Patrol Engine Issues
Results 1 to 11 of 11
    Sep 2013
    Default Patrol Engine Issues
    Hi all,
    I keep reading (and hearing) that the 3.0 Turbo Diesel in the Patrol is a complete dog... This coming from both LC and Patrol fans
    From those in the know, is this true? If so, I'm not aware of another diesel offering in the patrol pick up, but is there a better option?
    TIA
    2006 Land Rover Defender TD5 90
    Gaborone
    Thanked: 908
    Default Re: Patrol Engine Issues
    The ZD30 engine was used to blow up before reaching 100k km, so the Aussies christened them "grenade".
    A lot has improved in the later models and today they are okay.
    There is a 4.2 TD (6cyl) version in the pick-ups delivered between 2008 and 2012 about.
    Today they are also replaced with the 3.0 (4cyl)
    Kalahari Safari
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
    Sep 2013
    Quote Originally Posted by Kalahari Safari View Post
    Thank you, also found similar answers on the forum after a bit of snooping, apologies for digging up an old skeleton. Seeing as you've replied, is the presence of only the rear diff really that much of an issue off road? Specifically with steep climbs, or is it just a case of keyboard warriors?
    The ZD30 CRD is a pretty good performer with 115kw and 400nm or there about. Fuel economy at around 10l/100km - 15l/100km if towing in heavy sand. Really can't complain. However compared to modern standards this is lack lustre... in comparison even the old 3.0 D4D from toyota produces more power. Lets not even compare to the 4.5 V8 from Toyota in the LC200 (Really the only competitor out there).
    Reliability wise, the common rail is a very good engine. Stay away from the Di. Reliability is hit and miss.
    Off road, the Patrol with only a rear diff lock outperformed most. The biggest issue on trails is the width. Tight trails become very tight. With the coil suspension and solid axles it will go pretty much anywhere it fits. Rear departure angle becomes more of a hinderance than anything else in my opinion but then mine is used more for overland travels than playing.
    Dale
    F150 4x4 5.4 Triton V8
    Series 3 Land Rover 109 SW
    GU Patrol 3.0Di GL
    Metalian Maxi in RED
  5. The Following User Says Thank You to Dale For This Useful Post:
    Thanked: 9089
    If you start needing a front diff lock in a Patrol you are in territory that you should actually avoid.....IMHO
    Ruimsig
    Thanked: 1007
    Diesels are asthmatic by nature and need to be on a ventilator in order to work optimally
    As for the Patrol, it has to be the most underrated and overlooked 4x4 of all time, but I think the Ozzies understand just how good it is, judging from YT. It was definitely on my list when I decided to ditch LR but, mid-life kicked in and I went with the Hummer
    It was that or an Aston Martin
    2009 Hummer H3 5.3lt V8
    Discovery and Range Rovers: SOLD: enough is enough
    Thanked: 631
    Since you mentioned the pickup:
    This has leaf springs on the rear axle, and a large load capacity. This means that unless the vehicle is heavily loaded, rear articulation suffers, and thus the lack of a locker is felt more than on the wagons.
    However it is fitted with an excellent LSD which compensates in most situations and is said to be better in certain situations.
    However, the current 3.0l pickups do have a rear locker.
  9. The Following User Says Thank You to Peter Connan For This Useful Post:
    Kathu
    Thanked: 1921
    I have done a trail with the LC 76 v8 where lockers were needed. Two Patrols on the same trip. One with front and rear locker one with only rear locker. The one with the rear locker only had a hard time keeping up with the double locker Cruiser and Patrol.
    The 3.0l Patrol lag low down torque in serious off road applications. The 4.2 is a jewel.
    MTUNZINI
    Thanked: 425
    The grenade issue was resolved years ago, one of the problems was the dipstick was not correct, if I remembered correctly didnt give the correct oil reading. The engine suffered from not enough oil and was resolved.
    Just remember the ZD30 engine in the Rosslyn Patrol (aka hardbody config)bakkies and ZD30 long in the GQ and GU engines are completely different.
    I drove both, the 4.2D is gutless as a towing and cruising vehicle, very good for tugging along , the ZD30 Patrol was a better cruiser and towing vehicle.
    Fit a fan on the intercooler , and your low down torque will improve, there is no air flow over or into the intercooler below 80 km/h. Intercoolers on top of engines and bonnet scoops is a bad design idea , for low moving vehicles in high ambient temperatures.
    It is not a dog , as mentioned by others, some had problems like any other but was resolved.
    Great vehicles! pity Nissan SA does not advertise this vehicle more
    Koos Best
    Land Rover Discovery3 TDV6 S.
    Thanked: 9089
    Quote Originally Posted by Koos Best View Post
    Great vehicles! pity Nissan SA treat does not advertise this vehicle more
    1) here is the full list of issues with remedies: https://www.mypatrol4x4.com/topic/57...by-step-guide/
    2) several guys offer a successful turbo conversion for the TD42D
    3) I'd also consider a front mount IC if there is space, or even water cooling use a 12v spray pump
    4) Yes, NissanSA marketing is notoriously bad
  13. #11
    Kathu
    Thanked: 1921
    If it needs to be a diesel you will need to go very far to beat the v8 Cruiser. Tons of lugging power, tows like a train and huge power gains with simple mods.
    Petrol the 4.8 Patrol gets my vote.
