De Wildt 4x4 Trail - June 2019
Results 1 to 6 of 6
    Amorosa
    Default De Wildt 4x4 Trail - June 2019
    Did De Wildt 4x4 Trail a couple of weeks ago.
    The video should give a good overview of what it is all about and what can be expected.
    https://www.youtube.com/watch?v=117V...ature=youtu.be
    Bush Lapa Miskruier 586
    Aug 2016
    Louis Trichardt
    Default Re: De Wildt 4x4 Trail - June 2019
    Hi Bogaards. Just a quick question. De wild 4x4 trail and Moghatle, will I be able to do this trail with a standard 4x4 double cab. Or do I need to have a vehicle that is fitted with a suspension lift etc? That is now without damaging my vehicle?
    Amorosa
    Quote Originally Posted by Boetvasie View Post
    De Wildt can easily be done with a standard double cab.
    Moegatle you might get some damage if you don't pick the correct line, most likely you will bend running boards, but again you can avoid some of the obstacles. I am sure there are many people that do this trail with standard vehicles.
    Best is to practice and make sure you know your vehicle. It also help if you have a good spotter who can pick the correct line for you if you are unsure.
    Ruimsig
    Yes, I have done both in a standard vehicle with standard MS type tires. The first time doing Moegatle was back in 2002 or 2003 when the 4x4 ''scene'' was starting to gain momentum and when we didnt have all of the accessories available today.
    The best bits of kit that you have are common sense and good judgement.
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range
    Discovery and Range Rovers: SOLD: enough is enough
    Ruimsig
    Quote Originally Posted by Bogaards View Post
    Subscribed
    Mar 2007
    Harties Boet
    Which bakkie is it?
    I once did that trail with mates, one with a standard hilux, and one with a standard navara (old shape).
    the hilux did it with ease. The Navara scraped its belly, nudgebar and sidesteps on everything, and had to take the chicken route a couple times. It couldnt do the first axle twister climb at all - ok, it was pouring with rain, but, still it was getting hungup
    2004 Nissan Patrol 4.8
    1999 Nissan Patrol 4.2D
