Discovery 4 in Mabuasehube - Page 2
Results 21 to 37 of 37
    Apr 2015
    Thanked: 282
    Default Re: Discovery 4 in Mabuasehube
    Quote Originally Posted by Koos Best View Post
    Gearbox, remember LRover says its sealed for life, this is not so , the oil cant last for ever.
    The guys on the internet say that you have to change the oil and filter every 80 000 km.
    I am certainly going to do that, and have already done so with my BMW (they also say lifetime).
    Discovery 1 1995 V8i 3.9l (Sold, owned for 20 years); Freelander 2 2013 SD4 SE; Discovery 4 2014 SDV6 SE; Bushlapa Boskriek
  2. The Following User Says Thank You to Jola For This Useful Post:
  3. #22
    Apr 2012
    Melkbos
    Thanked: 8
    Default Discovery 4 in Mabuasehube
    Hi I also have a V8 but a D3 now with 190 000km on.Without a long story,take you car to ZF and do a proper,full gearbox service(I used Triangle transmission in Bellville,also a gearbox SPECIALIST),repeat every 50 000km.You should then have no gearbox issues.I learn't this the exspensive way(at 150 000km just 5 000km after a precautionary dealer gearbox double flush!).
    Defender 110 H/T 2.8i(Fully Loaded!) ; Disco 3 V8 HSE
    Evil C
  4. The Following User Says Thank You to Clive Miller For This Useful Post:
  5. #23
    Jan 2019
    White River
    Thanked: 16
    Question Re: Discovery 4 in Mabuasehube
    Doing Mabuashehube in my D4 TDV6 3l in October towing bush trailer. What was your fuel consumption on the sand roads.
  6. #24
    Hoedspruit
    Thanked: 89
    Quote Originally Posted by desdrake View Post
    Hi desdrake
    You need to remember that I have a V8, but on the thick sand I got anything from 3.5 - 4.5km/L towing a Jurgens Xcape.
    2011 Discovery 4 V8 HSE
  7. The Following User Says Thank You to Fourie110 For This Useful Post:
  8. #25
    Feb 2013
    Thanked: 300
    About 6 to 7 km/litre towing a Miskruier.
    Bush Lapa Miskruier: B116
  9. #26
    Jan 2015
    Thanked: 8
    Thanks for Sharing Video..
  10. The Following User Says Thank You to n0b0dy For This Useful Post:
  11. #27
    Hoedspruit
    Thanked: 89
    So this afternoon I decided to remove the rear valve block from the Disco to have a closer look and to clean it. Let me know what your thoughts are?? One can clearly see the 'white stuff' around the seals. Surely this would be a good reason for a small leak and also an air compressor on its way out.
    What are the thoughts?
    Andre
ID:	533844   Click image for larger version.
ID:	533845   Click image for larger version.
  12. #28
    Jul 2018
    Thanked: 74
    Quote Originally Posted by Fourie110 View Post
    So this afternoon I decided to remove the rear valve block from the Disco to have a closer look and to clean it. Let me know what your thoughts are?? One can clearly see the 'white stuff' around the seals. Surely this would be a good reason for a small leak and also an air compressor on its way out.What are the thoughts?Cheers Andre
    for those less mechanically inclined but getting there, what exactly are we looking at here? what is that? where is it?
  13. #29
    Hoedspruit
    Thanked: 89
    Quote Originally Posted by m0lt3n View Post
    The part that I took out is the rear valve block. It works very simple: There is one inlet pipe that feeds the valves and 2 outlet pipes that feed air to the 2 rear airbags. The front of the car also has a valve block to feed the 2 front air bags. So after some research and input on this very thread some people say I can remove the valve block and clean the o-rings. If the o-rings are dirty they will not seal properly and air will slowly leak and the vehicle will drop down. Apparently when the air compressor gets old silica crystals start to break down and collects in these valve blocks.
    Bottom line is it might be a pre-warning that my air compressor is getting old and might need replacing soon, but in the process it was a good exercise to clean the valve block to make it seal properly. Well that is the theory. I hope I have just fixed something. I must say it was a rather hard job to free the 2 outlet pipes as I have a long range fuel tank. In other words I could not gain access from where the spare wheel used to be.
  14. The Following User Says Thank You to Fourie110 For This Useful Post:
  15. #30
    Doing Time in CKGR
    Thanked: 184
    Andre
    Hi Andre. That is exactly the problem I had with my D4 and was sorted out easily and not expensive either. My symptom was that the compressor was running all the time when the vehicle was at a stand still.
    I had my gearbox serviced by ZF in Cape Town at 105,000km , one of the best vehicle experiences I have had - very professional and courteous. Remember to leave early, or plan to spend the night nearby the workshop as they will need your vehicle for most of the day - all day if you drop the vehicle off in the morning as it has to cool down. I dropped mine off the previous evening.
    Enjoy your D4, the most versatile and capable vehicles on the road.
    VW Amarok V6 4Motion Highline Plus
    Defender 130 HCPU TD5
    SOLD - D4 SDV6 HSE
  16. #31
    Hoedspruit
    Thanked: 89
    Quote Originally Posted by Oreo View Post
    Hi Oreo
    Thank you for your input. I really hope I am winning with the suspension issue. I'm not too worried about the gearbox. That I will get serviced and properly checked out.
  17. The Following User Says Thank You to Fourie110 For This Useful Post:
  18. #32
    Apr 2015
    Western Australia
    Andre
    The 'white stuff' is the silica gel crystals breaking down and getting through the filter pads.Try putting one of these kits https://www.ebay.com.au/itm/AMK-Air-...53.m1438.l2649
    through the compressor.Use the forums on www.aulro.com.au or www.disco3.co.uk for the procedure.
  19. The Following User Says Thank You to eddyoz For This Useful Post:
  20. #33
    Hoedspruit
    Thanked: 89
    So after leaving the vehicle in off road hight since yesterday morning, the Disco hasn't dropped at all. I did of course measure yesterday just after leaving the vehicle to rest and this morning it is exactly as I left it. I'm sure the warmer, thicker air here in Hoedspruit also plays a part, but hopefully I just mended something.
  21. #34
    Thanked: 2126
    This is very funny...
    My name is Rainier and I drive a Frotuna.
    Why are you always in such a bad mood? Experience...
  22. #35
    Hoedspruit
    Thanked: 89
    Quote Originally Posted by rainier vermaak View Post
    this is very funny...;d;d;d
    ;d;d;d
  23. #36
    Mar 2013
    Thanked: 67
    Ek het by Landtech Auto in Nelspruit by Johan my double flush laat doen op my ratkas. Nuwe olie en 'n buis Dr. Tranny. Dit het die ratkas se 'hunting' onder 2000rpm, en vibrasie weggeneem.
    013 752 2935 / 072 465 6115.
    Vra ook hulle die filter in die ratkas vir jou vervang.
    ''​Luck favours the prepared man''
    Discovery 3 HSE - 2.7V6Tdi 2008 (Written off)
  24. The Following User Says Thank You to Naguiltjie For This Useful Post:
  25. #37
    Jul 2014
    Somerset-West
    For those interested in the video of our trip.
    https://www.youtube.com/watch?v=_k41FXWiK68
    Nice video Fourie. Dit maak mens lus om te pak en gaan.
  26. The Following User Says Thank You to The White Stallion For This Useful Post:
