Which of these 2 w.angle lenses do i buy
Results 1 to 6 of 6
    May 2012
    Morgan Bay
    Thanked: 79
    Default Which of these 2 w.angle lenses do i buy
    I am looking for a wide angle lens and was advised a 10-22mm USM would be a good choice.Searching Orms i came across these 2 lenses.Is there going to be all that diffrence considering the price.The 18-22 is a STM.Please give me your opinion.Usage will be leisure not for pro use.Thanks Tony
ID:	531966   Click image for larger version.
    Skelmbos
    Thanked: 46
    Default Re: Which of these 2 w.angle lenses do i buy
    Which camera body do you have?
    Full-frame? Crop?
    And why wide-angle?
    May 2012
    Morgan Bay
    Thanked: 79
    I have a Canon 650d full frame body.Would like wide angle for landscape and some star photography
    Mar 2013
    Thanked: 635
    Quote Originally Posted by TonyC View Post
    Hi Tony
    The 650d is a cropped sensor body, not full frame, that means that you will be able to use any of the two lenses as both are EF-S lenses. You cannot use the EF-S lenses on a full frame camera. The Canon full frames are the 5 d and the 6 d series. Also keep in mind that with the cropped sensor on a Canon camera a 10 mm is actually a 16 mm lens. On Nikon the factor is 1.5
    For astro photography I would look for a lens with the lowest aperture to get a much light as possible. Something like one of the old Rokinon 14 mm 2.8 manual lenses. Both the advertised lenses will work, but you might not get spectacular results, with astrophoto's equipment does make a difference.
    Thanked: 713
    Unless you are happy with star trials (rather than pin-point stars) these lenses are both too slow (in terms of maximum aperture).
    To my mind, if you want pin-point stars on a crop-frame camera, there is currently only one lens to use. The Tokina 11-16 or 11-20 f2.8.
    Just my 2 cents.
    The more expensive lens you linked to above is a full stop slower, so your ISO will be double what you can use with the Tokina. That will be around 4000, and with the f3.5 you will be approaching 8000.
    The 14mm f2.8 Rokinon is nice on full frame, but on a crop it limits exposure time to about 15 seconds, once more pushing the ISO way up...
    Thanked: 161
    I can't help with the lens choice and know nothing about star photography, but can confirm what Peter Connan (who seems to know a lot about the topic) said about the Tokina - I have the 11-20mm f2.8, but for Nikon, very sharp lens.
    2006 Isuzu DMax 300Tdi DC 4x4
