D4 V8 Engine oil
Results 1 to 20 of 24
    Swakopmund
    Default D4 V8 Engine oil
    Can anyone recommend a better oil other than Castrol Edge 5W30 A5 for the Jaguar 5.0 engine
    Feb 2016
    Thanked: 615
    Default Re: D4 V8 Engine oil
    Fuchs/Motul/Mobil/Ravenol of the same spec: https://www.opieoils.co.uk/f/2354/21...ngine-oil.aspx
    the most important past is that the oil conforms to the specs, in your case, JAGUAR LAND ROVER STJLR.03.5004 or FORD M2C948-B
  3. The Following User Says Thank You to Orxy For This Useful Post:
    Thanked: 10243
    Shell Helix Ultra?
    Plettenberg bay
    Thanked: 128
    LiquiMoly Special Tec F 5W-30
    Range Rover Sport HSE
    MGB GT
    Mercedes Benz C200 (SWAMBO)
    I try to be the person my dogs thought I was....
    Sep 2013
    Moot, Pretoria
    Thanked: 28
    Why? What is wrong with Edge? If been using it with good results....
    LandRover Discovery 3 TDV6 2007
    BMW 320 D (E90) 2006
    Swakopmund
    Shell Helix Ultra?
    Is that the HX 7 fully synthetic?
    Mar 2018
    Ravenol is great if not the best oil and on there website you can use the oil finder.
  9. The Following User Says Thank You to Robwild For This Useful Post:
    Swakopmund
    Quote Originally Posted by johanventer View Post
    I have been using Edge every 10k, but my cam chain now starting to get noisy. Am just about on 200k. 2010 model
    Thanked: 10243
    Quote Originally Posted by Silverfox View Post
    oil won't fix a worn cam chain, tensioner and sprockets.............
  12. The Following 2 Users Say Thank You to jelo For This Useful Post:
  13. #10
    Swakopmund
    I know that, but should it be worn after 10k oil services.
  14. #11
    Thanked: 10243
    on Castrol anything is possible
    but it seems to be a common problem on that engine
    https://static.nhtsa.gov/odi/tsbs/20...03562-9340.pdf
    https://www.rangerovers.net/forum/6-...de-issues.html
    https://www.carcomplaints.com/news/2...nes-fail.shtml
    https://www.jaguarforums.com/forum/x...e-wear-191810/
  15. The Following User Says Thank You to jelo For This Useful Post:
  16. #12
    Swakopmund
    I see and the super charged ones even more so.
    The Shell oil you are on about, I think I will give it a try while I am sourcing new cam chain, sprocket and tensioner.
    Would you recommend agents only for these?
  17. #13
    Thanked: 10243
    can't comment, don't know, but I'd make sure you use a decent workshop.........
    a Jag V8 engine makes a very expensive coffee table..........
  18. #14
    Oct 2015
    Romania/Hungary
    Thanked: 114
    I think somebody misinformed you about what oil to use in that engine as 5W30 is not an option, choose any brand which meets the specs from the workshop manual not oils recommended by suppliers on theyrs sites or unofficial documents... i cropped the relevant part from the official LR website's WSM .... IMO most of the problems of these engines is caused by the wrong oil based on other recommendations than the manufacturer's.
    2000 Discovery Td5 ES manual, tuned
    Hawkeye v.6, Nanocom EVO,
    VDM UCANDAS, oscilloscope
    i DON'T ANSWER TO TECHNICAL QUESTIONS IN PM'S
    ALL MY ADVICES ARE BASED ON MY OWN EXPERIENCE AND MY WAY OF UNDERSTANDING THE DESCRIPTION AND OPERATION OF SYSTEMS... I'M NOT A LAND ROVER SPECIALIST JUST AN ADDICTED ENTHUSIAST
  19. #15
    Dowerglen
    Thanked: 580
    The rattly chain issue on the up to 2012 5.0 V8 is not oil based, unfortunately its crappy tensioner design based as mention previously herein..
    If you plan to do the job yourself, seriously purchase the updated spares from the agents, make sure its the updated spares or you will run into the same issue again..
    Note, apart from the replacement part, you will need an injector puller, and you will need the camshaft locking tools.
    Without the puller there is a good chance you will damage the injectors, without the cam locking tool you are in for a whole new world of pain..
    I understand that most of your front end will have to be removed, all radiators grill frame, lights etc etc in order to get to the front of the motor.
    While you are in there consider the water-pump replacement, its a cheap enough guarantee you will not need to come back to at a later date..
    My mates, 2012 V8 HSE, same issue, milage 130K if I'm not mistaken, cost was somewhere between R80 - R100K at JLR Sandton if I recall.., I did mention these costs somewhere in a previous post, either way sadly its not cheap..
ID:	533254   Click image for larger version.
ID:	533255   Click image for larger version.
    Every dog has its day, and those with broken tails have their weak-ends...
    1976 CJ-7, 400CI + Holley EFI, Tera-Low 3,15:1 twin stick, ARB's front & rear, oil leaks & plenty more....
    All my other petrol burners are boring....
  20. The Following User Says Thank You to Marcochezzi For This Useful Post:
  21. #16
    Forest Hills, KZN
    Thanked: 712
    Suggest you do the cam chain tensioners sooner rather than later to save on extra damage associated with bent valves, etc.
    Cost me R70k all in at a LR dealer with new waterpump, thermostat housing and that was without bent valves.
  22. The Following User Says Thank You to douglash For This Useful Post:
  23. #17
    Swakopmund
    Quote Originally Posted by sierrafery View Post
    5W20 is specced for Europe. In plus 40 degrees Celsius 5W20 is too thin.
  24. #18
    Swakopmund
    Quote Originally Posted by Marcochezzi View Post
    Well noted and thanks. I will be doing it myself.
  25. #19
    Oct 2015
    Romania/Hungary
    Thanked: 114
    The figure after W is showing the visocsity specs at above 100*C, the first figure is relevant only in low ambient temps for the cold start, IMO the manufacturer knows better what oil is good for the engine also once up at running temp the engine should be at around 95*C regardless if it's in Europe or Africa...provided the cooling system is performing as it should.
  26. #20
    Swakopmund
    What you are saying makes complete sense.
    From reading up, my engine has done very well as it's on nearly 200 000km and I only have a light ticking and have been using the 5W30 since 120 000km and servicing myself.
    I have heard of a bloke running 15W40 in his D3 diesel and is on 400 000km and drives it hard and lives on a farm
