Some ideas for pumped water please
Results 1 to 16 of 16
    Default Some ideas for pumped water please
    My drawer system has a 60 L water tank that sits in the front of the drawers and has a pipe that runs to the rear at the bottom.
    The Q is, what is a good suggestion to get the water out. it does have an inline pump. Currently it basically has a water pipe connected but Swambo says it is difficult and awkward to use.
    Ideas please.
    BMW R1200R
    Jan 2015
    Vredenburg
    Default Re: Some ideas for pumped water please
    Ideas please.
    Have you considered creating a small amount of positive pressure by use of a small pressure pump?
    Can the water tank be pressured ?
    For a minimal solution- before complicated pumps, electrics etc. -try..
    -fit a tyre valve to the water-tank cap and make sure it is sealed airtight.
    -leave some empty volume in the tank-say 5l or so-when filling
    -screw tank cap on to ensure airtight seal
    -pump up tank slowly and carefully with hand/tyre pump/compressor -do some tests to see what safe pressure works for the tank -(some straps/reinforcing of tank may help)
    -the contained pressure should well be enough for general water delivery at waist level -possibly even shower level, depending on your pressure/pipe diameter.
    I have similar tank behind drawer system-I have pipe running to tap just under the rear bumper-gravity feed is sufficient-
    and bending down now-and-again can only be beneficial to health!8)
    "The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence."
    - Charles Bukowski
    Thanks guys
    I must not have explained myself very well. it does have a 12 v inline pump, the ones they use on the caravans.
    Onto this goes a pipe and then .............. just the end of the pipe. What I did was hang a couple of pipe hangers onto the side of the drawer system, when the pipe is upright, you can see the level of the water in the tank.
    But that's it, no tap, shower head, gizmo or whatchacallit.
    Switch the pump on when the hose is pointing at you and .... well let's just say it does not end well.
    BMW R1200R
    Wilderness
    Well? Whats the problem? Fit a tap! Or showerhead or whatever! Duh!
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    That is the problem, I am too dumb to know what to fit, tap showerhead, nozzle ?
    BMW R1200R
    Vanderbijlpark
    Maybe something similar to this? There are more “elegant” valve options available at waterpiping stores. This one is fitted to our Xcape and it makes it easy if we want to empty the tank.
    Camping enthusiast. Overlanding addict. Child of Africa. Nature lover. DIY fanatic. 4×4 novice.
    Wife to one, mother to two. Happy lady who camps.
    Jan 2016
    Pinetown
    I fitted a tap and a the ran a t piece and fitted another 1m piece of hose with a normal garden fitting. So I can use any standard garden water device or extend the hose if needed. Works well for me.
    Si Vis Pacem Parabellum
    2012 Hilux 2x4 D/L
    A few basic mods.
    Dec 2009
    JHB
    http://www.parasolsa.co.za/product.php?id_product=304
    Ideas please.
    I could have told you what to do yesterday, but I doubt you'd have remembered.............did the blonde get you home safe?
    Apr 2012
    We all made it home after a great burger at Cut n Craft.
    Thanks again for the tickets and great beer!
    Citroen C5
    Touareg V8
    Audi A6 3.0 Avant
    Ruimsig
    Quote Originally Posted by zx14 View Post
    Thanks for the invite, its cos I have a beard isnt it? Cnuts
    Nah, it's cos you're a snob from Ruimsig.
    Ruimsig
    But I can socialise across stratum and I have no qualms about lowering my standards to hang out with you
    ag I have a bunch of brewing mates from your valley, you're not ALL bad
    but gee that Turn and Tender is expensive?
