Defender Defender pulling left when braking
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 48
    Feb 2016
    Thanked: 690
    Default Defender pulling left when braking
    Hi everyone,
    yet another issue cropped up on my Puma, only noticeable at highway speeds (>80kmh): when I brake, the car dives to the left.
    Even if I hold the steering wheel straight, the car still does this.
    What could be causing this?
    Apr 2014
    Richards Bay
    Thanked: 92
    Default Re: Defender pulling left when braking
    Brakes aren't balanced. Brakes favouring one side. Might be as simple as bleeding the system. If pads and disks are still in good condition and problem persists it may mean you need to service the callipers (Sometimes the piston can seize due to corrosion).
    1985 Land Rover 110 - 300tdi conversion
    It's always more fun on the road less travelled
    Apr 2014
    Richards Bay
    Thanked: 92
    You can take it to a road worthy centre. They can test brakes on a rolling road and tell you which is the offending wheel.
    Feb 2016
    Paarl
    Thanked: 590
    Bleed the brakes. See if there is enough pressure to BOTH the front calipers. If one seems to have more pressure than the other, it could be a blocked brake pipe. They tend to perish inside and then block up, especially on older vehicles. Also check the 'sliding mechanism' On most vehicles these are pins, these need to be lubricated, or could seize up.
    1996 Discovery 1 (SOLD)
    2001 Mercedes C180 (SOLD)
    2012 Nissan Xtrail 2.0 (Weekend Wagon)
    2010 Kia Sedona 2.9Crdi (Written off)
    Feb 2016
    Thanked: 690
    thanks, will take it back to the shop
    Feb 2013
    Strand
    Thanked: 81
    Sit net 'n stukkie lood agter die regter oor.
    Met verskoning aan Tolla.
    Robertson/ Larissa, Greece
    Thanked: 2742
    The Defender has a 4 wheel disc system and highly unlikely to be a brake problem IMHO. By all means do as suggested but it can also be something else like worn swivel bearings, shock absorbers or steering linkages that are worn. On a live front axle vehicle it can be many things. I speak from experience.
    Please let us know what the problem was if and when you find it. This can be rather frustrating at times.
  8. The Following 2 Users Say Thank You to Francois Theron For This Useful Post:
    Swakopmund
    Could also be a damaged flexible hose from fixed aluminium tube to brake caliper which is expanding under pressure and so brake cylinders not getting full pressure
  10. The Following User Says Thank You to Silverfox For This Useful Post:
    Feb 2016
    Thanked: 690
    thanks Francois, the Bilstein shocks were last rebuilt/serviced in 2013, probably time to do them again.
    Thanked: 890
    I had violent brake pulling to the left on my old Ser3S. Enough to change lanes! In my case it was pretty simple, but they were from brakes. Some butcher had fitted Ser3 brakes to one side, and 3S brakes on the other. I agree with the points above, but Francois raises some interesting alternative theories.
    More difficult to detect however. You will need to get stuck into the linkages with a pry bar and see what wobbles. Not sure about the steering shock. Will just have to take it off and test it I guess. Those swivel balls are a big job and will certainly discourage you from rushing into muddy crossings with gay abandon once you have seen what is involved in fixing them.
  13. #11
    Mar 2015
    Thanked: 218
    I had the same symptoms as described by the OP and in my case it was the front wheel bearing on one side that was shot (on a Merc though). The extra play in the bearing pushed the calipers apart on the one side.
  14. #12
    Thanked: 434
    My D1 did that when the ABS pump packed up. I just removed and bypassed it. Huge improvement in overall braking.
  15. #13
    Feb 2016
    Thanked: 690
    initial feedback from the workshop is that there's nothing wrong with the calipers nor the braking system.
    As Francois said, it could be something else in the suspension which is causing this, so they're checking other things tomorrow.
  16. #14
    Apr 2014
    Richards Bay
    Thanked: 92
    If something in the suspension I would expect the vehicle to pull when you go over bumps as well, not only when breaking. How did they test the brakes? A slightly warped disk would also cause issues and may not be obvious when inspecting without a clock gauge etc.
    you donít want to get to the point where all suspension bushes etc are changed and the problem persists.
  17. #15
    Apr 2014
    Richards Bay
    Thanked: 92
    A rolling road is probably the only way to check that your brakes are balanced
  18. #16
    Thanked: 11108
    My money is on that pesky rear A-arm ball joint........
  19. #17
    Boksburg
    Smile Re: Defender pulling left when braking
    Quote Originally Posted by Nitebob View Post
    I had a similar problem on an Autovilla a few years ago. If the vehicle pulls immediately to one side when braking and then corrects itself whilst still braking, it is definitely the hose on the side it initially veers to. If not, it will be something else. Good luck!
  20. #18
    Jan 2011
    Thanked: 592
    I had a similar problem on my Asia Rocsta many years ago, it end up to be the wheel alignment that was out, nothing to loose to check it out also.
    Before you criticize someone, you should walk a mile in their shoes.
    That way, when you criticize them, you're a mile away and you have their shoes.
  21. #19
    Feb 2016
    Paarl
    Thanked: 590
    A worn balljoint, can cause a car to pull to one side upon braking, but usually causes a pull in the opposite direction when accelerating...
  22. #20
    Dec 2014
    Thanked: 1685
    When I first bough my Disco it used to pull to one side together with a shudder under braking, and it was eventually traced back to a dead tie-rod joint.
    I had the Disco in for wheel alignment (again) to try and diagnose the fault, and the tech doing the alignment picked it up.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
