MediaRelease: Isuzu Arctic AT 35 is The Toughest D-Max Thus Far
Results 1 to 13 of 13
    Jun 2018
    Thanked: 73
    Default Isuzu Arctic AT 35 is The Toughest D-Max Thus Far
    PORT ELIZABETH - Isuzu Motors South Africa (IMSAF) has expanded its bakkie offering with the addition of an exclusive new flagship model aimed at avid off-roaders, professionals who need to travel to inaccessible places, and city dwellers looking to make a bold statement. The Isuzu Arctic AT35 bakkie is now available through Isuzu dealers on an exclusive order only basis with a projected 50 units to be built annually in Port Elizabeth.
    "Arctic Trucks are engineered for people who need to do tough jobs in tough environments, combining this attribute with Isuzu heritage of engineering tough, reliable bakkies is guaranteed to surprise and delight our customers", says Dominic Rimmer, IMSAF Executive for Technical Services.
    Hand Built To Exacting Isuzu Manufacturing Standards
    Isuzu Motors South Africa's factory is the first and currently the only Isuzu Motors facility globally to receive Arctic Trucks International's stamp of approval to build a production Arctic Truck model.
    "The Isuzu D-MAX is a very capable platform and we are very proud to be part of this partnership. For us it's very important for the Arctic Trucks brand to not be seen as an aftermarket solution, as a result everything we do is integrated with the manufacturer," says Patrik von Sydow, CEO Arctic Trucks International.
    The Isuzu Arctic AT35 begins life inside the Struandale body shop where it is welded together with a combination of robotic welding machines and handheld tools alongside regular D-MAX models. Once the cabin and load bay are completed the body in white (unpainted metal) is then moved into a special Arctic Trucks conversion area within the body shop. It's here where the real work begins as a select group of handpicked Isuzu artisans and technicians begin the process of transforming a D-MAX into an Isuzu Arctic AT35.
    "The Isuzu Arctic AT35 is built from the ground up on the same production line as regular Isuzu D-MAX bakkies. This process allows us to ensure strict quality control measures are in place at an early stage which in turn means no compromise on the structural integrity or rust proofing on this vehicle," says Johan Vermeulen, IMSAF Executive Manufacturing and Supply Chain.
    The conversion is carried out by a team of highly experienced Isuzu manufacturing tool makers who ply their meticulous skill in crafting bigger wheel wells and arches to accommodate the larger tyres and beefed up suspension. Working alongside them is an Isuzu Manufacturing System (IMS) engineer whose job is to ensure compliance to IMS standards and processes.
    "The three artisans who are responsible for the work done in the body shop have more than 60 years' experience between them. Their core responsibilities before joining this project included ensuring dimensional conformance of work done in the body shop as well as carrying out maintenance on manufacturing related tools and equipment"
    "All the cutting and welding happens before the vehicle is transferred back to the regular production line for it's journey through the paint shop where it undergoes e-coat and painting. This means that Isuzu Arctic AT35 models are covered by the same 5 year/ Unlimited km Anti-Corrosion Warranty as all D-MAX models"
    An Isuzu Arctic AT 35 spends two days in the body shop compared to a regular D-MAX which is completed in just a few hours.
    Once the body has been painted, the journey continues through the general assembly area until the AT35 is pulled off the line once again for the final stage of the conversion which sees the vehicle transformed with the fitment of the wheelarch moldings which accommodate the 35 inch BF Goodrich All-Terrain Tyres. Here just two technicians carry out the final work by hand over a three day period before the vehicle is ready for the final quality checks and inspection before being released for shipment to the customer.
    At home both on and off-road
    Based on the D-MAX 3.0 Double Cab 4x4 LX Automatic, the Isuzu Arctic AT35 takes Isuzu D-MAX's legendary toughness and off-road capabilities to a new level with the fitment of Fox Performance suspension and dampers giving the vehicle unsurpassed off-road capability.
    The Arctic Trucks package includes:
    • An increase in vehicle height from 1860 mm to 1980 mm with an impressive 268 mm of ground clearance (up from 220 mm) with a wading depth of 718 mm (up from 600 mm).
    • The breakover angle increases from 22.4 degrees to 31,4 degrees.
    • This additional height delivers massive improvements to the standard D-MAX's approach and departure angles with 36 degrees and 28 degrees respectively
    • The re-engineered wheel arches to accommodate the 17 inch AT alloy wheels and 35 inch tyres
    • Heavy duty Arctic Trucks mud flaps
    • In addition to a 245/70R16 spare wheel, there is an emergency ResQ Puncture Repair kit as standard.
    The end result is firmer damping at high speed, enhanced suppleness at low speeds. Great on-road and off-road performance and the ability to traverse technical and soft terrain with minimal ground or vehicle impact.
    The interior is shared with the standard D-MAX along with Isuzu's familiar 3 litre intercooled turbodiesel engine and 6 speed automatic transmission. Fuel consumption is a respectable 8.6 l/100 km, with CO2 emissions of 227 g/km.
    Gear ratios remain the same with only the odometer requiring calibration to compensate for the larger tyres.
    The Isuzu Arctic AT 35 is available in one derivative, the 3 litre double cab 4x4 6 speed automatic at a recommended retail price of R 785 000.00 including VAT.
ID:	532356   Click image for larger version.
ID:	532357   Click image for larger version.
ID:	532358   Click image for larger version.
  2. The Following 2 Users Say Thank You to MediaReleases For This Useful Post:
    Feb 2007
    melkbosstrand
    Thanked: 137
    Default Re: Isuzu Arctic AT 35 is The Toughest D-Max Thus Far
    It looks good, but bloody stupid... Imagine how underpowered this thing is going to be
    This thing isn't pulling the skin off a rice pudding.
    If arctic trucks built it properly, gearing etc. I think this is a lot of money for some flared wheel arches and big rubber.
    Current: Toyota FJ Sport Cruiser
    Previous: VW Amarok ULTIMATE 4motion (auto)
    Previous: Amarok 4motion (MT) with a few goodies
    Previous: Isuzu KB300 Dteq 4x4 not that many goodies
    Prevous: Isuzu KB360 4x4 with a few goodies
  4. The Following 2 Users Say Thank You to jonoB For This Useful Post:
  5. #3
    Jul 2013
    cape town
    Thanked: 629
    so that is R157 100 for a lift kit and bigger tyres.
  6. The Following 3 Users Say Thank You to Ocin For This Useful Post:
  7. #4
    Oct 2012
    Thanked: 231
    "In addition to a 245/70R16 spare wheel"
    How will this work? You have 35" tyres and a 30" spare wheel?
  8. #5
    Apr 2018
    Thanked: 170
    Zero power upgrades, nee dankie
    The first pic is of the arctic truck the other three are just the normal new D-maxes??
    2017 Isuzu KB 300 4X4 Auto (current)
    2008 Isuzu KB 300 4X4 manual (current)
  9. #6
    Stilfontein
    Thanked: 617
    This truck might be in my garage before the end of this month. I am very impressed with it.
  10. The Following 3 Users Say Thank You to HeinrichC For This Useful Post:
  11. #7
    Apr 2018
    Thanked: 170
    Quote Originally Posted by HeinrichC View Post
    N bietjie meer inligting asb?
  12. #8
    Stilfontein
    Thanked: 617
    Quote Originally Posted by A1ex View Post
    Ek is besig om te shop vir een
  13. The Following User Says Thank You to HeinrichC For This Useful Post:
  14. #9
    Aug 2018
    Boksburg
    We had 2 of these in stock. The white one sold within 2 weeks and the red one came in 4 days ago
  15. #10
    Klerksdorp
    Hoe rooier hoe mooier!!!!
  16. The Following User Says Thank You to Roes For This Useful Post:
  17. #11
    Apr 2018
    Thanked: 170
    Has anyone bought one these things yet!?
  18. #12
    Jun 2016
    Thanked: 25
    Quote Originally Posted by JSparrow View Post
    From this angle it looks like it could comfortably reverse over the polo behind it
  19. The Following User Says Thank You to JH84 For This Useful Post:
  20. #13
    Mar 2012
    Pierre van Ryneveld
    Thanked: 3922
    The red one at Isuzu East Rand has been sold... Not sure who bought it...
  21. The Following User Says Thank You to Redman For This Useful Post:
