PN to Dehoop
Results 1 to 7 of 7
Thread: PN to Dehoop
    Jun 2015
    Default PN to Dehoop
    Planning to sleep over in Dehoop campsite Richtersveld for two nights enroute Namibia.
    We will overnight In Hondeklipbaai and then make our way to Dehoop.
    Will be towing an Xplorer with the Patrol. Any advise on the best road to take to Dehoop campsite. I see there is 2 options:
    1. Via Sendelingsdrif
    2. Via Helskloof pass and Domorogh pass
    also I see its about a 2.5hrs drive from the park entrance to Dehoop.
    Any advise on these 2 options - easiest and fastest route to the campsite.
    Now - '19 Ford Ranger 2.0
    Now - '07 Patrol 4.8GRX
    Then - '04 Disco 2 TD5
    Barberton
    Thanked: 968
    Default Re: PN to Dehoop
    Quote Originally Posted by IR_eddie View Post
    I believe you have to book in at Sendelingsdrif
    Lonehill, JHB
    Thanked: 829
    Yes, you cannot go via Domorrah pass when entering, only when exiting.
    You will have to go via Sendelingsdrift because thatís where you check in.
    2014 Pajero 3.2DiD SWB
    Jun 2015
    Cool thanks.
    How is the road between Sendelings and Dehoop for towing a caravan?
    Apr 2015
    Thanked: 250
    It is ok, just a bit slow going through the mountain passes (Akkedispas, etc).
    The last 2 or 3 km's is also a bit rough, but not a problem.
    Did it in April with a Boskriek.
    Discovery 1 1996 V8i (Sold, owned for 20 years); Freelander 2 2013 SD4 SE; Discovery 4 2014 SDV6 SE; Bushlapa Boskriek
    Thanked: 2128
    Your best route would be via Sendelings directly to DH. The last section to DH might be tight with the Xplorer (because of its length), but possible. I'd however just stay on the northern section of the camp as its a very tight section to get south.
    Lonehill, JHB
    Thanked: 829
    Just take is slow and easy on the tight sections but you should have no issues towing the caravan, it was very easy with the Metalian.
