Tiny Teardrop Camper Design & Build - Page 2
Page 2 of 23 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 21 to 40 of 460
  1. #21
    Default Re: Tiny Teardrop Camper Design & Build
    What you are building is not Tiny any more, this is a Tiny Teardrop :-)
Name:	little teardrop side.jpg
ID:	532812Click image for larger version.
Name:	little teardrop rear.jpg
    '89 LR 110 V8
  2. #22
    Mar 2012
    Nice, not quite. but width wise i'm not going to be far off.
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
  3. #23
    Cape Town - RSA
    Wonder if the teardrop shape actually helps behind a tow vehicle? Or are you just sacrificing space for 0.001L/100km fuel saving.
    Ex - 2005 Cherokee CRD
  4. #24
    Mar 2012
    No idea, but I'm sure it will get 50 points for attitude!
    Honda Civic Type R
    - Daily Drive
  5. #25
    From what I understand that was the original reason for the compact design and also for towing behind a normal passenger vehicle.. so has to be lightweight.
    2005 Ford Ranger SuperCab XLT 4000V6 Manual 5 Speed 4x4
    Petri
    1997 Ford Explorer XLT 4.0 L SOHC V6 Auto AWD 4x4
    Pieter
    2013 Audi Q5 2.0 TDi S-Tronic Quattro
    Daily Drive
  6. #26
    Mar 2012
    Last night I was thinking about composite material the pro's and con's. But at the end we decided to stick with wood for now as we know how to work with it and also seeing that the interior will be used as room we really like the feel and touch that it 'wood' bring.
    We will be using high quality birch ply not the builders Warehouse ply.
    Also this camper will be too small for a galley and for now we don't want to battle with sealing and sourcing of things like hurricane hinges.
    2D Design
    I had to play around with Fred in 2d to make sure that we have enough space, and by saying enough I mean barely enough. Enough to sit up and enough to lay down.
Name:	Original Concept plus fred.JPG
    Next:
    1. Enough with these 2d sketches lets do some 3D modelling.
    2. At the same time we will start looking at all the items that's required for this project.
    Honda Civic Type R
    - Daily Drive
  7. #27
    Ruimsig
    Maybe chat to some of the Yachting crowd. They can recommend suppliers of materials like Marine Ply, epoxies and other light weight ''off-the-shelf'' materials, fittings and accessories. I would imagine keeping precipitation out while getting durability are high priorities for you and no better place for materials than the boating world.
    Estee = S T = Sean Towlson
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range Building for Touring, not Trails
    FJ: One day when I am big
    Land Rovers: Done unfortunately
  8. #28
    Quote Originally Posted by ViperR View Post
    Sounds interesting, and yes that might be the better option. Do you know how the price compares to plywood and how flexible these panels are. Also is something like that readily available up here in joburg.
    I have looked at other composite's but at this stage I'm more comfortable with wood.
    But if you have details of a local supplier please share. I 'wood' like to investigate other options.
    I have a Jetstream and a friend I have has been toying with the idea of building a teardrop - sticking to the basic dimensions of the Jetstream but with a different build process, the modern composites are fantastic but admittedly relatively expensive, most caravans and boats have very little wood these days and utilise different types of composite board (fiberglass/aluminium/plastic honeycomb) - Google Coosa
    Simply put the design is based on an aluminium frame bent and riveted together with s/s cross members and the board is then glued in...........windows and doors can be bought online...
    Personally I would stick with slightly larger dimensions than what you are considering, its more usable and the cost difference is negligible.....once you have used a teardrop you will never look at anything else - its just so easy!!
    Do yourself a favour and get onto Pintrest, there are thousands of ideas to mull over!
    FJC - Just Cruising
  9. #29
    (Calculated / modeled) static weight on tow bar?
  10. #30
    Mar 2012
    Quote Originally Posted by PieterOos View Post
    Did the following, now the axle is not cast in concrete as yet. Does this seem like it falls in the ballpark?
    This is just a thumb suck for now, until we get a better understanding of the weights that we going to work with.
    Honda Civic Type R
    - Daily Drive
  11. #31
    Did I read it correctly, 94lb? Yes looks good. (I haven't check the rest but I presume you want to come in with GVM < 750kg, for a B licensed driver.)
  12. #32
    Mar 2012
    It's in kg although it says Lb(N). Yes the idea was to get it to fall within the 750kg mark, but with a tongue box and RTT I believe we will be well over a ton. We'll just make sure we use a higher rated axle and keep revisiting the calculation until we have better idea of what we working with.
    Honda Civic Type R
    - Daily Drive
  13. #33
    Maybe consider releasing two models as you might find a market for a <750kg model?
  14. #34
    Mar 2012
    I mentioned at the start of the thread that we wanted this build to be unique in it's own way. And how do you do that, well we started with the tail lights. I looked at all the mainstream trailer, camper manufacturers and they all had one thing in common lights, tail lights. I can't believe that in this day and age we still only user two designs, the good old brick design that comes from nineteen voetseks and the round light that is just as old, but I'll give it to them at least it's an LED light now.
    Anyway can't believe that something like a tail light can get under my skin like that, so I started searching far and wide and ended up with this! I think it's unique and a little different.
    After my little tiff with the tail lights I ask Fred and his twin sister, that is actually also quite bulky to lay on a mattress so that I can measure them It will be a tight fit so lets call it a space for a cosy couple or maybe like I mentioned earlier for swambo and the little one.
Name:	Screenshot 2019-07-09 at 20.59.39.png
ID:	533316Click image for larger version.
Name:	Screenshot 2019-07-09 at 20.59.25.png
    I also asked Fred to sit up for me Fred is very good with taking orders.
Name:	Screenshot 2019-07-09 at 21.03.32.png
    It seems like his twin sister has the ability to levitate. Not sure how many of you can sleep like this but nonetheless the idea is there.
Name:	Screenshot 2019-07-09 at 21.03.46.png
    Honda Civic Type R
    - Daily Drive
  15. #35
    Sleep on the right mattress and it feels like you float on air
    One small little detail that Fred did not let you in on is sleeping on a pillow one hardly ever sleeps with your head right at the top of your bed, usually about 250 - 300 mm away. Seeing as you are a tall Fred it might interfere with a good night's sleep.
    The birch plywood is a great choice and I don't know if you are aware that it is also available in 1500 x 3000 sheets with a lot that is impregnated in resin, genuine good stuff, I have had off cuts in water for more than a year and no sign of delamination. It is expensive though a sheet of 10mm will set you back about R1.6k
    Another option is to contact this member https://www.4x4community.co.za/forum...hp/20445-Wedwo he is in to composite sheeting that might just change your mind.
    Henk
    Follow us on Facebook
  16. #36
    Mar 2012
    True forgot about the pillows. Yes I'm aware of the larger sheet. I think the plan will be to try and fit everything on the smaller sheets for now and then If it's a good build sell and build a bigger one.
    The birch is definitely high quality stuff but very pricey. What I would have liked but I can't seem to fine any is the sheets that they coat with protective film layer. Unfortunately I can't find a local supplier, so we will have to coat the interior ourselves. Something I'm not really keen on doing.
    Honda Civic Type R
    - Daily Drive
  17. #37
    Mar 2012
    Porch Light x2. Tick that box. See you can set them to yellow so that's a plus.
    Honda Civic Type R
    - Daily Drive
  18. #38
    Jeffrey's Bay
    Following your build as I'm doing something in a similar line...although I'm just DIY'ing it together.
    Where did you get these specific lights? I've seen them somewhere but now can't find them again...
    Anton
    "At the end of the game, the King and the pawn go back into the same box." - Italian Proverb
    "The single most important component of a camera is the twelve inches behind it." - Ansel Adams
  19. #39
    Mar 2012
    Quote Originally Posted by avk View Post
    Outdoor Warehouse
    Honda Civic Type R
    - Daily Drive
  20. #40
    Mar 2012
    Gas Stove have arrived.
    Playing Around with Surface finishes. I've used some Danish Oil, believe that has a low or no VOC.
    Not sure if it is visible in the image but on the right the coating looked rough, gave it a fine sand on the left and think that is the look that we will be going for. A semi sheen finish.
    Honda Civic Type R
    - Daily Drive
