Toyota KZTE 3.0
Results 1 to 14 of 14
Thread: Toyota KZTE 3.0
    Apr 2019
    Port Alfred
    Post Toyota KZTE 3.0
    My Mother drives a Toyota HiRider KZTE 3.0
    She has now done 500000+km and still going strong. No oil leaks engine good enough for another half a million and she pulls a 1 ton trailer weekly and gravel road daily.
    She has been complaining that there has been a power decrease from when she bought it on 80 000km. I think this is normal considering the km and the drop in power has been gradual I believe.
    Does anyone know or have experience on how to increase the power just slightly without the potential of doing damage?
    Any advise will be appreciated.
    Margu
    Robertson/ Larissa, Greece
    Default Re: Toyota KZTE 3.0
    I think a full check of injectors, pump, valve clearance and turbo is well due at that mileage.
    Sep 2016
    Palmwoods
    Just some small queries.
    some maintenance info.
    some mods info
    I think those engines are good but half a million kms will cause engine and drive train wear.
    Nigel
    Some questions.
    How often does it do long uphills? That engine needs a good burn/cleanout from time to time.
    That bottom end is extremely hard. So if it has all it's regular services, it will be fine.
    A dose of 2 stroke on every 2nd tank will also clean up the inpellers on the turbo.
    Also change that thermostat. It is old.
    Also top up that viscous with a tube of silicone oil. (From Toyota)
    Uniglide
    +27 zero eight 2 four 95 9252
    Without a full strip-down you cannot know if this is general wear & tear or evidence of a bigger problem.
    You don't mention oil consumption and coolant loss.
    Has the fuel consumption increased?
    When last was it serviced?
    Bellville
    Whatever you do, just ensure you take it to someone with a "feeling" for older cars. Nothing worse for a car of this mileage to be taken to someone who looks at it with a view of "Ag it's OK, just another worthless old piece of @#% which the owner thinks is still worth something!" No quicker way of killing your still very usable, but down on power vehicle.
    Do your homework!
    2011 Pajero 3.8 GLS LWB
    1996 Conquest 160i RS
    Friemersheim, Southern Cape
    Quote Originally Posted by Margu123 View Post
    Margu
    I have a 97 Hilux 2.8D normally aspirated.
    It is on 422 000km. No oil usage even under load, if I don't push too hard.
    But my power is not what it used to be 200 000km ago. Sure injectors and fuel pump needs to checked, will be done next timing belt change....50 000km to go
    You adjust to the circumstances....towed a full trailer & bakkie to Hogsback (650km trip) two weeks ago with no issues. Slow going on the hills, even 2nd gear @3500rpm, but no oil usage.
    ...also no oil usage does not equate to no power loss
    My diesel mech just said.....'moenie krap waar dit nie jeuk nie'
    Malawi
    Quote Originally Posted by Ouarzazate View Post
    Do your homework!
    This!
    Don't let some laptop mechanic get near it, find the right place where they know how to deal with older vehicles.
    Apr 2019
    Port Alfred
    Some questions.
    Never does long up hills
    Never missed a service
    Thanks for the advice
    Apr 2019
    Port Alfred
    No Oil consumption but I think some coolant loss.
    Last service was about two months ago.
    I don't believe there is any problem with engine. It's just old.
    Apr 2019
    Port Alfred
    Do your homework!
    Thanks for the advice.
    Apr 2019
    Port Alfred
    I would go with that quote.
    coolant loss on the KZ-TE should be watched like a hawk
    but I think you are correct: it's old
    If the engine is low on power and not smoking too much under full load , things like boost pressure on the turbo should be considered.
    If I remember correctly the healthy boost pressure on the KZTE was about 85 kPa or 0.85 bar under load. If the engine sees the boost it will add the fuel for the power....no boost, no fuel, no power..
    On these older generation Tdi's the exhaust turbine's waste gate valve had a tendency to become leaky over time
    Old:1998 Hilux SC 3000D
    Old: 2001 Hilux DC KZTE
    Old: 2007 Fortuner 3.0D4D
    Current: VW T5.1 BiTdi Transporter
