Wooden box for outdoor storage
Results 1 to 9 of 9
    Thanked: 677
    Default Wooden box for outdoor storage
    I need to move my bikes from the garage to outdoor storage and have thought to do something like this to accommodate two bikes.
    Top or front panel needs to be removable (no hinges)
    Minimum inside measurements shown
    Weatherproof
    Questions:
    Pine / Saligna or ?
    Thickness ?
    T&G / laminated etc sides ?
    Wood treatment
    Reinforcement of structure? (Max mass will be ~30 Kg's)
    Screws / hex key / pan head fasteners etc?
    Pointers will be appreciated.
    Mar 2012
    Randburg
    Thanked: 1062
    Default Re: Wooden box for outdoor storage
    My two cents worth would be to look at Wendy house construction as a start.
    Go for pine or cheaper and stronger consider plywood.
    Something like 19mm
    Use Waxol or Navo 17 Depending on the surface you require.
    Use a combination of wood glue and Screws.
    Raise the box slightly of the floor to prevent wood rot.
    4.0 XJ Jeep Cherokee - Go anywhere
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
  3. The Following User Says Thank You to ViperR For This Useful Post:
    Mar 2007
    Harties Boet
    Thanked: 823
    2004 Nissan Patrol 4.8
    1999 Nissan Patrol 4.2D
  5. The Following User Says Thank You to Graham For This Useful Post:
  6. #4
    Thanked: 182
    Why wood in particular? More for aesthetical value?
    Why not steelframe with coloured Chromadek cladding? No maintanance.
ID:	531462Click image for larger version.
    "The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts" : Bertrand Russell
    2014 Nissan Navara 2.5 4x2
    1995 Nissan Sani 3.0 V6 4x4
  7. The Following User Says Thank You to staalwol For This Useful Post:
  8. #5
    Struisbaai
    Thanked: 840
    I would use Nutec.Wooden frame with the Nutec.
    Either the boards or for looks use the patterned "planks" that they use to build Nutec Houses.
    2015 Land Cruiser 79 D/C V8 Diesel Turbo
    2000 Prado 90 KZTE SWB.
    Bush Lapa Boskriek No 607 - Die Kriek
  9. The Following User Says Thank You to LC Man For This Useful Post:
  10. #6
    Thanked: 677
    Thanks for the advice & recommendations, will consider the options
    (Need to add, the 'solution' should be fairly low profile and easy movable)
  11. #7
    Thanked: 976
    For simple construction, low cost, and easy movability
    -I'd use a 18mm waterproof ply ( either marine WBP, or genuine waterproof shutterply ( not the non-waterproof stuff the local hardware calls 'shutterply' - always look for the dark/black gluelines between the plys) -fixed onto H4/5/6 treated internal frame ( 38x38 or 50x50), countersunk screws, Balcotan glue, polyester filler ( bodyputty) to holes, entire box mounted on 3 or 4 off 100x100 or 100x50 treated bearers, and placed on bricks/blocks. To move box-insert 2 poles under box, 4 sets of hands and carry like a stretcher ( I expect you would get closer to 50/60 kg though, in weight)
    Entire box sealed with sanding sealer -thinned first coat-then final colour coats of good quality external paint.
    "The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence."
    - Charles Bukowski
  12. The Following User Says Thank You to Patrick L For This Useful Post:
  13. #8
    Thanked: 13574
    Use 18mm shutterply with a marine sealer as mentioned. Unless it is permanently submerged, it should last many many years and shutterply or end-ply is bloody robust.
  14. The Following User Says Thank You to jelo For This Useful Post:
  15. #9
    Thanked: 677
    Thanks guys, is it something like this?
    https://www.davidsonsboards.co.za/product/redwood-6
    and
    http://ecotimbertraders.co.za/products/plywoods
    Marine Plywood
    We believe we carry the best Marine plywood available in South Africa. All our Marine plywood is made from Keruing wood which is a lovely deep red colour. The veneers are precise and crisp and the colour of the veneers is uniform. Our Marine ply is all BS1088 certified.
  16. The Following User Says Thank You to PieterOos For This Useful Post:
