Jimny operating temperature
Results 1 to 14 of 14
    Thanked: 389
    Default Jimny operating temperature
    Does anyone know what the correct operating temperature for a 2010 Jimny is? I have searched google and the forum and can't find any info on this. According to the OBD2 my Jimny runs between 95 and 105 degrees, is this standard or high?
    Thanked: 245
    Default Re: Jimny operating temperature
    I'm not sure but my GV runs exactly the same temps if that helps
    Suzi Blue , 2008 Nocturne Blue Suzuki Grand Vitara 3.2 V6
    Dobinson's 40mm suspension, Wizerd rock sliders, radiator, sump and diff plates
    Frontrunner RoofRack, NL 2nd Battery Box, Llumar sun protection
    16" Hyundai Tucson rims, 235/70R16 General Grabber AT3 tyres
    Thanked: 389
    Quote Originally Posted by daveysmith View Post
    Thanks Davey, it does help!
    Thanked: 1383
    Quote Originally Posted by Johnna View Post
    90 degrees
    Sent from my iPhone
    Stilfontein
    Thanked: 617
    What does your temperature gauge in the dash display? Is it sort of in the middle or towards the high end of the gauge in the dash?
    Hartenbos
    Thanked: 339
    90 degrees
    Myne loop so tussen 87 en 90 op die Ultraguage.
    Cobus
    2010 Jimny
    Thanked: 389
    Quote Originally Posted by HeinrichC View Post
    It sits nicely in the middle and doesn't move around at all
    Dec 2013
    Paarl
    Thanked: 506
    Same here with mine
    Thanked: 389
    Laat mens wonder of myne bietjie hoog loop, en of die sensor dalk nie 100% akuraat lees nie...
    Thanked: 389
    I guess what I am concerned about is the 100 degree mark. When water turns to steam the cooling properties obviously disappear. I know that pressure in the system and coolant can raise the boiling temp significantly but I wonder by how much?
    There is no boiling effect happening in the cooling system (that I can pick up) but would obviously be worried about sailing too close to the edge...
    Dec 2013
    Paarl
    Thanked: 506
    Will check with obd2 to give you more distinctive answer that it is sitting in middle and not moving.
    I use the Torque app with obd2.
    Never really bothered me to check temp as the gauge very consistant.
    Thanked: 389
    Quote Originally Posted by johan65 View Post
    Thanks, that is what I am using to get my temp reding as well, it will be nice to be able to compare
    Thanked: 918
    Depending on the pressure cap it could easily be 118-120 degrees.
  14. The Following User Says Thank You to stephenplumb For This Useful Post:
  15. #14
    Hartenbos
    Thanked: 339
    Drove a 4x4 trail on a farm in the Karoo one very hot December. On a really steep, long climb, low range 1st, at very slow speed (no airflow through radiator except from fan) and with mid to high 40s air temperature, I have seen coolant temp of 110 and air intake temperature of 87 on the UltraGuage. Jimny had virtually no power and the aircon was wasting its time.
    Even with the 1800 in I have absolutely no problem with cooling. Maybe even too cold at normal road conditions and temps mid 20s.
    Cobus
    2010 Jimny
  16. The Following User Says Thank You to jab2 For This Useful Post:
