FIAT Fullback Alarm
Results 1 to 13 of 13
    Thanked: 21
    Question FIAT Fullback Alarm
    Hi Fullbacks
    My bakkie's alarm sometimes beep four times when locking, and sometimes only twice.
    Fiat centurion just shrugs their shoulders and say they cannot do anything about it. Yes, the bakkie is still under warranty.
    The fact that it behaves differently, and I am not able to reproduce the problem, says something is wrong.
    What is the normal coming and going ito your alarms? Beep once for unlock, twice for lock?
    Also, please advise on another dealer, preferably in Pretoria? Is Menlyn any good?
    Wow FIAT Centurion's service is horrible! I feel so bad for anyone who has bought a R1m+ Jeep there! Sies (Not even worth explaining why I say so, not even due to the alarm not being able to be fixed)
    BMW X5 3.0d ---
    Vorige? FIAT Fullback 4x4, Wat 'n loutere stuk strooi voertuig en geen diens van FIAT af nie. Bly weg...
    PRETORIA
    Thanked: 41
    Cool Re: FIAT Fullback Alarm
    Hoe ry daai triton in skaap klere??
    Dink jy het goeie koop gekoop.
    Ek nog baie happy met my chinaaaa.
    FOTON TUNLAND 4X4 LUX
    Thanked: 21
    Default Re: FIAT Fullback Alarm
    Quote Originally Posted by UITZICHT View Post
    Ja, oor die algemeen is ek steeds baie tevrede. Meer spyt dat ek omgegee het oor waarborg, maar die handelaar voel nie die selfde daaroor nie.
    BMW X5 3.0d ---
    amanzimtoti
    Thanked: 8
    Mine does exactly the same. dont think there is anything wrong thats why the dealer cant help you. Must be just the way its programmed.
    Thanked: 21
    Quote Originally Posted by trev1136 View Post
    Can you reproduce the one honk, or the four honks at will?
    I have a booking with Fiat Menlyn tomorrow, and will hear what they have to say.
    BMW X5 3.0d ---
    amanzimtoti
    Thanked: 8
    I have not really tried. will try and feedback.
    amanzimtoti
    Thanked: 8
    Did the dealership have any answers ?
    Thanked: 21
    Yes, they did! Top notch service from FIAT Menlyn, highly recommended!
    They found a bulletin about the alarm module that gives problems. They will have the part in three weeks, and will install it.
    BMW X5 3.0d ---
    Sep 2016
    Boksburg
    Thanked: 125
    I've been driving Fiats and Alfas a while. Alarm always gives an additional sound as a warning if one of the doors or boot is not properly closed when activating.
    Not saying this is the problem for the OP, but hopefully it will help someone.
    Alfa 159 - die dors ene, met 6 silinders
    Fiat 500c - SWAMBO se pink'e met 'n swart pruik, en make-up
    VW T5 4Motion - cause there ain't no Italian 4x4 kombies
  10. The Following User Says Thank You to JAPster For This Useful Post:
    amanzimtoti
    Thanked: 8
    Quote Originally Posted by Tr0jan View Post
    Thats good news then. Will check in after 3 weeks to see if it makes a difference. Thanks.
    Sep 2016
    I found that my Fullback gave additional beeps when arming the alarm if my indicator was on when I turned off the key. The additional beeps are there to just warn you that something is not where it should be (eg the indicator lever) try it and let me know.
    Thanked: 21
    Quote Originally Posted by JackLion View Post
    Tried everything, if the doors are open, it does not arm at all.
    If I lock and or unlock the door before arming, I still cannot reproduce the four beeps.
    Lights on, lights off. Sometimes one beep, sometimes four.
    Indicator? Nope, that is also not active when locking.
    BMW X5 3.0d ---
    Thanked: 21
    Feedback on the alarm.
    New one was installed. Doesn't work at all.
    Another 6 weeks wait from fiat.
    BMW X5 3.0d ---
