Discovery 4 Spare Key coding - Disco 4
Results 1 to 20 of 20
    Thanked: 33
    Default Spare Key coding - Disco 4
    Hello All,
    Your assistance will be greatly appreciated.
    I need to have a spare key coded and cut, got the actual key from the UK, any advice on someone thatíll do this correctly and properly first time please?
    2009 Land Rover Discovery 4 TDV6 S
    Thank you all
    AK77
    2017 Toyota Fortuner 2.8 GD-6 4x4 A/T
    Mar 2012
    Fourways
    Thanked: 434
    Default Re: Spare Key coding - Disco 4
    If you had an IIDtool you would be able to code it yourself.... Maybe there is someone on here with a Pro license that can help you.
    Failing this you would need to go to a stealer (dealer) to do it for you.... No idea about the cutting
    I'm thinking of buying a used key fob with a blank key template and programming it as a 3rd key for mine to keep in the safe as a spare. the 2 keys are currently being used (each has a different memory seat setting)
    Rob,
    D4 SDV6 HSE ARB Bullbar, Compos, BFG 265/65R18s, Big Country drawers, National Luna 52L, Dometic 50L, Spare Wheel Carrier, Roof Rack, Hardshell RTT, FR 50" LED Bar, Lift Rods, Mantec Snorkel, C-TEK Dual batt system, 270 Ostrichwing, Maxtrax, TXG Rock Sliders, IIDtool, shelf
    Oct 2015
    Thanked: 94
    My second key just went dead...a key master says it is a loose solder on the board and the indie says it's the battery. Any suggestions where I can go in CT so I can fix this without paying the price of a new key?
    Discovery Landrover 3 tdv6 2008
    Volvo S40 T5 2006
    Thanked: 33
    Quote Originally Posted by DETOUR-GP View Post
    long story on what happened to my spare key...
    thank you Rob for the reply. Currently looking at having to go to that Stealer (dealer). Believe it or not theyíre cheapest so far, just hope they can do it and not give a story of having to change the whole module.
    BTW, Oooooo your Landy looks schweet. Give me some ideas on good to haves please? Maybe some pics of yours please?
    Apr 2015
    Thanked: 284
    I have an IIDTool, how do you do this ?
    Also any recommendations as to the best place to get a blank ?
    And where can one get the physical key cut, I guess that an ordinary locksmith can't do it ?
    Discovery 1 1995 V8i 3.9l (Sold, owned for 20 years); Freelander 2 2013 SD4 SE; Discovery 4 2014 SDV6 SE; Bushlapa Boskriek
    Thanked: 33
    Quote Originally Posted by Jola View Post
    Hi Jola,
    Best is to check in YouTube. Thereís a few videos.
    May I ask what did the IIDtool cost? Getting crazy quotes for the coding.
    Correct, any locksmith should be able to cut the key.
    Awesome Disco you got there.
    Mar 2012
    Fourways
    Thanked: 434
    Quote Originally Posted by AK77 View Post
    thank you Rob for the reply. Currently looking at having to go to that Stealer (dealer). Believe it or not they’re cheapest so far, just hope they can do it and not give a story of having to change the whole module.
    Thanks for the compliments bud. You are looking at about $500ish to buy one on ebay. I was lucky, mine was advertised for a range rover only (the owner didnt know that the car can be changed) and I bought it for under $250. GAP Diagnostics changed owner and car and off I went. The IIDtool is such an amazing tool from Dianostics to Height adjustments, to coding keys. Every disco owner should have one IMO
    I am in process of doing a video feature film of my car, will share when its done. It will feature every single modification done to the Disco
    Have a look here, it takes you through the process on programming a key fob -- https://www.youtube.com/watch?v=CtxUaD8nMOQ
    I have recently bought a blank from eBay but have not looked at where to cut it as yet.
    Rob,
  8. The Following User Says Thank You to DETOUR-GP For This Useful Post:
    Sep 2012
    Thanked: 28
    Call Anthony from Northern Keys in Bellville, Cape Town, I got a new key in a generic casing, cut and reprogrammed all for R1000.00 same day service, very knowledgeable bloke! (082) 455-6322
    Thanked: 33
    I got a key from http://www.car-keys-online.com/
    Apr 2015
    Thanked: 284
    Hmm, thanks, but that is quite steep.
    I am going to try one of the eBay ones and see how it works.
    Of course, the SA Post Office may steal it, we will see.
    Apr 2015
    Thanked: 284
    BTW, what is the frequency used by a typical SA D4 (mine is 2014 pre-facelift) ?
    I see that you get them in 315MHz and 433MHz ?
    I am guessing 433MHz ?
    Sep 2011
    Tokai
    Thanked: 155
    Quote Originally Posted by Shade View Post
    Turnkey Locksmiths in Diep River may be able to help: 021 712 2737
    Oct 2015
    Thanked: 94
    Quote Originally Posted by Davesg View Post
    Yes they said loose solder on board and cannot be fixed...which I find hard to believe.
    Volvo S40 T5 2006
  15. #14
    Thanked: 33
    433MHz hope itís the same as my original key, or else I got more problems 😬
  16. #15
    Thanked: 33
    Any recommendations in the Johannesburg area?
  17. #16
    Thanked: 33
    Got the key coding done and cut at Randburg Locksmiths (he does do the actual key also) 😊
    check them out if needed. Well priced too
  18. #17
    Apr 2015
    Thanked: 284
    Thanks !
    Do you know if he has the blank keys or do you have to supply those ?
    I ask because some of the key fobs on eBay come with the electronics but without the blank.
    Oh, and what is well priced ?
  19. #18
    Thanked: 33
    Thanks !
    Yes he does do the full/complete key also. Complete key and coding and cutting is +-R2500 from him (yeah, still a lot of money though cheaper/less expensive than others Iíve checked with)
    Ask for Michael
  20. The Following User Says Thank You to AK77 For This Useful Post:
  21. #19
    Jul 2018
    Kathu
    Thanked: 74
    change the battery yourself, will be done in 2 minutes. Doesnt even use a special battery but the 2032 common type. Youtube is your friend
    Then you will know...
  22. The Following User Says Thank You to m0lt3n For This Useful Post:
  23. #20
    Quote Originally Posted by Brownpine View Post
    Anthony at Northern Keys Parow supplied me with a spare Disco 4 today. Very good guy with very good equipment to code the new key in about 10 mins - efficient, courteous service with a smile - so impressed.
    11 Disco 4 HSE V8
    11 LR Puma
    17 Honda HRV
