Series I Question to the boffs
Results 1 to 17 of 17
    Virginia
    Thanked: 936
    Default Question to the boffs
    My mate has this LR. Permanent 4x4 with no diff locks.
    Just used as a plaything on trails.
    So seeing that it has no diff locks, he is considering putting in manual lockers similar to what the old hilux SFA's have.
    Will this work? If so, how would he confirm which lockers to consider seeing that he did not build the vehicle himself and has no idea what diffs it has...
    Would it be possible to put the same type of manual lockers on the back diff?
    All advice would be appreciated.
    Witfield, Boksburg
    Thanked: 64
    Default Re: Question to the boffs
    Permanent 4x4 with no difflock is standard.
    Should have centre difflock?
    It probably still has its factory diff then, so if you can figure out which year model it is that would help, even some pic's of the diff.
    You can remove the sideshaft as well, check how many splines it has.
    Chris
    "Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing" Helen Keller
    1996 Range Rover P38 4,6 HSE
    1977 LandRover Series III 109" Project
    Magalieskruin Pretoria
    Thanked: 265
    Daar was ou Landies sonder die centre lock. As ek reg was hier rondom die middel 80's.
    Ashcrofts ATB's of lockers of ARB's sal werk in die diffs.
    Henk
    So understand
    Don't waste your time always searching for those wasted years
    Face up, make your stand
    And realize you're living in the golden years
    Virginia
    Thanked: 936
    Quote Originally Posted by Crips View Post
    Not sure about centre diff lock. But should it have one, that just distributes power equally to front and back diff?
    Does not lock the wheels thus independant wheel spin is still possible?
    Or am I missing something?
    Witfield, Boksburg
    Thanked: 64
    Quote Originally Posted by Bacon View Post
    All depends what model it is and what transfercase.
    If it's a Series 3 like the door handels suggest, then it won't have centre difflock
    Chris
    Thanked: 13571
    Spot on: series 1, 2 & 3 was part time 4x4, not full time
    If it is a hybrid, who knows what is going on.
    Thanked: 936
    if it is 4x4 it has a centre diff lock. If it is based on a 90 defender type it will have a centre diff lock to lock the front and rear propshafts together. If it based on a Series vehicle it will have part time 4x4 which still locks the centre diff (which is doesn't have since it is part time) so front and rear propshafts are locked together.
    if he wants to install aftermarket lockers on each axle, then one would need to know what axles he is running? It looks like a very modified plaything, so there is a good chance he is running salisbury diffs front and rear? Ashcrofts is probably the best place to start looking I would have thought?
    If it is some Dana variant then I guess detroit, or trutrac or similar also become options?
    Thanked: 936
    Just looking and seeing leaf springs holding it off the ground, so it must be a series underneath, although range rover chassis, shortened with series body on top, is also a popular toy amongst the modified set.
    Probably running salisbury's if that is the case.
    Oct 2007
    Uitenhage
    Thanked: 527
    The OP needs to take some photos of the axles and the gearbox and transfer case. That'll help.
    The first time that a "Defender" had a centre diff was in 1979 with the introduction of the V8 Stage 1.
    No Series Land Rover before or after the Stage 1 had a centre diff i.e. no diff lock.
    I know that the very first Series 1s had some sort of a permanent 4x4 system, but it was scrapped pretty quickly in favour of part time 4wd.
    2004 Land Rover Discovery 2 Td5 ES
    Virginia
    Thanked: 936
    Quote Originally Posted by Fontuin View Post
    Will make a plan for more pics!
    Virginia
    Thanked: 936
    Right took a while but managed to get these pics.
    One of them has a serial number on (for what it's worth)
    He seems to think they might be salisbury diffs?
    Virginia
    Thanked: 936
    Please ignore the second pic - accidently uploaded
    Centurion + Others
    Thanked: 203
    Ive got a set of ARB lockers for 2 Rover diffs wit ALL connections switches compressor etc tc.
    evertyhing
    30k.
    It will make that thing a DEMON.
    Merit before Race - anything else IS Racism.
    Stay Calm, engage low-ratio, keep buggering on - a Landy Man
    Longevity isn't worth dying for,
  14. The Following User Says Thank You to Capt Chaos For This Useful Post:
  15. #14
    Mar 2015
    New Germany
    Thanked: 486
    Looks like Rover long nose diffs if that is the case you can get aftermarket diff locks, and seeing as they rover diffs so no free wheel hubs it will most prob have a LT230 you need to check that it has the center diff lock mechanism installed, if it is a series TCase it will have a low high leaver and a 4 High push down lever
    2005 Defender TD5
  16. The Following User Says Thank You to clivemd For This Useful Post:
  17. #15
    Dowerglen
    Thanked: 732
    Glad its just used as a plaything on trails, looks like a great fun Landy, but this steering link marvel must deserve its own award in engineering prowess....
    Either way, I guess it works, bumpsteer must be a shocker with those angles...
    Every dog has its day, and those with broken tails have their weak-ends...
    1976 CJ-7, 400CI + Holley EFI, Tera-Low 3,15:1 twin stick, ARB's front & rear, oil leaks & plenty more....
    All my other petrol burners are boring....
  18. #16
    Thanked: 13571
    precisely correct
    Lockers are available for the Rover axles.
  19. #17
    Virginia
    Thanked: 936
    Quote Originally Posted by Marcochezzi View Post
    We were looking at that ourselves yesterday!
    The vehicle was purchased as is.
