35" wheels on defender
Results 1 to 16 of 16
    Dec 2010
    klerksdorp
    Thanked: 99
    Default 35" wheels on defender
    Hi everybody
    I have a 110 pick up that i use as a toy.It has 33" wheels on at the moment and everything else is still standard.
    I can now get a set of 35" tyres but i dont know how much i will have to modify my vehicle to fit them.
    If somebody has done it please tell me if it is worth it and what it entails.
    Thanks.
    Feb 2008
    Elarduspark
    Thanked: 203
    Default Re: 35" wheels on defender
    Aarde na John Grobler!!!
    John van die Landy Shop in Hoedspruit het al jare 35's op sy pick up. Daar was nie veel mods as ek reg onthou nie. Daar was nie te lank terug 'n stasiewa (goud geel) by Overland Worx gewees vir 'n diens ook met 35's op. Gesels dus met tgwinduna (die baas vannie plaas by Landy Worx) oor wat jy sal moet doen om daai wiele te fit.
    Henk
    So understand
    Don't waste your time always searching for those wasted years
    Face up, make your stand
    And realize you're living in the golden years
    Apr 2009
    Thanked: 203
    Quote Originally Posted by johnnybritz View Post
    Hi everybody
    Thanks.
    lots of work needs to be done to make it work properly, Ben van Dyk on the forum had a complete post about it all..
    do a search
    Thanked: 10290
    OFF THE TOP OF MY HEAD and if I recall properly:
    4" lift
    wheel spacers
    wheel arch extensions
    Mar 2013
    Thanked: 342
    4" lift
    wheel spacers
    Might get away with a 2 lift
    Wheel spacers
    Wheel arch extenders
    Caster correction radius arms
    HD drive flanges
    Ps with a 4 lift your looking at extending brake lines. But there are braided hoses available.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    -Land Rover Defender 110 Td5
    -BMW G650 xChallenge
    Thanked: 10290
    Quote Originally Posted by pjf110 View Post
    Wheel spacers
    HD drive flanges
    Yes, I think you are correct
    Sandboarder put 35s on with the following:
    10J Modulars (UK) -30 offset
    2" Terrafirma HD Lift
    35" GY Wrangler Kevlars
    Caster correction by Burnco
    Thanked: 1105
    Won't the larger tyres turn the Defender into a real donkey?
    Defender 2.8i
    People talking without speaking
    People hearing without listening
    Jan 2010
    Mosselbaai
    Thanked: 480
    A regear to keep the driveability as well I reckon.
    Will follow with interest
    Jeep Wrangler TJ
    Volvo XC60
    Amarok AWD
    Jan 2010
    Mosselbaai
    Thanked: 480
    Quote Originally Posted by albertvl View Post
    A diff ratio change is not very expensive and makes a huge difference.
    Jeep Wrangler TJ
    Volvo XC60
    Amarok AWD
    Thanked: 10290
    Quote Originally Posted by Jeanvn View Post
    Cheaper to get a transfer case with a lower final drive ratio. The 1.667 ratio is available.
    New Germany
    Thanked: 422
    Running 35 on 15x10j rims with +2 coils front and 2 spacers on rear just +2 coils, have wheel spacers, 6 caster front and also changed back as well to adjustable one, changed panhard rod to adjustable one, changed brake hoses to SS braded lines.
  12. The Following 3 Users Say Thank You to clivemd For This Useful Post:
  13. #12
    Thanked: 10290
    She's looking sick, Clive. Bloody well done.
  14. The Following User Says Thank You to jelo For This Useful Post:
  15. #13
    Thanked: 2393
    One of the best builds on the forum.
  16. The Following User Says Thank You to grips For This Useful Post:
  17. #14
    Jan 2009
    Thanked: 101
    I've built two Defenders on 35's.
    110 Puma CSW & 100" 3.9 V8 Pickup.
    From what I can remember at the moment, the minimum to be done:
    * 30mm wheel spacers
    * 2" lift
    * Stronger steering rods. 35's bend the standard ones on tar, never mind offroad
    * Upgrade your brakes
    On Puma I did the following related to the bigger wheels (+ lots and lots of other mods not mentioned):
    * 3" lift
    * Extended brake lines
    * Widened wheel arches
    * Cranked trailing arms
    * Replaced with reinforced pan hard rod
    * Replaced reinforced steering rods
    * Power Brake upgrade
    * RTC steering damper
    * Trim wheel arch in rear
    * Modify long range tank
    * Modify wheel arch water tank
    * X-Eng lockable anti roll bar
    - I have stripped diff twice, broken many side shafts & recently a propshaft too....
    - The gearing on Puma is quite good with the 35"s
    On V8 100" pickup:
    * Steel rims with offset
    * 3" lift
    * Re-geared transfercase (it's got auto box, which also helps)
    I would recommend Ashcroft drive train upgrades. The problem is where does one stop... Somewhere something will want to break - I chose it to be side shafts
    Range Rover Big Body 5.0 V8 Supercharged
    Land Rover Defender 110 CSW Puma
    Land Rover Defender 100 PU V8
    Land Rover Freelander II SD4
    Jaguar XJS V12
  18. The Following User Says Thank You to bvandyk For This Useful Post:
  19. #15
    livingstone
    Thanked: 157
    The problem is where does one stop... Somewhere something will want to break - I chose it to be side shafts[/QUOTE]
    I love that sentence!!!!
  20. #16
    Apr 2011
    Sandton
    Thanked: 201
    Very cool build!
    '06 TJ Wranger | 4.0L Auto| 4.5" Lift | 35" Copper STT | 15" MT Classic II Black | 4.88 Gears
