14171
    yep, volatile components evaporate under pressure and heat
    Feb 2017
    Pietermaritzburg
    Thanks for the reply.
    I complex is the job? I am fairly handy around the car and tend try to do what I can to save a buck.
    If not a complex process I would like to attempt myself.
    How much fluid is required (I suppose Hyundai can confirm) and I would still need to flush with ATF? How much ATF would the flush require?
    Feb 2017
    Pietermaritzburg
    I agree, the invoice after a service always states all fluids were topped up, although I have never confirmed this myself.
    In my 8 years of owning the vehicles they have never advised that the power steering fluid should be flushed.
    Thanked: 14171
    Quote Originally Posted by kavesh View Post
    The magic of the interwebs
    https://www.google.com/search?q=repl...w=1707&bih=760
