2.7tdi R20 engine exhaust manifold
Results 1 to 8 of 8
    Thanked: 11
    Default 2.7tdi R20 engine exhaust manifold
    I had a cracked manifold repaired, properly welded at an engineering shop, x-rayed, and refitted, the area between the turbo and the manifold was skimmed, but the turbo keeps on leaking or the gasket. Some experts have told me it may be due to the skimming that the metal is a little to thin now and from heating and cooling the gasket starts leaking. It's has been done 3 times now, but within a month the blowing starts again.
    So I have 2 questions:
    1. Does anybody know how this can be fixed? I could tell them to weld a layer of a a few mm onto the gasket and skim it again (so the manifold it think enough to no warp), but that isn't a small job.
    2. Does anyone have a TD27 manifold for me?
    I have a local TD27 top on the motor (the injector holes had to be bored to fit my injectors, but that was all), so will a 2.7 turbo diesel bakkie manifold fit here?
    Advise would be appreciated. (No, selling the Terrano is not worth it, I want to fix it)
    Thanked: 119
    Default Re: 2.7tdi R20 engine exhaust manifold
    Can you find a clear image of the manifold?
    If it is the same as the 2.7D manifold, I have a brand new OEM Nissan one in storage.
    I was going to use it to turbo my QD32 way back then, but was advised against it.
    '00 Nissan D22 QD32Ti 4x4 D/C
    '10 Toyota LC150 4.0V6 VX
    '10 Yamaha XT1200Z Super Ténéré
    Our lives were governed by the Ten Commandments, good judgment, and common sense.
    Thanked: 11
    How much do you want for it?
    Thanked: 119
    No idea.
    I go dig it up sometime, you see if it fits.
    If it does, you can make me an offer?
    Thanked: 9723
    Just contact one of the importers, they bring in dozens of those TD27T engines, they should have some spares
    www.enginesandmore.co.za
    Thanked: 11
    Swakop_toe, where are you located? I'm in the Western Cape, Klapmuts or Cape Town CBD
    Thanked: 119
    Quote Originally Posted by lifeboy View Post
    Milnerton and Tygervalley.
    Thanked: 11
    Kon jy dit dalk al vind? Ek sal baie graag wil kyk of hy pas.
