Welding machine for R998
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 68
    [REMOVED]
    Thanked: 258
    Default Welding machine for R998
    I need to build a little fence with gate next to my house and need a welding machine. Will I make a mistake with this ?
    Do these cheapie DC welders last ?
    Attachment 530915
    EDIT: Dont know what happened with the link (Hotlink)
    Image reattached
    Rangeview Krugersdorp
    Thanked: 1244
    Default Re: Welding machine for R998
    Coastal hire ?
    Ford Figo 2016
    Thanked: 49
    Quote Originally Posted by SBSP View Post
    https://www.builders.co.za/Tools/Han...00000000628841
    I live in Sinoville, bordering on Montana. I also have a welder which you can borrow for the job, if you wish.
    Attachment 530914
    Land Rover Discovery 2 TD5
    Echo 4 Off-Road Trailer
    Gemini 505 S/Rigid
    Ford Ranger T6 S/C 4x2
  4. The Following User Says Thank You to Jack B For This Useful Post:
    Sep 2011
    Potch/Brits
    Thanked: 583
    It depends if you want to weld again?
    It should do the job, but for how long?
    [REMOVED]
    Thanked: 258
    Thanks Jack that's a nice gesture.
    I always borrow my brother's welder. I actually want my own to do stuff here and there.
    I found this thread, https://www.4x4community.co.za/forum...32-What-welder
    Looks like a 130A welder is borderline useless ?
    Mar 2013
    Molopo
    Thanked: 147
    I bought similar. Looks exactly the same but different brand. It will do the job. For how long I don't know but for that price it is good.
    Sasolburg
    Thanked: 547
    I have a Disston, although its a 180Amp it has completed a number of projects and I am happy with it. For the price and around the home I think its a good buy.
    Duty cycle is not great at high amps but for welding tubing and palisades with 2.5 Electrodes you don't really need more than 60 to 70 amps.
    I'd say go for it.
    If Force is not the solution, not enough of it was applied....
    Thanked: 1162
    I own a cheapie inverter welder from Adendorfs. Think I paid R1500 for it a decade ago.
    It still works perfectly and much better than an old-school welder. I don't use it often so I won't claim that it is an industrial tool.
    But it seems like your needs are similar to mine so I would say that a cheapish inverter welder should be ok.
    Defender 2.8i
    Thanked: 13574
    it will be fine
    Nov 2017
    Thanked: 34
    Welder will be fine. Spend some cash on a auto darkening helmet. Does wonders
    Gaborone, Botswana
    Thanked: 1164
    For a fence and gate you will mostly use 1.6mm to 2mm wall thickness steel and 2.5mm rods.
    You will seldom exceed 80A. The welder will be fine.
    Get the auto darkening helmet.
    Kobus
    [REMOVED]
    Thanked: 258
    Great, I will go get it today then
    Thanked: 2442
    Tip number one : weld onto clean rust/paint/coating/grease free steel.
    Prep your welding area with a wire brush or wire wheel on a drill. It is the single best tip for getting good welds.
    I have a matweld cheapie welder and it works well.
  15. #14
    Thanked: 13574
    precisely
    and
    get an auto darkening helmet
    R250 at Makro is the average price.
  16. #15
    [REMOVED]
    Thanked: 258
    Got it thanks, I haven't welded something myself in a very loooong time. When i bought the 25x25mm tubing i opted for 2mm walls knowing that I am going to be burning holes.
    Tell you what! , when I'm done welding it together I will post some pictures of the weld, should fun
    The health and safety on the description of this welder read's
    Caution! Always connect the battery first and then the inverter/UPS.Caution! DO NOT place anything between battery cable ring terminals and battery terminals. The terminal stud/bolt is not designed to carry current. Apply Anti-oxidant paste to terminals after terminals have been torqued.
  17. #16
    Thanked: 245
    Please use eye protection when using wile wheels.
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
  18. #17
    Thanked: 2442
    Yes. Eye protection is critical. Those wires fling off at great speed and will blind you!
  19. The Following User Says Thank You to MariusFourie For This Useful Post:
  20. #18
    Thanked: 1162
    I once saw a guy that welded a 6 metre gate without using a helmet. He just squinted his eyes.
    Not a pretty sight for sore eyes
    Defender 2.8i
  21. #19
    Thanked: 439
    Invest in a decent 115mm grinder.....it can make any weld look good
  22. The Following 2 Users Say Thank You to GaryFrank For This Useful Post:
  23. #20
    durban
    Thanked: 1056
    Ha Ha thats funny. My spraygun came with a reminder of air tools need to be oiled.
  24. The Following User Says Thank You to plunger For This Useful Post:
