Spigot rings
Results 1 to 15 of 15
Thread: Spigot rings
    May 2012
    Default Spigot rings
    Anyone know where I can buy spigot rings in the cape town northern suburbs area? looking for size 106.1 - 93.1.
    Default Re: Spigot rings
    What is a spigot ring? Like an adapter?
    Jul 2013
    Dit is dat die wiel mooi centre pas op die hub.
    I have seen that the magrim sellers have lots of them.
    Try Tiger Wheel an Tire
    May 2016
    Quote Originally Posted by janseekat View Post
    Is that not achieved by the (tapered / close fitting) wheel nuts?
    What happens if the tapered wheel nuts and the spigot rings are in conflict as to where the centre of the wheel is?
    2006 VW Touareg V10 TDi
    Jul 2013
    Lets wait for the experts.
    Meantime pse read here:
    https://www.performancealloys.com/spigot-rings
    May 2012
    I have aftermarket rims on my bakkie, the centre hole of the aftermarket rims are slightly bigger than the centre hole of my OEM rims, therefor the spigot ring fills the gap to make sure your aftermarket rim fits dead centre on the hub. Recently I did a rotate and re-balance and the guy that did the job must have lost one of my spigot rings, and just put the wheel back on without it - also not telling me. Since then I have a terrible vibration and after inspecting my wheels I saw the spigot ring is missing on that wheel the vibration is coming from. So no, you need a spiigot ring to keep it dead centre and no the wheel nuts even being tapered does not keep it dead centre. It seems that here in Cape Town it is not easy to locate these things.
    Nigel
    Contact Gang R in Krugersdorp.
    Uniglide
    +27 zero eight 2 four 95 9252
    what brand rims are they?
    Hilux 2700i s/c 4X4 with a few extras ...............
    Feb 2016
    Paarl
    I can get 106.2 - 93.1
    Let me know. For a Ranger, am I right?
    1996 Discovery 1 (SOLD)
    2001 Mercedes C180 (SOLD)
    2012 Nissan Xtrail 2.0 (Weekend Wagon)
    2010 Kia Sedona 2.9Crdi (Written off)
    Apr 2015
    I bought my Spigot rings for my A-line rims directly from SupaQuick. R100 for 4. it's really just a plastic ring the fills the gap between the rim and hub.
    Feb 2016
    Paarl
    Quote Originally Posted by Mia225 View Post
    Helps to centre the mag on the hub. Mags are 'universal' so the centrehole might be too big for some vehicles, and these 'adapts' them
    May 2012
    Quote Originally Posted by ismail View Post
    17" ATS Mamba 6/139 Matt Black Alloy Wheels - 6/139 pcd - -12 offset - CB106.1 - 9j width
    May 2012
    Quote Originally Posted by Nitebob View Post
    Ranger yes ... the sizes is as follows ...
    NEW - 17" ATS Mamba 6/139 Matt Black Alloy Wheels - 6/139 pcd - -12 offset - CB106.1 - 9j width
    Original - 16Ē OEM Rim 6/139 Silver Alloy OEM Wheel - 6/139 pcd - +8 offset - CB93.1 - 7j width
    Cape Town,South Africa
    Hi
    If you didnít come right with the spigot rings. Give me a call. I had mine made up in aluminum, last year cost was R400 for the 4 also 6/139 to i think 106.2 for a Hilux. The reason its expensive because the rest of the Aluminium plate after they cut it is a waste. So you paying for the the outer diameter.
    Razeen
    0829920752
ID:	532751   Click image for larger version.
ID:	532752   Click image for larger version.
    Razeen Baboo
    Toyota Hilux 2.4 GD-6 4x4 2016
    Audi A4 1.8T 2007
    1997 Isuzu KB 280DT 4X4
    Domino Intercooler
    63mm exhaust
    EGT Turbologix
    Hi-Lift Jack
    Turbo Timer
    Garmin GPS
    I never met a man lying on his death bed, that said he spent too little time at work.
    May 2012
    Thanx buddy, I'm picking up a set on Saturday in Strand, hopefully they are a perfect fit, if not, I will give you a call.
