Does Sikaflex conduct electricity
Results 1 to 16 of 16
    Jan 2017
    Rustenburg
    Thanked: 975
    Default Does Sikaflex conduct electricity
    I need to set some electrical components into a housing that needs to be very robust, but also waterproof, and able to flex ever so slightly.
    I was considering using sikaflex, but I am not sure if it conducts electricity, because if it does, that could be a problem. We are working with 3 volts and microampere currents by the way
    Thanked: 14201
    Default Re: Does Sikaflex conduct electricity
    Silicon is a semiconductor yes.
    Thanked: 20
    As far as I am aware, sikaflex is a polyurethane and therefore does not conduct electricity
    Putta
    Landcruiser 105
    BL Miskruier B850
    Dec 2014
    Thanked: 1916
    If you are uncertain, get hold of RS Components or AMT Composites and buy an electrical potting compound.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Ellisras
    Thanked: 607
    Potting compound is actually made of polyurethane (so is Sikaflex...)
    http://www.mantech.co.za/ProductInfo.aspx?Item=90M0104
  6. The Following User Says Thank You to Dungbeetle For This Useful Post:
    Thanked: 521
    Silicon is a semiconductor, silicone is a sealant.
  8. The Following 2 Users Say Thank You to faniedup For This Useful Post:
    Wilderness
    Thanked: 1222
    Sikaflex is not conductive.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  10. The Following 4 Users Say Thank You to Pieterk For This Useful Post:
  11. #8
    Jan 2017
    Rustenburg
    Thanked: 975
    Thanks for the responses so far.
    I have realised that silicone, or sikaflex for that matter isnt going to work, even if Sikaflex is not conductive.
    I can individually insulate all the components well enough to get around the conductivity issue. But I need a pretty large quantatity. (the mould is about the size of a small bread tin), and that amount of silicone will cost a lot. (Unless someone knows of well priced bulk silicone)
    I am back at looking at epoxies again. I need something that wont get too hot in the curing process though. Nothing more than about 15 or 20* above ambient will be okay.
    Any suggestions?
  12. #9
    Jan 2015
    Vredenburg
    Thanked: 943
    Silicone is a beautiful enhancer.
  13. The Following 2 Users Say Thank You to Karoo Klong For This Useful Post:
  14. #10
    Jan 2015
    Vredenburg
    Thanked: 943
    Try these guys.
    Not sure if they are near your home town. The website is not cellphone friendly but I buy my silicone for moulding from them.
    https://alliedfibreglass.co.za/?s=Si...t_type=product
  15. #11
    Hillcrest, Malaysia
    Thanked: 6516
    Quote Originally Posted by RPiet View Post
    Any suggestions?
    What on earth are you trying to do or accomplish.
    I canít even begin to imagine from your explanation.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  16. #12
    Nov 2011
    Thanked: 980
    Perhaps block bitumen will work? Very reasonable in cost, very effective at correct temp. range.
    We used to make our own waterproof joint housings for km's of farm pump/borehole cables with the stuff, and it worked wonders.
    You can buy large bagged blocks of it (from ABE/CHRYSO), which you melt down to pourable consistency -not sure of your possible working temperature range - but you should find full data sheets on their website.
    - Charles Bukowski
  17. The Following User Says Thank You to Patrick L For This Useful Post:
  18. #13
    Dec 2014
    Thanked: 1916
    Any suggestions?
    https://www.amtcomposites.co.za/prod...ubber/tin-cure
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  19. #14
    Jan 2015
    Vredenburg
    Thanked: 943
    Quote Originally Posted by Patrick L View Post
    The very same stuff used in the large 11kva and larger cable joints. Best option for your application indeed. Heat it up in the tin bucket with a gas stove.
  20. #15
    Thanked: 1029
    Have you considered cold-cure Polyurethane?
  21. #16
    Thanked: 1001
    So potting in large volumes has it's own challenges as compounds in large volumes will generally crack or exotherm which leaves a non homogenous product.
    Google "electrical potting resins" these have fillers to prevent shrinking and cracking. They are available locally through Elite. Right thing for the job, always best.
  22. The Following User Says Thank You to Andrew Leigh For This Useful Post:
