DIY Mini camping caravan build - Page 7
Page 7 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 121 to 140 of 244
  1. #121
    Dec 2010
    Morgenzon
    Thanked: 35
    Default Re: DIY Mini camping caravan build
    Avk do you have joints on the floor board?
  2. #122
    Dec 2010
    Morgenzon
    Thanked: 35
    I have a full board with no joints on mine
  3. #123
    Thanked: 85
    Very nice build!!!
  4. The Following User Says Thank You to ozosborne For This Useful Post:
    avk
  5. #124
    Apr 2017
    Thanked: 65
    Quote Originally Posted by TonyP View Post
    I was thinking more along the lines of epoxying in a few strips of fiberglass cloth.
    Tony, perhaps consider a routed strip of timber to allow a smooth transition of the fiberglass cloth to the floor board and side panel? excuse the hastily drawn sketch, experience has taught me that there will always be a few air bubbles in a 90 degree join when you try to force the cloth and resin into a 90 degree corner, good luck
  6. #125
    White River
    Thanked: 878
    Any 90% joint needs a fillet to round the corner off, thickened epoxy does this perfectly, otherwise the cloth won't bend to the corner.
    2011 JK Wrangler Rubicon 3.8
  7. The Following 2 Users Say Thank You to TonyP For This Useful Post:
  8. #126
    Jeffrey's Bay
    Thanked: 9815
    Quote Originally Posted by martiny View Post
    Unfortunately yes.
    The floor on mine is just too wide to fit only one sheet. Doesn't matter how I do it, will always need more than one sheet. If I stayed only within the wheelarches, I could've done it. But my whole idea is to incorporate the wheelarches inside the body of the van, and making use of that space inside.
    Quote Originally Posted by Armadillo View Post
    I would preferably not work with fibreglass cloth, etc. I have a bit of a daring plan in the back of my head which I want to try...but I'll get to that when the walls etc are up, and I start finishing the inside. Luckily, the corners and joins inside should be easy to get to if the ever need replacing or fixing.
    Anton
    "At the end of the game, the King and the pawn go back into the same box." - Italian Proverb
    "The single most important component of a camera is the twelve inches behind it." - Ansel Adams
  9. #127
    Dec 2010
    Morgenzon
    Thanked: 35
    I found a board thats 1850 wide which is enough for the wheel arches included
  10. #128
    Jeffrey's Bay
    Thanked: 9815
    Unfortunately I couldn't find anything in my area wider/larger than normal plywood @ 2440x1220. So I'll go with the flow and use it.
    Anton
  11. #129
    Dec 2010
    Morgenzon
    Thanked: 35
    I think later on if its possible to get the inderside rubberrised or even stone chip sprayed ..for now i need to decide if im going to use square tubing infront and at the back as a reinforcement or just the ply wood weight wise the tubing and 38x38 brandering almost feels the same
  12. #130
    Jeffrey's Bay
    Thanked: 9815
    I will be using stonechip on the whole trailer's underside. I've used it in the past with similar trailers I've used, and it worked well. Also easy to apply, and I have the gun.
    For the frame I'm using wood only. Even though it might not be the sturdiest/best/etc. that is what I've always wanted to do. So I'm going to try it. I have a large amount of wood from projects I've done around the house. From purlines, to 38x38, to 114x38. And of course quite a few boards of 12mm plywood, and offcuts of said plywood. I have two nice, long, straight 114's on the garage which have been drying there for a long time...they are straight and much lighter than similar 'wet' beams. I might just use them as runners at the top of the trailer...I'll see how it works when I get there.
    For me a large part of this project is to see how cheaply I can do it. Not making a "cheap" trailer, just not spending money when it's not needed. Using up what I have in stock before buying anything else, if that makes sense?
    I'm going to play around with a few combinations to see what works best. When the fibreglass is fixed to the frame on the sides and the whole roof, it should form a really sturdy box.
    I've even considered making I-beams using strips of 12mm plywood. I've seen that construction method being use in a few DIY builds, and it seems to work quite well.
    Anyway, I'm just enjoying the process and the research. Which of course sometimes sidetracks me totally.... If I make mistakes, I'll fix it and move on.
    Anton
  13. #131
    Dec 2014
    Thanked: 1839
    That crowd in PE also do premade shapes, like angle and cappings, maybe have a look at their dogalogue for ideas.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  14. The Following User Says Thank You to JohnnoK For This Useful Post:
    avk
  15. #132
    Jeffrey's Bay
    Thanked: 9815
    Started mocking up the rear kitchen section this morning. The uprights will be used as is, the section connecting the uprights is just temporary to keep them up. Plywood "shelves" and a plywood rear will connect the sides at right angles to make a (hopefully) strong box. This also shows the reason for me building the separate rib-section below the floor.
    I'll follow basically the same procedure for the nose of the trailer. This should give me a strong rear and front "box" which I can then connect lengthwise to each other with a lighter frame. Now just wait for some cashflow to buy more materials.
    Unfortunately it was during this process that I realised that right rear corner of the trailer is drooping by about 15mm. Not sure if this was from manufacture or from lugging around the golf cart. This means I'll have to either fix it, or shim up the floor on one side. You won't see the shims, so I reckon that should be the easiest way.
    15mm at the bottom translates into a big difference at the top. If I just build from it, there will be a noticeable lean to one side. Not happening.
    Anton
  16. #133
    White River
    Thanked: 878
    Damn, that's bad luck. Are you planning to shim the base/floor up by 15mm on the right hand rear corner? That's quite a gap, but a lot easier than trying to straighten out all the steel of the trailer. It's maybe something to do with the breakneck arrangement and could actually be easier than you think.
  17. #134
    Jeffrey's Bay
    Thanked: 9815
    Unfortunately it seems to be the frame itself. Measuring from the floor to the frame just inside the wheel wells are basically the same. From the axle to the same spot on both sides also basically the same. So it is only at the back. I reckon I'll shim it up with strips of plywood, and the planer. Then wood glue it to the bottom of the floor to make sure it stays in place until I bolt the floor down.
    Anyway, that's just spitballing right now...will see again next weekend.
    Anton
  18. #135
    Jeffrey's Bay
    Thanked: 9815
    Had a little time yesterday so continued with the mocking up of the kitchen area. Still need to add a shelf on the bottom horisontal beam. But I now have a solid structure that can be moved as I need it. This will be blown apart at some stage when everything fits correctly, redone with wood glue, etc.
    And of course, here is one if my main reasons for taking on this project. Some quality time with the little ones.
    Anton
  19. The Following 3 Users Say Thank You to avk For This Useful Post:
  20. #136
    Thanked: 2155
    Quote Originally Posted by avk View Post
    Had a little time yesterday so continued with the mocking ...................
    Nou bou jy Belangriker as enige eind produk
    Henk
    Follow us on Facebook
  21. The Following 4 Users Say Thank You to hbannink For This Useful Post:
  22. #137
    Jeffrey's Bay
    Thanked: 9815
    Verseker!
    Anton
  23. #138
    Wilderness
    Thanked: 1178
    When i built my caravan i constantly used a level to make sure that i am working from a 100% horisontal surface. Are you sure it is the frame and not something on the suspension?
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  24. The Following User Says Thank You to Pieterk For This Useful Post:
    avk
  25. #139
    Jeffrey's Bay
    Thanked: 9815
    Jip. 100% sure. Took measurements from directly over the axle as well. But it's not that huge of an issue. I will be able to work around it.
    Anton
  26. #140
    Jeffrey's Bay
    Thanked: 9815
    Fitted the 2 parking jacks in the rear of the trailer this morning.
    Side advantage of this is that between the parking jacks and a trestle behind the hitch, I can now have a steady, level base to work on.
    Anton
  27. The Following User Says Thank You to avk For This Useful Post:
