300tdi oil pressure mystery after rebuild
Results 1 to 9 of 9
    Sep 2018
    Melbourne
    Default 300tdi oil pressure mystery after rebuild
    Hi all,
    We recently did a rebuild of sorts on a 300tdi which was really just a freshen up with new rings and bearings in the end.
    Anyhow, upon starting there was no oil pressure. This was confirmed with a mechanical gauge, where we got absolutely no pressure at all.
    Cranking with the oil pressure switch off shows that there is oil flow.
    https://youtu.be/hZeyLqbFhms
    So it seems as if there is something wrong elsewhere which is causing no resistance and preventing pressure build up. We are confident all the bearings were the correct size.
    We then overfilled the engine with oil to see if we could get it up and flowing but no luck.
    After that, we rigged up a pump with a gauge to the oil switch oil to try to check if the relief spring setup operated correctly at the 55 psi it is supposed to but we couldn't get it to hold any pressure at all.
    So the sump came off and the plunger and relief spring were confirmed as put in correctly.
    Basically there seems to be a leak in the system somewhere preventing resistance necessary to build up pressure as the pump appears to be providing adequate flow (or at least enough to provide some level of pressure..)
    We are at our wits' end so any assistance would be greatly appreciated!
    Jim.
    Nigel
    Thanked: 2310
    Default Re: 300tdi oil pressure mystery after rebuild
    Pull all the bearing caps and check the bearing clearances with Plastiguage
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
    Ruimsig
    Thanked: 11706
    Head gasket correct and channels not blocked?
    Oil pick up securely fastened and seal/o-ring in place?
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Langebaanweg
    Thanked: 1165
    Some of the engines I've rebuild took 5-6 3 second swings with the starter to get the oil pressure.
    Old trick on the V8 was to pack the pump with vasiline.
    It primes the pump faster amd dissolves in the oil.
  5. The Following User Says Thank You to jfh For This Useful Post:
    Thanked: 14083
    Any engine rebuild needs a new oil pump.
    But this is the clue: "new rings and bearings in the end"
    somebody stuffed up. too much bearing clearance to the crank and big ends
  7. The Following 2 Users Say Thank You to jelo For This Useful Post:
    Ruimsig
    Thanked: 11706
    Very possible, wouldnt be the first time. Pump doesnt create pressure, its the restrictions within the system that does
    Hummer H3 V8
    W.A.P Objectivist
    Ruimsig
    Thanked: 11706
    I had forgotten about that old trick
    Hummer H3 V8
    W.A.P Objectivist
    New Germany
    Thanked: 503
    Could be bearings clearance, cam bearings, oil spray nozzel left off to cam vacuume pump lobe or even oil squirt nozzles, pick up sucking air in
    or even excessive pump clearance and filter housing obstruction
    One will have to go through it and check
    2005 Defender TD5
    New Germany
    Thanked: 503
    Also what was the oil pump and crank cut always like, on the crank there are flats cut away that pump slots over to drive pump were they all still good not worn, resulting in crank spinning but no movement on pump,
    2005 Defender TD5
