Epoxy coating of Oregan Pine
Results 1 to 4 of 4
    B-gowrie Randburg
    Thanked: 305
    Default Epoxy coating of Oregan Pine
    ... so I sanded table down through sandpapers 40, 60, 80, 100, 120
    and have put good coat of ‘prodet’ catalysed resin ...
    ... which is now dry to touch after 2-3 hrs ...
    ... can I now put 600 paper sander on it and give final coat ?
    ..., or must I wait much much longer ?
    2002 Defender 130 DC HCPU. : Own the road...Any road
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8... The Greatest Rover.
    ‘1975 Series3 88 PUP... Simply Classic...
    ‘2017 Metalian Mini ... A Home from Home
    Thanked: 988
    Default Re: Epoxy coating of Oregan Pine
    Should you not have taken the wood down to 600 first?
    Either way I would leave it overnight to dry, it is cold.
  3. The Following User Says Thank You to Andrew Leigh For This Useful Post:
    Thanked: 261
    wait till it is DRY
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
  5. The Following User Says Thank You to Robbief For This Useful Post:
    Dec 2014
    Thanked: 1908
    Quote Originally Posted by Robbief View Post
    wait till it is DRY
    Then add 24 hours for it to properly CURE.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  7. The Following User Says Thank You to JohnnoK For This Useful Post:
