12v pressure pump - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 36 of 36
  1. #21
    Thanked: 397
    Default Re: 12v pressure pump
    I had 2 starter solar kits in my food trailer. One kit ran the lights & extractor fan. The other kit ran the water pump & music. Click image for larger version.
    Very similar to this
  2. The Following User Says Thank You to GaryFrank For This Useful Post:
  3. #22
    Jun 2007
    Pietermaritzburg
    Thanked: 141
    I ordered my 12 Volt pressure pump on the 04 July online from Reliable Store and it arrived at my front door on the 17 July. I was impressed by the way Reliable Store updated the order status every day detailing where about the order was. Hope I am impressed with the pumps performance as well.
    Gen 4 Pajero GLX 3.2 DiD
    Forum Radio Licence 1037
  4. #23
    Okahandja, Windhoek
    Thanked: 755
    Just mount that N$420 pump on something that absorbs sound, else you will wake up die whole neighborhood when opening a tap.
    Johan Kriel
    LCs, Hilux and Echo Chobe
  5. #24
    Thanked: 342
    Also take care of the pressure. Some of them pump as high as 8 bar. Also the one I used got to a point where it did not switch off at a time I was not at the caravan and it burnt out. In my case I used a pressure regulator to keep the pressure at a usable level. I am sure the pump will work well if only switched on when a tap is opened.
  6. #25
    Okahandja, Windhoek
    Thanked: 755
    Most of them have a bypass screw which you can fine tune the stop-start pressure.
    Johan Kriel
  7. The Following User Says Thank You to JLK For This Useful Post:
  8. #26
    Apr 2008
    Boksburg
    Thanked: 28
    Can one use this "Reliable" pump in line with a gas geyser? I will really like to have a system like that in my van
    Chris
    Pajero GLX
    Imagine Comfortvan
  9. #27
    Okahandja, Windhoek
    Thanked: 755
    Quote Originally Posted by visconeng View Post
    Yes absolute
    Johan Kriel
  10. The Following User Says Thank You to JLK For This Useful Post:
  11. #28
    Jun 2007
    Pietermaritzburg
    Thanked: 141
    True statement that. The fixing / mounting feet are rubber but the pump is certainly not the quietest
  12. #29
    Jun 2007
    Pietermaritzburg
    Thanked: 141
    I am trying to get away from the standard caravan tap that come complete with micro switch to start the pump when the tap is opened and was hoping a pressure pump would do the trick. Plan is to use the pressure pump with pressure switch and to use normal open / close taps. The other reason for wanting to use a pressure pump and remove the caravan submersible pump is so that I can pump drinking water through a carbon filter.
  13. #30
    Jun 2007
    Pietermaritzburg
    Thanked: 141
    Well this pump does work well but its simply too noisy. Going to have to look at alternatives.
    It can stay installed as a standby but its simply inconsiderate to use this pump in a public camping area.
    It really is that noisy and its installed on sound damping material in a "box" too!
  14. #31
    Thanked: 342
    You could try the Shurflo I think 2190 as a lower pressure 5.5L/min pump. Not sure about the noise but pressure is good. I have seen it at Silver lakes Camp world. Cost about R1300.
    It is also a pump that can suck water so no need to bleed.
    May be users can comment on the noise.
  15. The Following User Says Thank You to ekkekan For This Useful Post:
  16. #32
    Gauteng
    Thanked: 938
    I am going through this exact exercise now.
    I need to go from trickle to flow, not high pressure, just better flow rate. 5.5l/min sounds good. I assume this is a 12v pump?
  17. #33
    Polokwane
    Thanked: 476
    https://www.frontrunneroutfitters.co...l-per-min.html
    Compact Automatic Demand Diaphragm Pump
    Features:
    Compact Design Measuring 6.4" (160 mm) in Length.
    Fully Automatic Demand Pump.
    Self-priming and Can Operate Dry Without Damage.
    Built-in Thermal Protector.
    Sealed Pressure Switch and Motor.
    Low Noise, Acid, Alkali, Corrosion Resistant.
    Compact design and plug-in port fittings make installation easy.
    Sealed pressure switch automatically starts and stops pump when discharge valve is opened and closed.
    Self-priming so pump can be located above supply tank.
    Can run dry without damage and handle liquids up to 130 F (54​ C).
    Low amp draw for battery powered applications.
    Soft compliant Santoprene mounting system.
    No metal contact with liquid being pumped.
    Maybe this pump will work for you. I don't have personal experience of this pump and only go by their website features.
    There is this one as well but no mention of it being low noise.
    Features:
    Built-in pressure switch automatically starts and stops pump instantaneously when discharge valve opens and closes.
    Can run dry without damage and handle liquids up to 130 F (54 C).
    Ball bearing drive throughout pump and motor assures longer pump life.
    Excellent self-priming capability. Pump may be located above the liquid level.
    Powerful, permanent magnet motor with low current draw and long life brushes.
    Negative review for this one on their site
  18. The Following 2 Users Say Thank You to DC Polokwane For This Useful Post:
  19. #34
    Thanked: 342
    Quote Originally Posted by AntonN View Post
    Yes it is a 12V pump. Model 2095.
  20. The Following User Says Thank You to ekkekan For This Useful Post:
  21. #35
    Gauteng
    Thanked: 938
    Thanks very much. It is now on my acquirement list.
  22. #36
    Okahandja, Windhoek
    Thanked: 755
    I revised the plumbing on my caravan (echo chobe) a bit, to have the geyser permanent connected. Echo provides two taps (1 cold and 1 hot) with two loose pipes to connect the geyser if you need to use it, which I wanted to change. I preciously replaced the FLO 2022 pump (3.8lpm at 35psi) with shurflo 2095-204-112 (4.7lpm at 20psi), which work well till now, although it was a bit tricky to tune the hot water flow between the taps That FLO 2022 was just to noisy.
    Then shurflo 2095 struggles to supply hot water to the kitchen tap. The geyser switch on and off and the same for pump irrespective any setting. Google could not help me with the spec of the geyser, but eventually saw sticker on the geyser. It needs 1.5 to 5 bar water pressure!! Its 5.5l Atlas camp geyser. With the additional pipe length the pressure drop was just out of the pump's supply.
    Luckily I had also a shurflo 4128-110-A04 which can supply 4.1 lpm at 30 psi. (30 psi is about 2bar and 20psi is about 1.4 bar.)
    Now I can tune the hot and could water as you like at any tap and the shower.
    Moral of the story, check what you have first before start changing, and make sure the pomp pressure and supply match the geyser requirements and pressure drop in the pipes.
    Johan Kriel
