Larger wheels on a Venter
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 54
    Thanked: 326
    Default Larger wheels on a Venter
    I hope the clever guys on here will be able to assist me with some advice, since we now only have SUV's in the family I was wondering about fitting larger tires to our 6ft Venter trailer. I don't intend to use it off road or in any other way than what the manufacturer intended it for, but was wondering if one can fit larger wheels and tires to raise it up off the ground so that the nose isn't always pointing up. That coupled with a little flag on the back should also help the little trailer be visible behind an SUV.
    Any recommendations? Is this a stupid idea? Input will be appreciated!
    '07 VW Touareg (T2) 3.0 V6 TDi (BKS), Air Suspension, Centre and Rear diff locks, DeCAT, 265-65R17 muds
  2. The Following User Says Thank You to Commander For This Useful Post:
  3. #2
    Jun 2008
    Terenure, Kemptonpark
    Thanked: 43
    Default Re: Larger wheels on a Venter
    What size currently? 10" or 13"?
  4. The Following User Says Thank You to LouisXander For This Useful Post:
  5. #3
    Paarl
    Thanked: 570
    If the wheel arches allow (sometimes they can be moved up, not sure about Venter) I reckon it's a great idea. If you fit all terrains you'll only change them every 5 years. A trailers nose pointing upwards is not good. The trailers vibration etc, if not completely full might cause load to shift to back of trailer...not good.
    https://youtu.be/6mW_gzdh6to
    1996 Discovery 1 (SOLD)
    2001 Mercedes C180 (Soon to be my eldest's car)
    2010 Kia Sedona 2.9Crdi (SWAMBO's ride)
  6. The Following 2 Users Say Thank You to Nitebob For This Useful Post:
  7. #4
    Thanked: 326
    Quote Originally Posted by LouisXander View Post
    I would have to check, but I suspect 10", it is an older model so the wheels are quite small.
    Quote Originally Posted by Nitebob View Post
    I am not sure if the arches could be moved without major work, it may be easier to extend the mount for the shackles, and basically lift the trailer a little. A nose up trailer is very much a problem, I have seen some of the clips on how unstable it gets and it is pretty scary.
    Thanks for the input so far, I will try and take a couple of photos over the weekend in order to get a better idea of what I am dealing with.
  8. #5
    Thanked: 81
    10 inch to 13 inch yes. Its relatively easy by welding in an extra saddle plate to act as a body lift. We do this often.
    13 to 14 inch is a lot harder and will need bigger mudguards. You also have to be careful with the high carrying capacity on these bigger tyres as the shaking and bouncing will destroy the body / chassis.
  9. The Following User Says Thank You to ozosborne For This Useful Post:
  10. #6
    Oct 2012
    Thanked: 58
    Isnít it easier to just get a drop plate for the SUV?
  11. The Following User Says Thank You to Gothan For This Useful Post:
  12. #7
    Jun 2017
    I upgraded mine from 10 to 13. Another tip the older venter trailers with 10" usually had a gvm of about 560kg. If that's the case your leaf springs are I think 4 blades and they sag quite a bit when loaded decreasing the height, what I did was put new leaf springs 900kg 7 or 8 blades, adds more stability and less rocking also increases the height about an inch and keeps it there when loaded. On the back of the d4d runs pretty level
  13. The Following 2 Users Say Thank You to shaggy For This Useful Post:
  14. #8
    Thanked: 326
    Thanks everyone! I don't intend on going huge, nothing close to matching the tire size on the actual car, just a bit bigger. Unfortunately all of our SUV's have detachable towbars so drop plates are out of the question.
    I have noticed the leaves sag quite a bit under load, so new leaf packs should be a viable option as well!
  15. #9
    May 2011
    Thanked: 397
    Careful, bigger wheels also tend to put higher loads on wheel bearings, so it may be best to get new axle with higher capacity bearings if conversion is any more than 10 to 13 inch.
    '89 LR 110 V8
  16. The Following User Says Thank You to Mike N For This Useful Post:
  17. #10
    Jan 2007
    Thanked: 270
    I've been wanting to do this for a while now on our quad bike trailer, as I often tow on gravel roads. I don't quite trust the little Lego wheels currently on there. However, I will have to replace the axle to get larger tyres on there.
    So instead of doing that, I just added a second spare wheel. Much cheaper.
  18. #11
    Jul 2007
    Putfontein, Benoni
    Thanked: 1966
    Drop plate is not an option when the towing vehicle is a touareg with a factory removable gooseneck....
    Audi A6 Avant - 2005 - 3l TDi Quattro - my daily
    Audi 90 Coupe - 1995 - 2.8l V6 quattro
    VW Touareg - 2005 - V10 TDi Awd
  19. The Following User Says Thank You to Stephan van Tonder For This Useful Post:
  20. #12
    King Williams Town
    Thanked: 839
    OK I have just bought a 7ft old venter trailer. It has 10 inch and will fit 13 inch wheels. To lift it I will be manufacturing a 100mm block using flat bar welded together to for a billiard. Then drill a hole in top to take the spring center bolt and weld a bolt at the bottom to locate into the axle plate, longer U bolts to cater for the extra height. No need to alter the suspension and mounting points with longer shackles etc.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  21. The Following User Says Thank You to hunter26 For This Useful Post:
  22. #13
    Lonehill, JHB
    Thanked: 798
    The diameter only goes up by about 50mm so a 25mm spacer is all you need, Hunter4x2. The U bolts are available from the Venter trailers website.
    http://www.ventertrailers.co.za/spar...-for-sale.aspx
    2014 Pajero 3.2DiD SWB
  23. The Following User Says Thank You to KurtG For This Useful Post:
  24. #14
    Klerksdorp
    Thanked: 341
    Had my Venterjie upgraded from 10" wheels to 13" wheels some years ago at one of our local wheel alignment places. Can't recall the cost but it was perfectly reasonable and the trailer has done many kms since. It's a good match.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  25. The Following 2 Users Say Thank You to Family_Dog For This Useful Post:
  26. #15
    Thanked: 326
    Thanks for the comments! I am astounded at the spares available on the Venter website, one can basically scratch build a trailer from that!
  27. #16
    Jun 2017
    For the 13" rims and wheels I got mine at burquip they are R828 compared to venter R1288. But the leaf springs are cheaper at Boksburg venter. https://burquip.co.za/product-catego...im-tyre-combo/
  28. The Following User Says Thank You to shaggy For This Useful Post:
  29. #17
    Sinoville Pretoria
    Thanked: 474
    10" wheels on a trailer is a nono, as max speed on those small tyres and wheel bearings is limited, acc to Roadque in Pta.
    Iirc max speed was 100 or 80km/h for the small wheels. I did not really pay attention to detail as i do not own a 10" trailer, but have since then observed may a 10" doing 140 or more on our highways some with the Moz triangle sticker on, thus travelling huge distances at high speed, with poor road conditions in Moz as well
    Henk Pretorius D4 3,0 SDV6 HSE
    EX AFRICII SEMPER NOVUS
  30. The Following 2 Users Say Thank You to julius caesar For This Useful Post:
  31. #18
    Thanked: 1486
    Quote Originally Posted by julius caesar View Post
    And 90% of all classic Minis sit up and say "What?!!"
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  32. The Following 2 Users Say Thank You to JohnnoK For This Useful Post:
  33. #19
    Sinoville Pretoria
    Thanked: 474
    Tyres of the 10" Venter have a rating for speed is what i am saying, the older Mini tyres used could have a different rating
  34. #20
    King Williams Town
    Thanked: 839
    I think the rating is 80km/h
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
