Trailer batteries end of life, one or both?
Results 1 to 5 of 5
    Phalaborwa
    Thanked: 15
    Default Trailer batteries end of life, one or both?
    I have 2 105a deep cycle batteries in my trailer with mk4 power panel. Approx. 4 years old. I charge continuously with 220 mains. The panel shows a drop to 10. As I understand it the panel shows the main batterie's voltage but not the aux battery. Does that mean the aux battery maight still be ok, or that both have reached end of life?
    Sinoville Pretoria
    Thanked: 487
    Default Re: Trailer batteries end of life, one or both?
    Perhaps swop the 2 batteries and then look at numbers
    Henk Pretorius D4 3,0 SDV6 HSE
    EX AFRICII SEMPER NOVUS
  3. The Following User Says Thank You to julius caesar For This Useful Post:
    Thanked: 110
    Are the two batteries connected in parallel? Pse say how you identify the main and aux battery?
    ORRA Callsign: X130
    Phalaborwa
    Thanked: 15
    I actually have no idea. Was thinking to disconnect each in turn and see which one displays on the panel??
    Friemersheim, Southern Cape
    Thanked: 2138
    Any owner who has an aux battery should at least have a multimeter (even a cheapy).
    Makes life so much easier to measure quickly and independently.
    https://www.takealot.com/digital-mul...E&gclsrc=aw.ds
    A whole R149!
  7. The Following 3 Users Say Thank You to Prof For This Useful Post:
