Recommended winch "rope" size
Results 1 to 14 of 14
    Sep 2010
    London/Cape Town
    Thanked: 11
    Default Recommended winch "rope" size
    I've acquired a new-to-me 4X4 with a Warn 14,000 lb winch sporting the usual steel cable. I'd like to replace the cable with the "Dyneema" Kevlar rope instead (and change the fairlead) but looking around I see there are now a lot of choices with differeing brand names and even composition to choose from.
    I'd appreciate input on what diameter rope would be preferable for a 14K lb winch (approx 6K Kg) and how much the various types of synthetic rope vary in strength.
    http://www.masterpull.com/difference...c-winch-lines/
    I may never use this winch in anger. I've managed to avoid using the one on my other 4X4 for over a decade, so I doubt things will change now. So this is not a "challenge" truck. What use it does ever see will be slow and methodical. Obviously given any type of rope, thicker wll be stronger and less will fit on the drum. But I would think 25 metres is plenty (I have a whole collection of the usual recovery equipment plus a 30M Dyneema extension). The vehicle is garaged, so UV resistance is not critical.
    So the questions are - which rope, which thickness gives the best value in this usage?
  2. The Following User Says Thank You to CanAmSteve For This Useful Post:
  3. #2
    Okahandja, Windhoek
    Thanked: 655
    Default Re: Recommended winch "rope" size
    The diameter for the synthetic rope they use on winches is as follows: 10mm for 13 000lb, 11mm up for 16 500lb, 12mm for 20 000lb.
    Not sure what material is that?!
    Johan Kriel
    LC's and Echo Chobe
  4. The Following User Says Thank You to JLK For This Useful Post:
  5. #3
    Sep 2010
    London/Cape Town
    Thanked: 11
    Yes but that will be for one specific type (possibly even brand) or rope (see the link for some info).
    Let me phrase it a bit differently - should I go for a more-expensive name-brand like Dyneema, or a cheaper generic and probably thicker rope at less cost per metre? The thicker rope will also fill the drum faster, so I will "need" less of it. (Although, obviously I can buy a shorter, thinner & stronger rope).
    There's quite a bit on eBay from China, but would you trust it? I will probably only ever use it to test function and maybe to help someone else. If it snaps, it's at least less dangerous than steel cable.
    Thanks!
  6. #4
    Okahandja, Windhoek
    Thanked: 655
    Looks like they use about a 50% safety factor, thus for 14000lb, you need about 21 000lb rope, what ever type. If not using everyday I will not go for the most expensive.
    Johan Kriel
    LC's and Echo Chobe
  7. The Following User Says Thank You to JLK For This Useful Post:
  8. #5
    Feb 2013
    Strand
    Thanked: 36
    Go to Southern Rope in Paardeneiland, get 40m of GP12 8mm for around R1000 sometimes less. GP12 is dyneema without the trademark. Go onto youtube, do a brummel lock-splice. Don't pay R3-10k for a winch rope. If you want to go overkill get the 10mm. Ask for a rope sleeve for the section sitting on the drum and another 1.5m section near the hook. UV kills synthetic ropes so put a sleeve over the exposed sections.
  9. The Following 2 Users Say Thank You to kenskind For This Useful Post:
  10. #6
    Sep 2010
    London/Cape Town
    Thanked: 11
    Quote Originally Posted by kenskind View Post
    Wouldn't 10mm be weaker than 12mm?
  11. #7
    Feb 2013
    Strand
    Thanked: 36
    Quote Originally Posted by CanAmSteve View Post
    Yes and that would be weaker than a 14mm. But no. Synthetic ropes are actually stronger than their steel equivalent.
    https://www.southernropes.com/gp12/gp12/tech-spec
  12. The Following User Says Thank You to kenskind For This Useful Post:
  13. #8
    Feb 2008
    Elarduspark
    Thanked: 178
    This is the reason I do not trust those synthetic ropes. The heat will get them.
Name:	Melted plasma 02.jpg
ID:	529384   Click image for larger version.
Name:	Melted plasma.jpg
    Henk
    So understand
    Don't waste your time always searching for those wasted years
    Face up, make your stand
    And realize you're living in the golden years
  14. The Following User Says Thank You to Henkus For This Useful Post:
  15. #9
    Oct 2006
    Walmer Heights, Port Elizabeth
    Thanked: 55
    Quote Originally Posted by Henkus View Post
    Could you explain how this happened?
    1999 Colt Rodeo 3.0 V6 4x4-Build
    1998 Pajero Gen 2 SWB 3.0 V6 4x4-Resurrection
    1997 Ford Ranchero Outback 4.0 - Build
    SOLD
    1979 Landrover Series 3 88" Ford 3.0 V6 - Build
    1980 Landrover Range Rover 3.5 V8 - Build
    1979 Landrover S2A 109" with Chev 4.1
  16. #10
    Langebaanweg
    Thanked: 623
    Also not a fan. Mine gets used rarely, so I want the peace of mind that it will be good to go.
    I don't want to worry if it is going to perish in the sun.
    And I don't want to wash it if was used in mud.
  17. #11
    May 2019
    Germiston
    IMHO if it's certified to work within the rated working load most applicable to your vehicle/situation then price should be the last thing to look at.
    The only difference the price would make is the process the synthetic rope has undergone to make it a bit more resilient to the sun or sand or abrasion but as someone previously stated that too can be overcome by a sleeve fitted at the end that covers the rest of the spool once the rope has been fully reeled in. Any cheap product can last as long as an expensive product with the right care and maintenance.
    To make a long story short if it's rated and certified to snap or break at 15t or 17t it's going to snap at that given tension no matter the price.
  18. #12
    Thanked: 954
    winches on vehicles do not comply with the machinery act. The ropes are specced right on the winched pulling capability with very little safety factor. You should be ok with a 12mm rope, But I will go 16.
    Turnkey Construction Projects, Commercial, industrial, Domestic
    Importers: Diving gear, Compressed air cylinders for diving and airgun industry, 4x4 equipment.
    Manufacturers: Pofadder Kinetic ropes, Recovery kits, Synthetic winch ropes
    Vehicles: Modifications and installations, Special application vehicles
    Driver training: 4x4, Defensive
    [email protected]
    +27824453301
  19. The Following User Says Thank You to Engel For This Useful Post:
  20. #13
    Sep 2010
    London/Cape Town
    Thanked: 11
    Well, I have a friend with a winch and steel cable and when he last went to use it, the cable was rusted together quite well. Nothing lasts forever and I would say that rope got a fair bit of use. Everyone's situation is different, but while some use their winch every weekend to "play" getting unstuck, I with luck will never use mine. And if I do, I will not be in a hurry. So why lug around the extra weight of steel and the inherent risks (at breaking) of a steel cable? I'm also storing the vehicle under cover, so UV is not really an issue.
    I do agree that within reason, I'd rather have a stronger/thicker rope and live with the shorter pull. Thanks!
  21. #14
    Feb 2008
    Elarduspark
    Thanked: 178
    Quote Originally Posted by Racer-X View Post
    Heat from the brake of the winch. This one was used just to load a ski boat.
    Henk
    So understand
  22. The Following 2 Users Say Thank You to Henkus For This Useful Post:
